03-18-2018, 09:16 PM | #1 |
Rep 1,483
What can be wrong with one of my headlights -SOLVED
Ok so I'm puzzled and looking for some input here. My passenger side headlight is not working and I've try the following with no luck;
Open to suggestions on what I should try next. I was going to see if the light is getting power tomorrow but have to find the wiring diagram for the light first. Thanks
2007 #1432 ///M Coupe Silver Gray - KW V3 Coilovers - AFE Intake - Strong-Strut Brace - Status Grupee Headers - Super Sprint Race Exhaust & Xpipe - 19" Avant Garde M359 - Stoptech 380 6 pot BBK - EPIC Motorsports Tuning ////////////2009 328xi M-Tech E91 manual 6spd
- Instagram ->@e91kiter Last edited by Cyclops; 03-20-2018 at 04:12 PM.. |
03-18-2018, 10:12 PM | #3 |
Rep 2,547
I assume you swapped the igniter as well, even though you didn't mention it. Yes, you're right, the next step is to use a schematic and make sure power is getting to the ballast.
03-18-2018, 10:38 PM | #4 | ||
Rep 1,483
01 Bulb Xenon light D2-S 35W 02 CONTROL UNIT XENON LIGHT 03 Ignition element Xenon-light 04 STICK-ON LABEL XENON-LIGHT 05 Fixing clamp, Xenon cable
- Instagram ->@e91kiter Last edited by Cyclops; 03-18-2018 at 10:45 PM.. |
03-19-2018, 03:12 PM | #5 |
Rep 305
If you've already changed out the bulb and swapped the ballast (#3 in the figure), it's probably the control unit.
You'll need to remove the headlight assembly (it bolts to the bottom of the assembly) which requires removal of the bumper cover.
2006 Z4 coupe - with HOMELINK!
1966 Mustang GT fastback (too many mods to list) 2015 335i GT 2014 981 Cayman S manual |
03-19-2018, 07:16 PM | #6 |
Rep 2,547
check the control unit connector
I've done many dual angel eye retrofits for people and several said they had intermittent problems with their Xenon turning on and sometimes not turn on at all before sending me their headlights. What I have found is that the seal between the ballast (control unit) connector and headlight connector had failed and let water in. The pins were corroded. I cleaned the pins and sockets, used some contact cleaner and reassembled with RTV to get a good seal and the headlight worked consistently. I few people had purchased a new control unit and sent it with the headlight, but I never had to replace one since it was always the connector at fault. I'm not saying your control unit is has not failed, but check the connector where it plugs onto the headlight. Since the connector sits horizontal, water can rest in there if the seal is compromised.
03-19-2018, 09:23 PM | #7 | |
Rep 1,483
- Instagram ->@e91kiter |
03-20-2018, 12:18 PM | #8 |
1821
Rep 5,337
I feel bad in referencing your user name...Cyclops.
03-20-2018, 03:02 PM | #10 |
Rep 1,795
Drives: E86 3.0si
Garage List '55 Ford F100 [0.00]
'08 Z4 3.0SI [8.50] '66 Triumph TR4A [0.00] '85 Corvette [0.00] '64 Corvette [0.00] '68 Triumph GT6 [0.00] '19 VW Golf "R ... [0.00] |
03-20-2018, 04:03 PM | #11 |
Rep 1,483
Well boys don't feel bad any longer, got both eyes back today. Picked up a new control unit and it fired up on first flick of the switch, now I just got make it all look pretty and to put it back together.
Just as an FYI if you do experience the same issue, this particular control unit was used across many different car brands like Mercedes, Audi, Jag, Land Rover, Saab and even on a Chrysler and a Ford so if you're in a pinch you could always cross shop. I was able to find one local but it was purchase from here on ebay It's not an OEM unit, but for $50 we'll see how long it last.
3798j11413.50 |
03-20-2018, 07:40 PM | #12 |
Rep 156
The water is leaking into the light housing thru the black plastic rear cover. The cover itself is ok, it's the rubber gasket which is shot. If you drive in the rain or, actually simply wash the car and later notice the light housing fogging from the inside....well, the gasket is gone and your getting water seeping into the housing....which sort of explains what happen with your car.
BMW only sells the Gasket with the rear housing as a combo for somewhere near $38.00---$40.00. You could try a non-curing silicon gel of some sort. I've read other postings about your problem on other forums. I know this because it's happening to my car as well and getting two new rear covers is on my list of things to do this spring. |
03-21-2018, 01:39 PM | #13 | |
Rep 1,483
- Instagram ->@e91kiter Last edited by Cyclops; 03-21-2018 at 02:38 PM.. |
03-21-2018, 02:12 PM | #14 |
Rep 4,057
I think you jinxed yourself when you chose your username for this forum. Glad to hear that you've got if figured out though!
Huz-Z
