      04-29-2016, 04:03 AM   #1
michaelyang601
michaelyang601's Avatar
Drives: STI Cayman S Black Edition Z4M
Warning light
Problem Solved
Last edited by michaelyang601; 04-29-2016 at 09:21 PM.. Reason: Problem Solved. It was the angel eyes bulb off.
      04-29-2016, 08:11 PM   #2
Polarbert
English Member
25
Drives: 2006 Z4M Roadster
All the god damned time. On mine it's due to a fault with either the bulb, the ballast, or the ignitor. Its an intermittent fault and it doesn't always happen. Usually after the lights have been off and then come back on again. Also it changes sides on driver and passenger.
Does my head in and I've searched a lot and can't figure out which of those three things to replace.
      04-29-2016, 09:21 PM   #3
michaelyang601
      04-30-2016, 03:15 AM   #4
abelgonzaleZ4
Drives: 2006 BMW Z4 SilvrConvert 3.0i
What size of bulb is the angel eye bulb?
I want to change mine to a white LED's.
If you happen to remember m, I'd really appreciate it so I can order the lights size.
Cheers ��
      05-01-2016, 12:49 PM   #5
michaelyang601
Cheers ��
I haven't do any research for that yet. Still working for my business plan for this June. But I will definitly pm you once I have the information.
      05-03-2016, 07:10 PM   #6
StickMon
StickMon's Avatar
Drives: 2006 MR
Cheers ��
The bulbs are BA9s, but they're trapped in the plastic holder.
Once you get the bulb out of the socket, look between the bulb base and the plastic and you'll see where the pins want to get out from under the plastic.
Use an Exacto to make some little notches and then you can get the bulb completely out of the holder.
Do a search for LED replacements. There was a thread around here somewhere recently.
