04-19-2018, 10:00 AM | #1 |
Rep 11
Oil filter brand #
I'm new to the Z4 and want to make sure I keep her running as long as I can. Has 30k and just got a 2003 2.5i. I'm going with mobil 1 for my oil but want to know which filter is best. Ive heard of MANN and MAHLE. I'm going to order online but my question is, what part number do i need for my specific engine (M54?). I know for MAHLE Original OX 154/1D will fit my car but does anyone know for MANN? Or does anyone have an suggestions/experience?
I use forums for my cars a lot and know this is a 'newb' question so sorry in advance. Also i plan on doing a drain and fill, not a vacuum since i want all the oil out. Thanks |
04-19-2018, 11:02 AM | #2 | |
Rep 870
Drives: 2006 BMW Z4M Roadster
Amazon has them: http://a.co/415QwWA Salty
Thormx3310.00 |
04-19-2018, 11:06 AM | #3 |
Rep 870
I don't want to start an oil discussion, but just throwing it out there that many have moved away from Mobil 1 in the M54 engine. Castrol 0W40 *Euro* formula is used quite a bit now, and for higher mileage M54's, Shell Rotella T6 has a fast growing following in the E46 community.
Aux Port|LED Interior|LED Strip Trunk|Underseat First Aid Box|Stubby Antenna|Intravee II|BMW Oil Change Kit|Top Down Side Panels|Vibra Technics Engine Mounts|Rogue Trans Mounts|Engine Mount Bolts Upgrade|RS Windblocker|Euro Front Plate|M5 Illum Shift Knob|Supersprint Powerloop Exhaust|Gruppe-M Intake|RPI Scoop|Black Grills|19x8.5 ET35 F 19x9.5 ET22 R Sportline 8s PSS| Besian Vanos|CDV Delete Last edited by SaltyNC; 04-19-2018 at 11:54 AM.. |
04-19-2018, 11:33 AM | #4 |
Rep 167
Drives: 2003 Z4 3.0i, Black Saphire
Oil:
You are going to get lots of different opinions on this, but the general consensus is LL-01 spec'd oil. The two best are: - Castrol Edge 0W-40 A3/B4. - Mobil 1 0W-40. BMW's OCI is also 15000 miles; you can forget about that -- it was a cost savings measure for BMW's bottom line. Change your at oil at 5000-7500mi intervals. Drive hard? Change sooner. Drive like a granny? Extend that interval. In reality as long as you are using a full synthetic of the appropriate weight, and changing oil & filter often, then it doesn't matter a whole lot. Filter: Mahle: MAH-OX1541DECO. Mann: HU 925/4 X. The Mahle filters are made in Austria and (supposedly) have more pleats. The Mann filter is made in Mexico. I don't have any evidence to say which is filtering better, but I use the Mahle filters. |
04-19-2018, 11:55 AM | #5 |
Rep 870
Thromx, I misspoke earlier on the weight of the Castrol. It is the 0W40 Euro that RevsPlease listed. I edited my original post to reflect that.
04-20-2018, 12:56 AM | #7 |
636
Rep 3,124
Isn't Mahle the OEM manufacturer?
Same filter, just different stamping, and you're not paying a steep mark-up for it to say "Genuine BMW". To quote an exchange in another thread: "Have you had any problems with the Mahle parts?" "Nope. Mine work just fine."
04-20-2018, 11:13 AM | #9 | |
Rep 167
I think there is also a Pennzoil oil out there that is LL-01 and ready available. |
04-20-2018, 11:23 AM | #10 |
Rep 167
Mahle is the BMW OEM for the filter, yes. They're the same price as the Mann and I feel the quality is little higher so I stick with them. Nothing wrong with Mann though; they work just fine.
04-20-2018, 11:45 AM | #11 | |
Rep 2,867
Drives: Anything
As noted above, Mann is also an OEM for BMW in the M54 engine. I use Mahle for the S54 and Mann for the M54 because that's how BMW have equipped my cars that way. |
04-20-2018, 07:46 PM | #12 | |
Rep 758
Top Down 365
04-21-2018, 07:00 PM | #13 |
Rep 11
Thank you all for your input and clarification. This seems like a great forum. I've searched and found many different weights and brands that are the said to be to "correct". Looks like ill be going with the Castrol 0W40 Euro. Id like to go with a better filter since its not much price difference which sounds like Mahle. Plus I usually go on the safe side and change it early since oil is not too expensive.
Other question is the process of the oil change. All my cars I've just drained from the plug. But I hear other opinions about using a vac? One way better than the other? Also read somewhere about soaking the filter/housing when installing the filter? Thanks again for everyone's help. |
04-21-2018, 09:49 PM | #14 | |
636
Rep 3,124
It's said to be optional, and I didn't do it on my first change. Made a hellish racket for the first 10-15 seconds after starting.
04-23-2018, 04:27 PM | #16 | |
Rep 167
