      11-04-2009, 08:50 PM   #1
fatmatt0116
Hooligan
fatmatt0116's Avatar
Drives: 2014 Porsche Cayenne Turbo S
Suggestions for new rear tires
Was recently down at the town fair tire where they suggested Toyo Proxy 4s.....
tire rack suggests sumitomo htr z IIIs or yokohama advan sports.....
the sumitomos are very cheap ($155/tire)......
Your thoughts? I have stock wheels, don't track the car.....
2011 X5 5.0 Dinan - SOLD
2007 Imola Red Z4 M Coupe -SOLD
2004 Navy Blue BMW 325Ci
      11-04-2009, 09:10 PM   #2
The__J__Factor
The__J__Factor's Avatar
Australia
88
Drives: ///M Coupe
I just put on 275/35 Kumho SPT and found they are much much better then the Contis in grip levels and comfort levels. They were really cheap (for Australia) Im sure in the US they will be even cheaper.
If you dont track it im sure most tires will be fine. Most people will also suggest the Dirreza Star Specs.
135i N54 manual
MR-S with a 2zz swap and mods Sold
EVO X MR - Phantom Black - Ti Exhaust - Ti UICP - AQM Intake - Sold
Z4 M Coupe - H&R - RE Diablo - RPi - Tekarbon - Sold
      11-04-2009, 09:17 PM   #3
fatmatt0116
Hooligan
how did increasing the width and decreasing the height work out for you?
      11-04-2009, 11:01 PM   #4
The__J__Factor
Australia
88
Drives: ///M Coupe
Well i went with what everyone says works perfectly for stock rims on here.
245/40 fronts and 275/35 rears.
Looking at from the side i think overall its the same diameter which is why you drop down a profile size. The tires don't look like they are bulging off the rim or anything, everyone is right when they say this is what should have been mounted stock.
So really i couldn't be happier, everything has worked out well with no side effects (ie no rubbing, not looking weird ect)
135i N54 manual
      11-05-2009, 08:48 AM   #5
jonanator
Drives: '08 E93 335i, '06 Z4MC
I have ran the Sumitomo HTR Z III on my previous S2000 and was very, very pleased. Great grip on dry and wet pavement, and best of all, they have awesome treadlife. I will probably be getting a set for my M Coupe when the time comes.
      11-05-2009, 10:02 AM   #6
Z4MCJJ
Z4MCJJ's Avatar
Drives: Z4MC
If you don't plan on tracking your car, I doubt any tire will make much difference....on the street I almost never (read: never) get close to the limit decent street tires can handle. On the track, that's a different story.
      11-16-2009, 11:21 AM   #7
fatmatt0116
Hooligan
Got the Direzza Star Specs installed on the rear today.....they sure do look nice, and the 275/35 dimension does sit just about flush with the body now so thumbs up on look and fitment. I'll give some more feedback after a few thousand miles, so far so good.
      11-18-2009, 02:09 AM   #8
david_lm
Go Ducks!
david_lm's Avatar
Drives: 06 Z4Mr
I love my Nitto Invos
David . MY2006 IB Z4Mr
      01-30-2010, 03:06 PM   #9
Car_Girl
Car_Girl's Avatar
Drives: 2013 BMW X5 xDrive 5.0i
When you purchase your new tires, check the date code on the tire. It's located along the embossed letters and numbers inside an oval shaped symbol with 4 numbers. The first two numbers are the week the tires were manufactured and the last two numbers are the year. For example 2804 would mean the 28th week of 2004.
One forum member posted a youtube video of a story where a young man was killed in an accident caused by tire failure - the tires were purchased new and were only about 4 years old. After the investigation of his death completed, they had come to find out the tires were significantly older than the father had realized. There is no industry standard for tire age apparently, so this is a controversial topic but if you have a moment, go check out the youtube video in the forum post and you'll see for yourself that there's another safety factor people don't normally know about and it just never hurts to be knowledgeable about what you're buying.
Good luck!
