      06-30-2015, 12:49 AM   #1
jdoublehcubed
Mechanical Engineer
Drives: 2006 Z4MR, Imola Red
Center Jack Pad Adapter
I'm thinking about having some aluminum jack pad adapters made for the front center jack pad, and I was wondering if anyone would be interested in a group buy.
Whenever I jack up the front of the car, I'm nervous that my floor jack's lifting cup will accidently contact the aluminum stress plate and potentially damage it. This jack pad is designed to (1) automatically center your floor jack's lifting cup on the jack pad, using the hole in the center, and (2) raise the contact point up out of the lifting cup, so that the lifting cup's edge can't contact the stress plate.
I use FirstCut machine shop at work to order small quantities of machines parts like this. My plan is to 3D print it first to double check the size, then do a single order of adapters machined out of 6061-T651 and bead blasted. There are significant discounts for higher quantities. I had FirstCut quote the part for me. Here is the unit price at each quantity (includes $5 each for me to ship them out in USPS flat rate envelopes):
$60 each Quantity 5
$40 each Quantity 10
$33 each Quantity 15
$31 each Quantity 20 or higher
A screen shot of the CAD is attached.
Please post below if you're interested, and at what price you would be in. The lead time from First Cut is less than a week, so if we decide to do this everyone should have the parts in hand in no more than 3 weeks from the day I submit the order.
-----Interest List-----
1. JdoubleHcubed
2. Nate4641 (?)
3. itdnwiwbp (at 15)
4. Barryb97
5. Reborn_ (?)
6. Patrick Gent (at 10)
7. dschultz (at 10)
8. arsonism (at 10)
9. dalecan (at 10)
      06-30-2015, 08:16 AM   #2
Nate4641
Nate4641's Avatar
Drives: '07 M Roadster
Sounds like a good idea. I'd be more committed after seeing the 3d print on the car.
      06-30-2015, 09:11 AM   #3
itdnwiwbp
Drives: 330iZHP
I'd be interested if we get 15+ people.
      06-30-2015, 11:42 AM   #4
Reborn_
Drives: 2007 BMW Z4MC
You are missing a fillet where the nipple meets the main body. Interested to see the 3D print prototype on the car.
      06-30-2015, 12:15 PM   #5
jdoublehcubed
Mechanical Engineer
You guys understand that this is an adapter for your jack, not something that gets permanently installed, right?
      06-30-2015, 12:50 PM   #6
itdnwiwbp
Drives: 330iZHP
Understood. What is the diameter of the base?
      06-30-2015, 07:47 PM   #7
jdoublehcubed
Mechanical Engineer
its 2.75" ish. i have to check the model when i get home
      07-02-2015, 01:10 AM   #8
jdoublehcubed
Mechanical Engineer
Just checked. 2.75" exactly at the bottom.
Its being 3D printed tomorrow, I'll have the prototype on Monday to check the fit.
      07-02-2015, 09:06 AM   #9
itdnwiwbp
Drives: 330iZHP
Great. Thanks. Just wanted to make sure it would fit atop both of my jacks.
      07-02-2015, 12:03 PM   #10
jdoublehcubed
Mechanical Engineer
No problem.
There's also a relief on the bottom to clear anything sticking up out of the jack cup. I know the Harbor Freight jacks have a big protruding rivet head-sort of thing in the middle of the cup.
      07-02-2015, 01:34 PM   #11
Barryb97
Drives: 2006 M coupe
I'm in.
      07-02-2015, 08:23 PM   #12
wasupdu
wasupdu's Avatar
Drives: Z4 3.0, CLS63 AMG
Sorry, I guess I'm not following. I've lifted my Z4 on all 4 corners countless times with a low profile jack and I've never needed something like this. What am I missing?
2005 BMW Z4 Roadster 3.0 - Black Sapphire with Red Extended Leather / NAV / Premium & Sport Pkgs / 19" wheels / M steering wheel / Xenon
2013 Mercedes CLS63 AMG
      07-02-2015, 08:42 PM   #13
jdoublehcubed
Mechanical Engineer
On the M there is an additional jack point at the front, just behind the plastic skid plate. If you aren't careful, you can reach just past it with your jack and hit the metal stress plate. This jack pad adapter is for use with that point.
I don't think the non Ms have a jack point there, can anyone confirm?
      07-03-2015, 03:32 PM   #14
elerner61
elerner61's Avatar
157
Drives: '07 Z4M Roadster
What are the cons of using a hockey puck instead of this?
      07-03-2015, 11:56 PM   #15
Vanne
Down Under!!
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
if your car is being lifted, you can't play ice hockey?
Powered by
      07-04-2015, 01:35 AM   #16
StickMon
StickMon's Avatar
Drives: 2006 MR
I went to a sporting goods super store here in SoCal that sells everything from Lacrosse sticks to fishing worms.
When I asked if they had hockey pucks they looked at me like I was speaking Latin.
      07-04-2015, 02:08 AM   #17
GomboRombo
Roadie B4 Roady
GomboRombo's Avatar
Drives: Z4 M Roadster
Got my pucks at Amazon, 4 for $10. I use them on the front and rear center jack points.
Remus, ZHP, Stubby, H&R Coilovers
      07-04-2015, 02:32 AM   #18
jdoublehcubed
Mechanical Engineer
Provided you line it up just right, a hockey puck will do exactly the same thing. The risk is that you line it up slightly back of the center of the jack point, and dimple the stress plate. Big risk? Not really.
I use these for the 4 corner jack pads
http://www.amazon.com/BMW-128i-E46-3...N2Q177HZZ3QCC6
they're awesome, because when the raised up boss sticks into the jack pad, you know the jack is lined up perfectly and isn't going to slip forwards or backwards. I love having them when I'm jacking at the corners, so I designed this center pad adapter to give me the same convenience at the center point.
if you have a lathe, you might be able to mount a hockey puck in a 3 jaw chuck and make a center pad adapter exactly like the one I designed. I've never tried to cut hard rubber on a lathe, not sure if it would work or not. if I had a lathe I would definitely try it though.
      07-04-2015, 02:33 AM   #19
jdoublehcubed
Mechanical Engineer
anyone else in?
      07-05-2015, 01:31 AM   #20
Patrick Gent
Drives: 2007 M Coupe
If you get to 10 I am in
Pat Gent
954-249-3246
      07-06-2015, 01:14 AM   #21
dschultz
dschultz's Avatar
26
Drives: 07 Z4MC
I'm in at 10.
I'd love to see something similar (perhaps rubber or delrin?) for the rear jack point. Perhaps a block with holes that could be press-fitted onto the bolt heads then just slide the jack under it.
      07-06-2015, 09:06 AM   #22
Nate4641
Nate4641's Avatar
I did a write up to make jack pad adapters out of hockey pucks a little while ago.
http://www.zpost.com/forums/showthread.php?t=983883
If you look at the last few photos you'll see cutting the rubber makes a pretty big mess. If someone did this on a lathe maybe some cooling fluid would help, but I think it would still be messy.
