      09-11-2016, 03:58 PM   #1
mihajlo
Drives: Gray
PFC Brake Pads: 08, 06, Z Rated
Performance Friction (PFC) Brake Pads
PFC-08:
Front: 6 mm
Rear: 5 mm
PFC-06:
Front: 5 - 6 mm (slight difference between in and outboard pads)
Z-Rated:
Front: 6 mm
Rear (Set 1): 7 mm
Rear (Set 2): 6 mm
All pads used on Z4 M Coupe with stock calipers and rotors.
I believe the original thickness for the Z-Rated is 17 mm and for the 08.06 is 20 mm. But this is data I gathered from the internet and I never actually measured the original size when the pads were
Will also include a set of used rear rotors.
      03-26-2017, 12:51 PM   #2
mihajlo
Drives: Gray
The actual price is FREE - I couldn't make the update in the listed price area.
Only catch is you have to pick them up in San Diego, 92103.
      03-27-2017, 04:18 PM   #3
Beedub
wow!! awesome member ALERT!!!
