12-30-2008, 05:08 PM | #1 |
Rep 37
cleaning keys?
so i lost my key in the snow last week.. a friend just called me saying he found it, but im scared that it wont work.
is there anything i should do before trying it out? dry it off? that kinda stuff? help me out! i dont wanna shell out another $270 for another key thanks! |
12-30-2008, 05:17 PM | #2 | |
Bad Lieutenant
232
Rep 3,517
12-30-2008, 07:33 PM | #3 | |
Rep 615
Drives: 2017 G30 540i M Sport
Garage List 2002 BMW Z3 Roadster [0.00]
2007 BMW 335i Coupe [0.00] 2012 BMW 335i Sedan [0.00] 2006 BMW M Roadster [0.00] 2017 BMW 540i [0.00] 2015 BMW 428 Gran C ... [0.00] |
Mine G30 540i M Sport Hers F36 440i Gran Coupe |
12-31-2008, 08:31 AM | #5 |
Rep 112
Try it before doing anything - in all likelyhood it will work. If you try drying it with heat, you may damage something inside that wasn't damaged before. At most, open it and let it air dry.
GT |
12-31-2008, 08:39 AM | #6 |
Imola Lover
26
Rep 749
If you're really concerned, put it in a jar and pack rice around it and seal the lid. The rice will draw out any moisture.
01-02-2009, 05:53 PM | #7 |
Rep 746
Drives: 2009 Honda Civic Si
WADR, Our keys are sealed, they will never need a battery because they charge while in the ignition of the car while the car is running, If you open the key, It will not work again. Saw it done on an E39 M5, the guy had to tape the 3 parts of the key together so he did not loose one of them.
Instructions that came with my dell computer said that if it gets wet, remove all parts and let it set at room temperature with a fan blowing on it for atleast 24 hours. I would assume the same would apply here except for the fact that you cant remove anything from the key, I would let it set at room temperature for a few hours with a fan blowing on it and then try it. Good luck!
Johnathan
03' 2.5i Maldives Blue Roadster - SOLD 09' 2.0 Polished Metal Metallic Honda Civic Si - Current |
01-02-2009, 05:57 PM | #8 |
Bad Lieutenant
232
Rep 3,517
Low heat around 100 degrees won't hurt, that's just above body temp.
01-04-2009, 01:43 PM | #9 | |
49
Rep 397
I myself have had moisture on the key before, and no problems. Mind you it wasn't soaked, just a quick spray of water on it.
