08-27-2015, 11:14 AM | #1 |
Rep 39
Drives: 2005 Z-4 roadster
Dash Rattle
I have a dash rattle that drives me nuts. When I go over bumps or hit a pot hole I get a noise like two small brass cymbals and hitting each other. It seems to come from the instrument panel. I have read posts on struts and others but this seems like a new one. Who can help?
08-28-2015, 06:51 PM | #2 |
Rep 406
Tighten/retorque the strut races in the engine compartment. It costs nothing to do and likely will fix the problem. If it doesn't you've eliminated a potential cause ...
Sent from my smart phone...
08-28-2015, 08:55 PM | #3 |
Rep 39
Thanks I will try that.
09-02-2015, 04:32 PM | #4 |
Rep 39
09-02-2015, 10:39 PM | #5 |
Rep 406
Honestly can't think of anything else in dash area that would cause a sound. I would suggest you check your suspension and anything connected to the control arms. Worn bushings etc may be the cause. It also could be your struts are worn out ... So check the front springs to see if you have any issues there caused by bottoming out the struts...
09-04-2015, 12:16 PM | #7 |
Rep 39
09-04-2015, 12:17 PM | #8 | |
Rep 39
09-04-2015, 03:47 PM | #9 |
Rep 218
It's a torx screw
tilt the wheel down and fully out--look up at housing and see the single screw --remove it and pull towards you. You don't need to unplug the cluster, there's enough room and slack to shift it around and see if there is anything loose. |
09-05-2015, 12:20 PM | #10 |
Rep 39
Clean up behind the instrument panel of dust etc. found nothing that would rattle but found nice places to hide cash and pistol.
09-05-2015, 12:38 PM | #11 |
Rep 218
If you have some help, are you able to replicate the noise by having someone bounce the car with their weight?
Next thing to check, if you're sure it's coming from the dash, is to pull the radio and see if there's something back there.
/// LED Lighting /// Pedal Haus M aluminum pedals and heel plate /// BMW logo puddle lights /// CF wrapped console /// LeatherZ MK4 console storage, armrests, door pulls /// ZHP illuminated shift knob /// BMW under seat storage /// Soundplicity III /// Stubby Antenna /// Eventuri Intake /// Tekcarbon CF valve cover /// Stromung exhaust /// Rogue Engineering Transmission Mounts ///3rd brake light blinker
09-05-2015, 02:50 PM | #12 |
Rep 279
As I understand it, when strut bearings fail they make a noise similar to what you have described. Otherwise, i'd be checking for loose metal in the engine bay, or possibly a heat sheild somewhere.
09-05-2015, 03:42 PM | #13 | |
Rep 39
Pulled the vents and radio and all I found was dust and better places to hide a revolver when crossing state lines. |
Tags |
dash rattle |
