      12-12-2016, 03:14 AM   #1
zurus
Puerto Rico
49
Drives: IB M coupe
Functional hood vents
So i was looking at this thread on the m3 forum http://www.m3forum.net/m3forum/showthread.php?t=556687 and it caught my attention. I think these are a good option for people that want the benefit of a vented hood like the varis but don't want to spend thousands for it. With enough interest he can make them for the z4m. Let me know your opinion.
      12-12-2016, 11:39 AM   #2
Michael9218
Michael9218's Avatar
595
Drives: 2007 Z4 M Coupe
I'm just getting started on a track build and will need hood vents. I like these type of vents. Lots of flexibility and doesn't require a new hood. Our hoods are aluminum, so there is no benefit to a carbon hood.
My thoughts for these vents is to mount two inside the crease and two outside. Long narrow type. Maybe 4" x 10". I would also prefer to put them on the underside of the hood if I can do a clean job of cutting the holes. I think it would look good if I could flip them upside down so the long side of the slates are pointing up.
      12-12-2016, 12:08 PM   #3
zurus
Puerto Rico
49
Drives: IB M coupe
I agree with you, all he needs is somebody local in Illinois that can give him the car for measurements. I would but i am to far away.
      12-12-2016, 07:59 PM   #4
AriuSen
AriuSen's Avatar
Drives: Z4M Coupe
Honest opinion? Those vents are not good. I've seen in person and its too flimsy. In high speed the vents are shaking.
But don't worry. Trackspec autosport is already making one for us.....i just picked up my hood after a month there. Should be in production in January. Unfortunately he asked me to not share the project yet, but it will be something simile to this. He measures the location of the vents to reduce the most air inside. I had to measure my whole front for him to know the best place for them.
Instagram: ariusen26
Youtube: Track vids
      12-12-2016, 09:10 PM   #5
zurus
Puerto Rico
49
Drives: IB M coupe
Case closed then, any idea on pricing for those?
      01-01-2017, 04:49 PM   #6
wspohn
Drives: 2007 Z4MC
Never been a fan of vents although I've owned several cars that had them.
On many cars they do little for temperature, so it is only an appearance mod, in which case they are usually installed too far back because people think they look better that way, but are ironically in the high pressure are in front ot the windshield, often resulting in air flow going the wrong way, into the engine by rather than out.
They can also cause maintenance issues when the drip water onto engine bits resulting in water marking of engine bits and occasional shorting out of high tension bits.
I've owned Jensen Interceptors that had louvered hoods and those with unlouvered versions and both seemed to cool about the same.
      02-14-2017, 02:12 PM   #7
AriuSen
AriuSen's Avatar
Drives: Z4M Coupe
I just installed and tested at the track.
I can ask the owner to give a good discount for zpost members if we have enough interest.
It was good to see that temp wasnt going over 190F although it wasnt 100 degrees out there.
Will have the real real test in summer when I was getting really high temps.
      02-15-2017, 01:39 AM   #8
zurus
Puerto Rico
49
Drives: IB M coupe
Hell yeah man, i saw them on your IG. I'm excited to see what he comes up with on the rear diffuser.
      02-15-2017, 02:01 AM   #9
Vanne
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
Looks great, and best yet, it's functional.
      02-15-2017, 03:02 PM   #10
Beedub
that does look fantastic, how about some pics of the underside??
and some better detail shots with a decent camera if poss.
tis hood is a very rare item, its very expensive and very light weight as is..... to cut it... the item must be PERFECt.
i THINK the best solution is the carbon VRS unit and store the stocker away..... However this does look ACE.
      02-16-2017, 05:25 PM   #11
AriuSen
AriuSen's Avatar
Drives: Z4M Coupe
Here are some pictures I took. Its iphone crap camera. Sorry.
Here is also some testing that he did at willow springs. He said he tried in varios different cars, and all cars showed similar data.
As you can see, the vents for the z4m sits more towards the middle of the hood, because of where the radiator is positioned. The vents sits perfectly after the radiator.
There were some friends with e46 who had the vents too, and everybody said that the z4m looked the best so i was happy to hear that haha
      02-16-2017, 05:43 PM   #12
AriuSen
AriuSen's Avatar
Drives: Z4M Coupe
e46 vs z4m.
you can zoom in the other one to see the construciton
      02-17-2017, 06:50 AM   #13
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
Sweet !!!
      02-17-2017, 08:39 AM   #14
3GFX
3GFX's Avatar
Drives: 2003 BMW Z4 3.0i
Sub for awesome.
Would love to run these, but I occasionally drive in the rain. I like a clean engine bay
I also don't think I'm pushing that much heat
      02-17-2017, 10:33 AM   #15
longress
longress's Avatar
Drives: 2007 Z4M Coupe
I can appreciate the functionality but good looking is not a description that comes to mind with hood vents and to be honest (no disrespect intended) it looks like someone dropped a home HVAC unit on the hood. 😁
inTgr8r2425.50
      02-17-2017, 10:44 AM   #16
wspohn
Drives: 2007 Z4MC
Originally Posted by longress View Post
I can appreciate the functionality but good looking is not a description that comes to mind with hood vents and to be honest (no disrespect intended) it looks like someone dropped a home HVAC unit on the hood. ��
Yeah, I can't disagree about the looks, but they are properly located to be functional.
I effected the same sort of result on a race car I own by raising the back of the bonnet, but that only works if you aren't running a full windshield - try spacing up the rear of the BMW coupe bonnet and I think you'd find that air flows in from the high pressure area at the base of the windshield. Whether that would do any good depends on whether there are other exits for the ir that comes in, but either way, I can't see it as being better than the vents further forward.
I don't know what the rules of the tracks you guys run at might be, but one possible solution without butchering a nice and rare alloy bonnet, would be a fibreglass replica bonnet with vents cast in.
      02-17-2017, 10:48 AM   #17
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
On a pure stripped down track car or in hot regions where cooling is real concern, yeah, I get that its a great functional improvement.
Purely for Looks..... definitely not IMO
      02-23-2017, 12:33 AM   #18
crawlin
Drives: BMW Z4 M
Yea not a fan of how it looks and I would probably lose the center vent unless it was a straight track car and maybe not even then. It would be nice if they were integrated under the hood and were painted the body color to match so they didn't stick out so much. To me the Z4M isnt really a car that should have hood vents it just doesn't look good or at least I haven't seen somebody do it right yet. For function I guess you cant argue.
      02-23-2017, 09:14 AM   #19
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
I for one love the functionality of it, and I don't mind the look either. Form and function and this ticks both boxes in my book. Yeah if you've got a garage queen and your worried about the resale value, then sure, but then you won't be making any mods. Good on you Alex. Maybe next season I'll try this myself. and I have seen it done right, I just don't have the 220k yen required to invest in a hood atm.
Powered by
      03-11-2017, 11:24 AM   #20
Shutterspeed
Shutterspeed's Avatar
Drives: 2008 Z4 M Coupe
Part of me wants these for the hot and humid Louisiana summers during autox and light track days, i just wish i could find a cheap spare hood to cut into...
      03-11-2017, 11:34 AM   #21
wspohn
Drives: 2007 Z4MC
Too bad no one makes a fibreglass hood for these cars - then you could stick it on in summer, no matter how fugly it looks. Could probably speed up the process by drilling guide holes for each hood and avoid all the time alignment sometimes takes.
      03-11-2017, 11:38 AM   #22
XMetal
XMetal's Avatar
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
You can always find a regular hood from a Z4 from a junk yard to cut into. The vent cutout will offset the weight of the regular hood
