      10-02-2014, 05:17 PM   #1
ilikebmxbikes
Drives: S65 1M Clone & E92 M3 4.6L
z4 M coupe vs Z4 3.0 and 3.0si
Hello Zpost,
I am hoping some of you can help me as I am less educated on your platform.
I know the obvious differences between the powerplant in the Z4 Mc and the Z4 3.0si, but can someone educate me on the suspension differences? I want to know if it is shocks, springs, bushings, control arm differences etc.
I am considering a new project and am looking into potentially dropping an S85 into a Z coupe and want to know if buying an M warrants the price difference between a non M as the motor will be pulled.
      10-02-2014, 06:41 PM   #2
2280
3.0 and 3.0si are pretty much same as e46 non-m. 3.0si front brakes are e46 330i, rear brakes are e46 325/328
M is e36 m3 front, e46 m3 rear
i think...
      10-02-2014, 06:47 PM   #3
VMRWheels
VMRWheels's Avatar
2038
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
Originally Posted by ilikebmxbikes View Post
Hello Zpost,
Oooh I see another epic build on the horizon
      10-02-2014, 08:12 PM   #4
ilikebmxbikes
i think...
Are the control arms and bushings different?
      10-03-2014, 10:49 AM   #5
2280
Yes, Z4M control arms I believe are E46 330ZHP based which gives more caster. The bushings are also offset and not centered like the non-M Z4 (which share same control arms & bushings as E46 325/328).
I know my statement regarding bushings are correct, control arms not entirely certain. I would check realoem.
      10-03-2014, 11:26 AM   #6
ilikebmxbikes
thank you.
      10-03-2014, 12:19 PM   #7
chickdr
Drives: 2006 M Roadster
This will help you:
http://www.bmwmregistry.com/model_faq.php?id=23
      10-03-2014, 12:27 PM   #8
The HACK
The HACK's Avatar
1820
Front control arms are the same. Both the non-M and M Z4s come with ZHP control arms. The M has offset bushings similar to E30 M3s.
It's quite the frankenstein's monster.
      10-03-2014, 12:35 PM   #9
ilikebmxbikes
Originally Posted by chickdr View Post
Thank you chickdr - this is exactly what i was looking for.
Thank you for the info
      10-03-2014, 01:01 PM   #10
whatcubed
Drives: e46 330ci
Wow that's a great site.
      10-03-2014, 01:43 PM   #11
2280
Also FWIW even though the M suspension is compatible with E36 M3 struts, I think the shaft length is actually different so if you want a true Z4M application, using off the shelf E36 M3 parts isn't your best option.
      10-03-2014, 03:33 PM   #12
Kgolf31
Kgolf31's Avatar
459
Drives: 2007 Z4MC, 2012 128i
You can use rear E36 type suspension that are perfect to throw in.
However, the fronts are E36 type that are about 1" shorter, which is where you throw the monkey wrench into the situation
Brakes are also E46M ZCP brakes. Free Floating rotors.
Also the M Variable diff will get you started, unless you want to replace it instantly.
      10-03-2014, 05:52 PM   #13
2280
I thought Z4M rear was E46 M3 based
      10-03-2014, 07:17 PM   #14
Kgolf31
Kgolf31's Avatar
459
Not from what I was told. At least I thought the suspension was a direct swap E36
      10-05-2014, 11:54 AM   #15
The HACK
The HACK's Avatar
1820
E36 and E46 rear suspensions are similar enough that the shocks uses the same bolt-up points. For adjustable shocks, cars with E46 M rear end can use E36 M rear end suspension parts like shocks, and springs are the same inner diameter so customized springs can also work between E36 and E46 rears.
However stock components are not interchangeable because the springs are of different rate and length, and shocks aren't tuned to the other chassis' rates, obviously.
