08-09-2022, 03:02 PM | #23 | |
Rep 781
I couldn't tell you, I'm going to be installing them, I'm sure it wouldn't be cheap. When I have rebuilt diffs in the past I take them up to a transmission/diff specialist near me for them to check over my work and make sure the preload and lash are correct, they charge me $300 for that.
2008 E86 M coupe
08-10-2022, 03:43 PM | #25 | |
Rep 1,373
I am about to swap to a ZF 3 clutch LSD with 30/60ramps. I think instead of ordering his kit i'll just source bearings somewhere else since I know the part numbers now.
07 Z4 M Coupe AW/IR |
08-11-2022, 11:37 AM | #26 |
1621
Rep 4,294
I got the other bits from summit. Parts aside, for the crown and pin and the race diff from racingdiffs, output shafts and all the other bits and pieces, the cost was about a grand 500 for the install.this included the initial wasted time/labour opening up the z4m pumpkin. This was at Gear Masters DXB, probably the only shop I would take transfer case/transmission/diff rebuilds to in Dubai.
08-11-2022, 03:38 PM | #27 | |
Rep 781
"Hi Chris, No worries, this is the correct one RD4060 GKN v2 Advanced - comes with clutches, plates, free play delete, preload shim and Bearings and oil seals kit: https://racingdiffs.com/collections/...42833941922028 Price is discounted on a summer sale 423e + 58e DHL Express worldwide shipping. "
2008 E86 M coupe
08-12-2022, 02:07 AM | #28 |
1621
Rep 4,294
Lol yeah no doubt after I was in his ear 2 years and a bit ago. Initally sent me the e46 kit which doesn't have enough plates for the OEM z4m pumpkin.that said, I have absolutely no hesitation to recommend Racingdiffs.. they work with you untill it's sorted.. excellent company and they stand behind Thier stuff.
Might help if your gear bloke is also Serbian. Lolol.. pretty sure we did the ground work together for the Z4M as they initially thought it was the same diff as the E46 M3. Last edited by Vanne; 08-12-2022 at 02:13 AM.. |
grannyknot951.50 |
08-17-2022, 07:35 PM | #29 |
Rep 781
Everything has arrived to complete the job now, the ring and pinion gear and disassembly tool came in yesterday.
I thought the 3.91 ratio would be mentioned with the engraving but just looks like some kind of code, can anyone decipher? The second pic looks like I don't have a thumb.
2008 E86 M coupe
Vanne1620.50 |
09-13-2022, 08:21 PM | #31 |
Rep 781
Post #27 above, " No worries, this is the correct one RD4060 GKN v2 Advanced - comes with clutches, plates, free play delete, preload shim and Bearings and oil seals kit:
https://racingdiffs.com/collections/...42833941922028 Price is discounted on a summer sale 423e + 58e DHL Express worldwide shipping."
2008 E86 M coupe
09-14-2022, 07:59 AM | #32 |
Rep 1,373
FYI to everyone... You can buy the Timken bearings already REM polished from https://negearpolishing.com
He doesnt have all the bearings listed on his website yet but if you email him he can provide them. Super friendly and knowledgable about gears... he did the REM polishing on my 4.10. I have him also do the REM on my 3.91
grannyknot951.50 |
09-17-2022, 08:22 PM | #33 |
Rep 781
I started tearing down the LSD today, a couple of things, if you do this don't waste your time putting extensions on the end of the opening tool.
I put a 10ft extension on the handle and only managed to bend it and it didn't budge the ring one bit. A 2lb mallet and sharp hard blows had the ring off in minutes. Also, the 8mm Allen screws in the tool are only snugged up a bit, you want to tighten them down well before you start hammering. I bought the Victor-Reins diff input shaft seal because I wanted to avoid buying the seal that was originally used - because it always leaks. As it turns out V-R sells the exact same seal as was installed at the factory, don't want that so I'm going to use the Racing Diffs seal, it seems to be built a little beefier and you can see the seal spring is heavier weight so that might solve the leaking. The Racing Diffs side axles seals also use a stronger seal spring. The last pic is of some of the clutch pack discs, not sure they are all that bad for 91,000 mi but I'm replacing them anyway just because I'm in there.
