10-20-2015, 10:39 AM | #1 |
Rep 904
Commuting with a lowered car
Do any of you commute in the city with a lowered Z4? Today I drove my Zed into Boston for the first time and kept bottoming out repeatedly. I'm on Eibachs/Konis. We have a long highway onramp that people normally do 50 on, but I was bottoming out going 30 on the uneven pavement from road repaving. I had a line of cars tailgating me, so I felt pressured to keep going at least 30 rather than slow down to 15-20mph. There was actually an A6 that was merging onto the ramp from another exit and I heard his tires squeel as he slammed on his brakes to avoid rear ending me. He must've been going at least 60. What do you guys do when you're going half the speed limit holding up traffic to slow down for speed bumps and such? Do you go 30 below the limit or just keep bottoming out to avoid causing road rage behind you?
As you can tell I'm a newbie driving on low cars. First time on a non-stock suspension. Can I do any damage going over these bumps at 50 mph? The bumper doesn't scrape or anything, it's just the shocks that bottom out and make a loud clunking noise that makes me grimace. I can drive over these just fine: It's these that make me grimace when I drove over them at 30mph: Last edited by Twixboy; 10-20-2015 at 10:54 AM.. |
10-20-2015, 10:58 AM | #2 |
salty cowboys fan
6211
Rep 3,425
Sounds like you're too low or maybe have something going on with the shocks. Did you DIY? Is the sound coming from the front or back? I'd check the rear shock mounts, and also make sure the bump stop/bumper were re-used from the OE hardware
If the problem is being too low, you might be able to find some evidence of rubbing on the tires. Edit - just saw the pics, sheesh I'd avoid that even in my SUV Last edited by yousefnjr; 10-20-2015 at 11:04 AM.. |
10-20-2015, 10:58 AM | #3 |
Commander
221
Rep 850
Drives: Z4MC/M5/640iX/M1000RR
Honestly if the roads are that bad I'd advise to stay away from driving it in those areas.
Ever since I put my coilovers on and dropped it I've had to retire my car from daily driving, I refuse to go anywhere near city centers. I will do the work commute when the weather is nice since I know the roads and they aren't bad but other than that trips to and from the track mostly.
E60 ///M5 - (6 Speed) Silverstone Metallic/Black F06 640iX - Tanzanite Blue/Amaro Brown K66 ///M1000RR - Competition |
10-20-2015, 11:18 AM | #4 | ||
Rep 904
I had Rogue Engineering RSMs installed and told the shop to replace any common wear items. Do the Koni yellows come with a bump stop that the shop might've installed instead of re-using OEM? Here's a list of what the shop replaced: Quote:
10-20-2015, 01:29 PM | #5 |
salty cowboys fan
6211
Rep 3,425
Not sure what comes with the Koni's, I can't remember off the top of my head if the dust boots cover the bump stops or not, you might have to take the wheel off to tell if they're there.
Also, consider swapping to non-RFT's if you haven't already. Roads like that aren't doing you any favors, and it could very well be that everything is installed but the stiffness is just too much. I feel like the clunking you're hearing means this isn't the case, but I dunno... That road looks pretty beat up. |
10-20-2015, 04:18 PM | #6 |
Get Some
226
Rep 759
Drives: 07 Z4 3.0si
I've always taken on speed bump, driveways, etc at an angle and slow, has worked out just fine...as far as when roads are getting milled...I stop turn around and search for an alternate road
10-21-2015, 11:38 AM | #7 |
Seasoned Novice
Rep 54
I was driving through downtown Dallas this morning on the way to work and was crossing an intersection where there are train tracks. I always go real slow over known rough spots and worry about getting rear-ended while doing so. Anyhow, this morning as I am going slow and bumping through the intersection an old lady in a Prius blows her horn behind me. LOL - old cow - horn blows ...
10-21-2015, 01:00 PM | #8 |
Rep 1,247
I assume bottoming out means you are dragging - not slamming into the bottom of your shocks - correct?
