02-15-2017, 04:20 PM | #1 |
Rep 911
Options: Z4 nonM rear bumper modifications
Looking to add some more aggressiveness to the nonM z4 rear bumper (revised bumper). Any options out there? Found some diffusers which sit underneath, but not my style.
Was looking for something like this: But no longer made... Or this: But obviously for the E85/E86 version - nothing exists. Not looking to replace the bumper either. Thoughts?
Andre - 2J into a Z4 Coupe!
02-25-2017, 06:04 PM | #2 |
Rep 911
Screw it... found a way to adapt the E89 Z4 carbon fiber diffuser onto my 3.0si
Took a bit of elbow grease, but it fits
02-25-2017, 06:08 PM | #3 |
10834
Rep 4,890
Very nice! Do you have pictures of your dual exhaust setup? There arent any in your build topic. Curious if you went Y pipe from the mid of the car (so true dual muffler) or a breakout pipe to the right from the rear muffler.
02-25-2017, 06:39 PM | #4 |
Rep 685
I second this question. Guess this would fit on a 03 roadster too? Turned out great my friend.
02-25-2017, 07:13 PM | #5 |
Rep 911
Thanks. The diffuser follows the rear bumper curvature, but mounting it required some trick brackets hidden inside. I cut the bumper in minimal locations as well, didn't need much trimming.
As for the exhaust, I run a single muffler to the driver-side dual tips, and the external wastegate via a long tube to the driver side pipes. No pics on the build thread since this was an afterthought I'll have better pics sometime next week.
02-25-2017, 07:45 PM | #6 |
10834
Rep 4,890
Wastegate as seperate exhaust tip. Thats pretty original I must say.
02-26-2017, 02:46 PM | #8 |
Rep 911
02-26-2017, 03:28 PM | #10 |
Rep 911
Thanks! Had to shift the driver side muffler over about 2 inches further to the edge. This is because the stock E89 Z4 exhaust holes are further spaced apart.
02-26-2017, 03:36 PM | #11 |
Rep 911
