      03-07-2015, 04:56 PM   #1
DeutschRennfahrer
DeutschRennfahrer's Avatar
39
Drives: 2006 Z4 3.0i - Saphire Black
Removing the Resonators?
I'm considering an exhaust mod to remove the stock resonators and replace them with a magnaflow muffler. I want to make sure that I won't trigger any kind of check engine light by doing this. Can anyone confirm that removing the two resonators in the image below will not throw a light?
      03-07-2015, 05:13 PM   #2
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
Those look like cats. As long as there are no O2 sensors behind them (it looks like there aren't), you should be fine.
      03-07-2015, 07:53 PM   #3
seank
enthusiast
seank's Avatar
48
Those are your cats. The ones down stream at the X is your resonator.
It is good that you asked us first or you would have been screwed.
      03-07-2015, 08:06 PM   #4
DeutschRennfahrer
39
There wasn't anything plugged into them. No O2 sensor that I could see. I thought they were either resonators or secondary cats that wouldn't throw a code if removed. Am I wrong?
      03-07-2015, 10:31 PM   #5
PLCZ4MC
Proud E86M Owner
PLCZ4MC's Avatar
If your headers NA are same as M models that it wont affect you at all as long as you do not touch the headers.
      03-07-2015, 10:55 PM   #6
DeutschRennfahrer
39
Would it be possible to fit a Magnaflow muffler where the stock muffler currently sits? Most people seem to cut these two cats out and replace them with a Magnaflow.
I'm wondering if I can leave these cats alone and simply delete the resonator and replace the stock muffler with a Magnaflow. Want to make sure there is room.
      03-08-2015, 09:28 AM   #7
Steeler
Steeler's Avatar
2429
http://www.zpost.com/forums/showthre...ight=Angry+cop
This mod has been done many times
Don't mess with the cats.
      03-08-2015, 12:07 PM   #8
DeutschRennfahrer
39
This is the exact mod I want to do. I will read through the entire thread later, but just skimming it I didn't see any complaints from the owner about removing the secondary cats. Someone tell me why I shouldn't do this.
