      09-29-2010, 08:07 PM   #265
crfine88
crfine88's Avatar
442
Drives: E86M
Originally Posted by ManoSpeed View Post
These wheels just take the car to a whole new level. I think this will be my first mod. Excellent thread.
I agree, they are beautiful wheels for sure.
Thanks for the comments in the thread
      09-29-2010, 08:10 PM   #266
crfine88
crfine88's Avatar
442
Drives: E86M
Originally Posted by mfanatic325 View Post
I took too quick a gander at your list, and saw "Black Girls" instead of Black Grills for item #6 on the mod list
Love the new signature man. Making me miss my TE's
      09-29-2010, 08:11 PM   #267
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
193
Drives: '01 911 Turbo
I personally like the TE's more than the G2's. But I'm biased. I have a TE/LE stable at home
      09-29-2010, 08:32 PM   #268
O-cha
O-cha's Avatar
218
Drives: Mcoupe
One day I'll put my SC back on, is the vt1 the non intercooled vortech one? I would meth it.
I want vt3 but there's no way in hell I'm going to rebuy the kit.
      09-29-2010, 10:33 PM   #269
Master Apex
Drives: '17 F80 M3 '07 Z4M '06 E60M5
#30
Specs:
Front wheels: 18x8.5 et 35
Rear wheels: 18x9.5 et 37 + 15mm spacer = to et22
Front tires: 245/40-18
Rear tires: 275/35-18
I truly enjoy and learn from reading this journal.
Thank You very much for taking the time to do this excellent write up.
Looking at your pics, ride height and setup, I am both impressed and puzzled on how your front tires (at ET35, with 245/40/18) don't rub the bumper liner.
My setup with the same KW CS set at 23-1/2" height (from bottom wheel to fender line), the front 245/40/18 ET38 rubbed slightly during transition from oval bank to flat surface. My rear setup with 275/35/18 ET25 has no issue.
So, my solution is to replace front with 245/35 and will be testing it on the track this weekend.
The 245/35/18 smaller diameter creates more spacing between the tires and liner therefore it doesn't look as "slammed".
Last edited by Master Apex; 09-30-2010 at 08:25 AM.. Reason: Clarify the front ride height setup
      09-29-2010, 11:11 PM   #270
O-cha
O-cha's Avatar
218
Drives: Mcoupe
I didn't have a problem with et 35 w/ 255s on the street, I only rubbed like that when I used the 255 Rcomps on et 30 (heavy braking force).
I don't see how the hell he fit an et 22 275/35, I tired that fitment and decided it couldn't;t even work stock (that's with starspecs though which are wider then normal 275s)
      10-01-2010, 03:26 PM   #271
crfine88
crfine88's Avatar
442
Drives: E86M
Originally Posted by O-cha View Post
... is the vt1 the non intercooled vortech one? I would meth it.
Yep, the vt1 is the non intercooled vortech one.
I am not familiar with what you mean by "meth it." I assume it relates to power?
      10-01-2010, 03:33 PM   #272
crfine88
crfine88's Avatar
442
Drives: E86M
Thank you for taking the time to read through and comment on the thread.
Your camber and caster settings will help with the front rubbing issue. I know from our previous conversations that you have been play with the camber adjustments. Have you tried adjusting you caster? I have mine pulled back toward the cabin, so as the suspension compresses the wheels is drawn away from the area you are rubbing. I have a color print out of my last alignment that I can post with all of my settings. I can post this next week when I am back in the office with a scanner.
      10-01-2010, 07:05 PM   #273
mfanatic325
///M-fanatic
Taiwan
193
He means methanol injection. Yup you're right, it has to do with power: http://forums.nasioc.com/forums/showthread.php?t=937176
      10-02-2010, 11:13 AM   #274
O-cha
O-cha's Avatar
218
Drives: Mcoupe
It means spraying atomized methanol into your intake piping under boost, it makes for an increase in effective octane, ESPECIALLY on a non intercooled car. ESS would have a hissy fit if they knew you were doing it though and I wouldn't actually recommend it unless done by someone who really knows what they are doing and can monitor your timing and knock-control to insure even distribution.
A vague guess that really has no accuracy would say you could get 10-30HP from it, possibly a bit more.
