05-02-2018, 10:34 AM | #1 |
Monkey Marshall
635
Rep 218
Clunk From Rear End
Hey everyone, so I've got an interesting issue...
I've been getting like a thud in the rear of the car. It seems to be in the right rear. Almost like something is moving. I'm running full Powerflex bushings in the suspension with new bilstein and H&R springs. Hell the entire suspension was rebuilt. Replaced with OEM where it was needed. I'm scared it might be a differential bushing. It happens at slow speeds (probably can't hear it at fast speeds). But it's just a "thunk" like when applying the brakes, or accelerating. It doesn't happen all the time, just every so often. Was hoping someone could shoot me some ideas on where and what to look for. |
05-02-2018, 10:47 AM | #2 |
Rep 2,704
Check torque at all the suspension attachment points.
I had the same thing after full poly rebuild. Sounded like the diff but was actually the sway bar bushing mounts.
05-02-2018, 10:50 AM | #3 |
Rep 150
I had a pretty serious clunk when my axel shaft started to fail. What happened to me is the bolts in the differential came loose and the drive train shifted just a bit putting the axel shaft at a weird angle until it failed.
05-02-2018, 10:54 AM | #4 |
Monkey Marshall
635
Rep 218
05-02-2018, 11:09 AM | #5 |
Rep 2,704
http://forum.e46fanatics.com/showthread.php?t=1054309
This is what I used Might suggest checking the TIS as well. Don't want to steer you wrong
05-02-2018, 11:26 AM | #6 | |
Rep 3,004
Perhaps this?
http://www.zpost.com/forums/showthread.php?t=1325707
Racerbruce
