      02-16-2017, 11:03 AM   #1
Cyclops
Cyclops's Avatar
FS: 4 x 87mm Carbon Tips
USD 150.00
I have 4 carbon tips that I was going to use on my SuperSprint mufflers but they are just too big so they wont work without butchering them up.
ID=87mm
OD=91mm
longest length=121mm (top)
Shortest length=87mm (bottom)
$150 USD shipped in Canada and Continental USA.
- Instagram ->@e91kiter
      02-17-2017, 09:06 AM   #2
3GFX
3GFX's Avatar
Drives: 2003 BMW Z4 3.0i
Shame it didn't work out, GLWS!
      02-17-2017, 10:28 AM   #3
XMetal
XMetal's Avatar
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
Just curious, how would someone attach these to their existing tips?
      02-17-2017, 10:53 AM   #4
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
I would cut small slots (2) and feed a hose clamp through.
      02-17-2017, 11:17 AM   #5
3GFX
3GFX's Avatar
The other option would be to drill a hole through both the carbon and exhaust and screw/bolt in.
      02-17-2017, 01:38 PM   #6
Cyclops
Cyclops's Avatar
Well the plan was to drill 3 mounting holes 3/4 towards the back of the tips. Put a bolt in and proportionally space out (centre) the carbon tip to the steel tip using either some nuts or washers and use a final nut inside the steel tip to hold it firmly in place. You could also just rivet in place instead of using a bold. The problem for me is that the supersprint tips are too close together and these carbon tips too large which means I'd need to slice the carbon tip in 2 spots to make this work like below. It's really too bad because these really look great.
      02-17-2017, 03:54 PM   #7
XMetal
XMetal's Avatar
2018 Audi S3  [0.00]
2004 X5  [8.50]
Thanks for the drawings. Looks like my Eisenmann tips are very close together as well
      02-17-2017, 08:19 PM   #8
NavZ
South Africa
Drives: '09 E86 Z4M Coupe
Might be a dumb q but will this fit on the OEM exhaust?
      02-18-2017, 08:42 AM   #9
savarin335
Drives: 2008 M Coupe
Will these fit over the Oem tips? If so, I'm interested and local.
      02-18-2017, 07:09 PM   #10
Cyclops
Cyclops's Avatar
Not sure
      03-02-2017, 08:15 PM   #11
Cyclops
Cyclops's Avatar
Bump
      03-25-2017, 08:20 PM   #12
Cyclops
Cyclops's Avatar
Bump