      10-02-2010, 12:52 PM   #275
johanness
Drives: 2008 Z4MC
why would ESS mind a water/meth kit? I thought it's essentially the safest and best single item one could run on a supercharged application (especially the vt1 being non-intercooled)?
It cools the intake charge, increases octane and steam cleans your internals keeping them virtually like new. We had one on virtually every Vortech system with the LX crowd. Is the ESS version that much different?
      10-02-2010, 03:22 PM   #276
O-cha
O-cha's Avatar
218
Drives: Mcoupe
They don't want people messing with their kit, plain and simple. Which is understandable, people start messing with things it makes diagnosing harder or they might make problems or break stuff.
Like lets say you had a misfire, you try to diagnose it with them and go through tons of tuff only to find out you're spraying too much methanol causing the misfire (it can happen).
But yea it's pretty safe.
      10-02-2010, 04:06 PM   #277
johanness
Drives: 2008 Z4MC
^^^ got it. Thx
      10-02-2010, 07:28 PM   #278
crfine88
crfine88's Avatar
442
Drives: E86M
Thanks for the explanation. It sounds very efficient. I wonder if ESS would consider adding this to their kits.
      10-02-2010, 09:30 PM   #279
Z4Murder
Z4Murder's Avatar
Drives: > speed limit
i think that'd be a great idea
2007 TiAg ///MCoupe
* Dinan strut bars * ZHP knob * RPI scoop * Ultimate Pedals * RE Diablo * 3.91 TMS gears * Apex PS7 * Eventuri intake* Nitto NT05 * TMS pullies * Zeck CDV * RE tranny mounts * Tekarbon * Mstache 2 *
'14 Jeep Grand Cherokee Overland Hemi... No more snow for the M!
      10-04-2010, 05:33 PM   #280
O-cha
O-cha's Avatar
218
Drives: Mcoupe
They are very much anti methanol from the brief talks I've had with them.
      10-04-2010, 10:00 PM   #281
Palantirion
Palantirion's Avatar
Drives: Z4 MC, M5, 540iT
*subscribed*
Great job on your car Chris!
      10-05-2010, 08:29 AM   #282
crfine88
crfine88's Avatar
442
Drives: E86M
Originally Posted by Palantirion View Post
*subscribed*
Thanks Earl
      10-05-2010, 08:53 AM   #283
O-cha
O-cha's Avatar
218
Drives: Mcoupe
*subscribed*
/hijack
Did they ever fix that issue where the car would just cut out at high speed and the ABS light would come on? I'm going ton reinstall the SC soon and was wondering because my car did it too.
      10-05-2010, 01:25 PM   #284
Palantirion
/hijack
-I think so, but I don't know so. Confused? I'll explain...The kit has exhibited two problems, both of which exist only in the context of hard track driving. One is overheating - if driven hard enough and somewhat dependent on the track as well. The other is a triggering of limp mode that seems related to engine heat. IE: The car will limp under certain rare, but repeatable, throttle loadings once the oil temp has gotten over 265F.
Since both situations need remedy the thought was to tackle the cooling system first. Bring the temps down and by extension the limp mode issue will go away. One customer replaced his thermostat and oil diverter with racing units and that fixed his problem. But I don't know yet if the tracks he drives on offer the same engine loading as the ones I drive on. I've installed Bimmerworld's replacement oil diverter, but not the cooler thermostat. From what I've been able to find out the BMW Motorsport thermostat doesn't flow more that the street version, so it wouldn't increase system efficiency. It just makes the engine start at a lower temperature, which in my case would only help for 1-2 laps.
ESS has a new oil cooler configuration that its testing out in another customer's MC. The new unit is slightly larger and is located behind the driver-side brake duct (which is mostly unused in our street cars). If the diverter valve doesn't cool things off enough I may go with the new cooler system. I am also considering fabricating an aluminum air guide for my existing oil cooler, so that its hot air exits below the radiator instead of straight into it.
      10-05-2010, 03:30 PM   #285
O-cha
O-cha's Avatar
218
Drives: Mcoupe
mine did it when the temperatures were not elevated, simply at high speeds.
      10-05-2010, 05:21 PM   #286
Palantirion
-That was an older problem and was fixed with a software update.
