01-12-2010, 09:00 AM | #1 |
Rep 1,224
Do I Have a Problem: Oil Level Sensor?
07 3.0Si with 15,000 miles on the clock with the electronic oil level sensor; no apparent oil consumption problems. Had a dealer oil change for annual low mileage service about 3 months and 2000 miles ago. As a habit I always check oil level each time I use the car. I realize that with someone else performing the oil change, the actual oil level (a little over/exact/a little under) is unknown due to the characteristics of the electronic sensor. I did get a "full" readout after the oil change and for the last 2000 miles since.
On the way up to participate in the Tour de Orange on New Years Day (great event) the oil level readout indicated one increment low, so on my return I added 1/4 liter of 5-30 BMW oil. My expectation was that the readout should now indicate the level at full; the readout still indicates one increment low. Do I add more oil? Another 1/4 liter, less, more? Is this an idiosyncrasy of the sensor? Is the sensor not reading accurately? Any thoughts are appreciated. TIA
01-12-2010, 09:02 AM | #2 |
Rep 1,337
This is one reason I hate the electronic sensor. If it reads a quart low after using the car for a full day, then I would add half a quart and see what happens.
If everything seems under control, then you aren't going fast enough"
01-12-2010, 09:09 AM | #3 |
Rep 316
Or you could take it to the dealership for their high-tech oil measurement procedure. They dump out your oil, measure it, then pour the dirty oil right back in your car...out of the same container they had used for this procedure hundreds of times already. So you get your own dirty oil back, plus bits and particles of everyone else's. Cool! Gotta love BMW for fixing things that were never an issue.
01-12-2010, 11:46 AM | #4 | |
Rep 615
I have the same year and model as you do and I just looked in the owner's manual to confirm and it does not provide for amounts that your oil is low. According to the readout, the message can be one of the following: 1. Oil level OK 2. Oil level being checked 3. Oil level at minimum level, put one quart in. 4. Oil level too high 5. Oil level sensor defective. Based on the manual, there are no provisions for 1/4 quart low, 1/2 quart low, etc. As long as you get the "OK" sign, I'd leave it alone. I certainly don't want my oil removed and then re-inserted back into my car.
01-12-2010, 01:00 PM | #5 | |
Rep 1,224
My primary concern is not being down 1/4 quart but having the sensor indicate 1/4 quart down and not showing any change after adding 1/4 quart.
01-12-2010, 02:17 PM | #6 | |
Rep 615
01-13-2010, 09:15 AM | #7 |
Rep 1,224
Additional Information and Explanation.
Originally Posted by bten If it does not indicate overfill, and still reads "OK", I would just leave it alone. I woud drive it for a day or so and check it again. It has been my experience that the sensor does not immediately react to a change. I had an overfill issue, and had them take out the oil and start over. It still said overfill, but the service guy told me to drive it for a couple of days, and the sensor would reset. He was correct. Thanks for the post, the sensor does appear to have a response lag based on my additional developments. To recap: Return home from Tour de Orange drive with readout showing one division low, add 1/4 quart, car sits for several days. Drive to and from work, each way about 30 min drive time, sensor still reads one division low each way. Drive in to work today and sensor reads full. It appears that this is a quirk/aspect of the oil pressure monitoring design. Possibly a long interval average to counter short interval variations from oil temp, cornering, road incline...? Thanks again for the post and for contributing to the forum.