I went with the H&R and the Bilstein combo. While I love the ride and body roll, mine was a shade too low in the rear for me as well. I took the 5mm pads out and added in the 15mm pads and that raised it up just enough to allow me not to drag going into my garage and on my gravel drive. May help you? Also - can you look under and make sure you do not have anything hanging down? When I bought my car, the PO must have hit a decent sized rock at high speed and it wedged into the skid plate. I dug it out (did not hurt anything) and hammered the skid plate up and that got rid of a occasional drag I would get on the driveway. I never noticed it till I was under changing my oil and spotted it. May require you to get under to check. Probably not your issue, but worth a look next time you are under there. Those roads do look shit though.
10-21-2015, 05:34 PM | #9 |
Rep 182
+1 on both counts, New England roads are merciless on wheels and suspension parts
10-21-2015, 08:09 PM | #10 |
Rep 279
I feel your pain, I have about a 1.5 inch drop with the H&R springs i'm on and I know there are certain roads I just can't go on. While I love the way the car looks and sits on the road, I like to get lost up north. And I pucker up when I see an unfamiliar bump up ahead. I will be going back to stock this spring. All told, it's just not worth it for me.
10-21-2015, 08:39 PM | #11 |
Rep 1,692
Just park it at the train station and remove all of the angst about the roads.
I live 0.61 miles from work. I can walk in 13 minutes or ride my bike and get there in 3:40 if I ride slow. I don't want door dings or worse from bad drivers here in Orlando. Take the train because that road looks terrible, so save yourself the worry. |
10-22-2015, 12:03 AM | #12 |
636
Rep 3,124
The problem with public transport is it usually starts where you're not and goes where you don't wanna be.
10-23-2015, 07:08 AM | #13 |
Rep 904
Thanks for the replies everyone. Just to be clear, that road isn't the one I actually drove over but looks exactly the same. They are constantly milling down roads and the new pavement is often a couple inches higher. They usually put up a sign at the beginning of road work that says "Road Work - pass at your own risk". I think I've learned my lesson - I'll just take my truck into the city from now on even though it's a pain to park.
I stayed in a hotel the past 3 nights and when the valet pulled my Z4 up to the curb this morning I must say it looked really low after not seeing it for a while. Definitely much lower than any other car I saw driving around the city the past few days. |
10-23-2015, 07:09 AM | #14 |
Rep 904
10-24-2015, 04:49 AM | #15 |
Rep 1,134
Drives: '07 M Roadster
10-24-2015, 11:54 AM | #16 |
Rep 879
My z4 on coilovers is an absolute nightmare on jointed concrete roads and downtown Houston city streets. I quit daily driving the z4 because of the roads. You basically just recognize the bad areas / lanes / potholes and do your best to avoid the areas in the future
10-27-2015, 04:23 PM | #17 |
Rep 2,665
I am surprised at the number of people that lower their car or change the suspension to the point that their answer to the problem is to stop driving the car and/or take public transportation.
Maybe consider something more practical for where you live and what you want to deal with. Seems like a woman with really high heals that no longer wants to leave the house.
10-28-2015, 08:23 AM | #18 | |
Rep 904
10-29-2015, 09:29 AM | #20 | |
Rep 904
Sorry, couldn't resist. |
10-29-2015, 11:17 AM | #21 |
Rep 753
<rant>I don't get why people associate coilovers in general with cars lowered beyond the limits of practicality, or for that matter even optimal suspension geometry for best handling. If you take a sports car that already is compromised in terms of clearance from the factory and lower it beyond practical limits, you end up with a car you are afraid to drive. And this same car will actually not handle much better than stock on a track when driven at 8/10ths because the suspension geometry and/or spring rates are likely not optimal either.</rant>
To OP, your shocks are likely bottoming out and you are hitting the bump stops. This is most likely because your springs are not stiff enough for the much reduced travel on lowering springs. If you are on Koni Yellow adjustable shocks, you can try to increase the rebound damping and that will improve things a bit but the ride will start to get harsh pretty fast as well. If my theory is correct, you will still bottom out though less often. The next thing you may want to consider, if you like to drive your car and need to drive it, is getting a set of stiffer and taller springs. This will remove your clearance issue, your bottoming out issue and improve ride and handling. But you will not get approval from the stance crowd. |
10-29-2015, 11:35 AM | #22 |
636
Rep 3,124
Well, I will turn 55 next week, so yea, there's that, too.
