      08-27-2010, 06:40 PM   #1
jra
Drives: 2005 z4
18x11
thinking of getting a set of ccw classics. possible to fit 18x11's with custom offset?
      08-27-2010, 08:46 PM   #2
crfine88
crfine88's Avatar
442
Drives: E86M
Need more info, what Z4 are in (2.5, 3.0, M...)
This would require some fender modification or an undersized strectched tire on the M for the rear.
Fronts would be a no go no matter what the offset unless you are willing to do some extreme fender modification.
      08-27-2010, 08:52 PM   #3
nmulax
nmulax's Avatar
Drives: '07 Z4 M Coupe
2007 Z4M Coupé  [7.66]
It's either a 2.5 or 3.0i (M was only '06-08)
      08-27-2010, 09:18 PM   #4
ZStig
instagram 997turbotom
284
Drives: Interlagos Z4MR
then no
      08-28-2010, 11:34 AM   #5
jra
Drives: 2005 z4
I know a 19x10 will fit the rears of a non m's. just thinking that it may be possible to fit a 10.5 or 11 in rear with an aggresive offset. I'm not oppossed to running a slight stretched tire in the rear. I'm in the process of doing a complete suspension/brake upgrade. just weighing all options. thanks
      08-30-2010, 02:30 PM   #6
misterawa
John 14:6
misterawa's Avatar
Drives: Z4
U should be able to get away with a 10.5" wheel at max. I think it would look good if the wheels u choose had a lip!
Mods: Eibachs/Konis, Eibach camber kit, JTD RSMs, 19" WedsSport SA67, Hamann headlight trim, Aero front bumper, Aero sides, AC Schnitzer side deflectors, Hella euro taillights, Hardtop, Dinan strut & supplemental bars, RD Sport intake, Dinan Stage 2 Software, RPI scoop, Bastuck catback exhaust, Radenergie CF engine cover...
      09-07-2010, 05:03 PM   #7
M II
Drives:
You might want to ring up CCW to verify. There are SOME fitments that even CCW will not consider doing.