2008 E86 M coupe
09-18-2022, 05:53 AM | #35 |
Rep 781
I think so, with all the new plates stacked in order it comes up to the same height as the original stack.
However there is this extra conical spring plate that is left over, I've sent a couple of pics to Aleksandar at RD to find out what it is, maybe from another kit Vanne, do you recognize it?
2008 E86 M coupe
09-18-2022, 09:46 AM | #36 |
Rep 975
It is there to give more preload and reduce the clunk noise. IMO you should use your stock clutches and since you are there, you can only add the free play shim and close it. With more preload you will wear down the clutches more quickly, in exchange you would get more lock and performance, but at the cost of durability.
Also, is known no aftermarket clutches will last as long. Did you measure breakaway torque before opening? If 50 to 60 NM, your diff is in spec. The RD spec calls for 100NM, but again, that will wear down your diff quicker. Is your car a weekend toy, or track? So you know, our diffs are used on the M5/6 S85 engine cars with 130NM more torque, so is more than good in our lower torque cars. One more advice I can give, check the numbers engraved on your old pinion and adjust the pinion shim accordingly. Those engravings mean 100’s of mm. I see your pinion has a +1, or one 100 of a mm, or in plain English, 0.1mm. |
AK72286.00 grannyknot951.50 |
09-18-2022, 03:29 PM | #37 | |
Rep 781
The car will mostly be used as a weekend car with a couple of track sessions per year. Forgot to measure the break away torque before disassembly but 50-60 nm of break away is fine with me so I'll just reuse the stock cone spring disc. Thanks
2008 E86 M coupe
09-20-2022, 04:40 PM | #38 |
Rep 781
I got everything back together and it is very hard to turn the input shaft, ring and pinion gears have zero lash so now I'm looking for a set of adjustment shims.
I could just order this set from RacingDiffs, https://racingdiffs.com/products/bmw...33487154151559 But I was wondering if anyone knew of a different option. Thanks
2008 E86 M coupe
09-20-2022, 09:40 PM | #39 |
Rep 975
For the V2 diff, if you follow the RD process, you will need to adjust side shims as you are effectively changing the width of the carrier. Did you measure how far off was your diff cap from the original position? if you measure the thread pitch you can estimate pretty accurately how much you change the width of the carrier and adjust the shims accordingly to go back to the original width. Also, did you adjust the shim for the pinion?
Don't proceed without making sure all is to spec, or it will whine at best, and self destroy at worse. Last edited by maupineda; 09-21-2022 at 06:27 AM.. |
09-21-2022, 05:11 AM | #40 | |
Rep 781
2008 E86 M coupe
09-21-2022, 06:26 AM | #41 |
Rep 975
No, there is a shim behind the big pinion bearing race. This shim is to set the pinion depth, which you need adjust to compensate for any pinion height difference from nominal, that was the inscription on the pinion itself. I assume you never read my post above.
Though easy, this job requires extreme precision or you will bang your head on the wall and regret. Measure twice, cut once. |
09-21-2022, 03:32 PM | #42 | |
Rep 781
Okay lesson learned, I'll remove the pinion and do some accurate measuring this time. Some how I got the idea that changing ratios in these diffs was a straight across swap. I have the shim kit coming and another collapsible sleeve as well. I do really appreciate yours and everyone else's advice and comments, I don't pretend to know everything and hopefully this will also help someone in the future.
2008 E86 M coupe
09-21-2022, 04:41 PM | #43 |
Rep 781
Just want to clarify again what is being done to this Z4M LSD diff.
New bearings and seals all around, new clutch pack and a change of gear ratio from stock 3.60:1 to 3.90:1 First 2 pics are the old ring and pinion, last 2 pics are the new ring and pinion. If you can't read it the old pinion specs are, XMK3628 10 25 +20288
2008 E86 M coupe
09-21-2022, 05:01 PM | #44 | |
Rep 975
My pinion also reads +1, just as yours. |
