01-04-2010, 06:02 PM | #1 |
Rep 647
Airbag swap between M and non M Z4?
I want to know if I can use an airbag that was removed from M Z4 in my 3.0i (which is a non M). Am I going to have the airbag lights or any warning lights on, because of using the M airbag in 3.0i?
Thanks, Last edited by BU Z4; 01-04-2010 at 07:02 PM.. |
01-04-2010, 07:13 PM | #2 |
Rep 237
Drives: 2003 Z4 3.0i, 2033 X5
I think that they are interchangeable. I swapped my regular Z4 steering wheel for an M steering wheel and the airbag fit perfectly. You should not have a problem.
01-04-2010, 07:16 PM | #3 |
Rep 647
I know that the airbag will fit in the steering wheel, I want to find out if the 3.0i will recognize the M airbag or not.
01-04-2010, 07:47 PM | #4 |
Rep 615
No, the parts are identical and there should be no issues. However, it is imperative that you remove the negative cable from your battery for at least 15 minutes before you do the swap. In addition to assuring that it doesn't go off in the process of the swap, it will eliminate any chance of an airbag light coming on when you start up. It is a simple process that takes very little time. Good luck.
Retired--2007 Z4 M Coupe (Imola Red/Black, Premium Pkg, Heated Seats, XM, Bimmian stubby antenna, CDV delete, Apex EC-7--Anthracite, Goodyear F1 Asymetric 2. Last edited by mhughett; 01-05-2010 at 02:17 PM.. |
01-05-2010, 01:54 PM | #5 |
Rep 1,034
http://www.realoem.com/bmw/partxref.do?part=32306782206 same part, all model Z4's
