02-14-2012, 04:45 PM | #1 |
Rep 11
Aftermarket PDC
Here is a short story of my latest mod.
I bought this Cobra set from thurgo.co.uk. I painted them to match the cars paint. I jacked up the car. Remove rivets, 3 each side. And then 5 nuts from the bottom. Disconnect licence plate lights. Bumper removed. Dirty exhaust pipes. Good chance to clean them. You will find marks behind the bumper. My little DeWALT is handy. Drill from inside bumper with 3mm. I used a 3mm and then 17mm drills bits. Then 17mm from outside. Here is what it should look. Attach wiring etc. Put everything back in reverse order. Done! Here is link for bigger picture. Last edited by kinkkujuusto; 04-05-2013 at 09:49 AM.. |
02-14-2012, 06:02 PM | #4 |
Rep 1,772
Drives: 2007 Z4M Coupe
can you elaborate a bit more on bumper removal? anything else other than removing the rivets and bolts?
02-14-2012, 06:11 PM | #5 |
Rep 11
02-14-2012, 06:39 PM | #7 |
Rep 1,663
Excellent post, this is one mod I've been interested in.
How does it work? is it just that you install the box in the cabin and it beeps when it's close to things? Any pics of that part of the installation?
02-14-2012, 09:04 PM | #8 |
Rep 4,128
Drives: M235i & G30 540i
Beautiful Mod!
Lack of money is not the problem. It is merely a symptom of what's going on inside of you! - T Harv Eker
Follow me on Insta https://www.instagram.com/bmwm_life_/ https://www.instagram.com/autogiftua/ https://www.instagram.com/phoenixbmwlife/ |
02-15-2012, 12:11 AM | #9 | |
Rep 11
No pics for the installation, its very simple. Just plug all wires to main unit and then take +12V from reversing light. |
02-17-2012, 11:59 AM | #10 |
The Wrapgician
47
Rep 354
Drives: z4si
Would you kindly to show the specific model of PDC that you bought? I'm interested to this DIY too
02-17-2012, 12:14 PM | #11 | |
Rep 11
02-17-2012, 02:40 PM | #12 |
Rep 1,855
Looks great, but where does the wiring connect to? Head unit?
02-17-2012, 04:15 PM | #13 |
Rep 11
03-21-2012, 01:48 PM | #14 |
Rep 296
Can you extend the wires for two sensors and run them to the front? Then you can know your about to curb your splitter lol, and still know about things behind you.
03-21-2012, 03:59 PM | #15 |
Rep 2,866
Even if you can extend the wires, the sensors won't get activated unless you have it in reverse...and when do you drive your splitter into the curb when you're in reverse
03-21-2012, 06:55 PM | #16 |
Rep 1,530
Maybe a front mounted camera so you can see if you're gonna hit the curb would be a better solution.
03-21-2012, 09:54 PM | #17 |
Rep 421
PDC
In 2007, I researched the PDC ready to go using BMW set up and sensors. Part guy said sensors don't last.
I decided to do a BMW camera set up front and back with aftermarket cameras. BMW wouldn't let you purchase the cameras. I like the cameras because I can see the curbs front and back. I have it height in the right place to show front and back from one foot from the curb. Cameras shows what I did in Bimmerfest: http://www.bimmerfest.com/forums/sho...d.php?t=194687 You can get thirteen sheets of PDC installation instructions from a BMW EPA disc. Last one ended 09/2003. Maybe you can get it from BMW. If interested, I have three EPA of them new and not copied. $25. shipped USA. . . . . Last edited by Ron Stygar; 03-21-2012 at 10:56 PM.. |
03-22-2012, 08:49 AM | #18 |
Rep 452
Hey, that's a monster drain cover in your garage, kinkkujuusto. I'd want to make sure I never left the top of that off!
