03-31-2018, 02:33 AM | #1 |
Mechanical Engineer
96
Rep 1,025
2 hard tops on ebay - 10 hours left!
One crazy looking carbon fiber hardtop:
https://www.ebay.com/itm/Bmw-Z4-M-Ro...xatoCb&vxp=mtr Plus this Z4 with a hardtop included: https://www.ebay.com/itm/2003-BMW-Z4...daT9~-&vxp=mtr If you're local you could probably buy it separate from the car. |
03-31-2018, 02:41 AM | #2 |
10857
Rep 4,893
That first hardtop is from a company called D Moris.
Too bad that hardtop turned out so ugly, because when they presented the drawings for it (artist impression) it looked awesome.
04-02-2018, 11:07 AM | #3 |
Rep 1,130
First one sold already for about $2,300
2014 BMW X5 Sdrive35i F15
04-06-2018, 10:49 PM | #4 |
Rep 2,051
What is the appeal of getting a hard top? I've seen a few threads in various forums asserting that it isn't really good to let your top completely soak in rain especially heavy downpour so I get that part. I also know its not good to put the top down right after it has rained and is wet as it will get mouldy. After a big rain you could remove the hard top and be able to drive with the top down right away since it was already down. So two reasons there I guess?
But I've also heard you don't want to leave the top down all the time for extended periods of time (as you would cause it to crease/wrinkle permanently and break down) which would making using the hardtop all the time a bit of an dicey business for the long run (kind of making winter use a no go right?). Anything I've missed in my thought process on this one? |
