      04-01-2024, 11:33 PM   #1
DFW Tom
DFW Tom's Avatar
11
Drives: 2006 Z4 Roadster 3.0i
Rear Wheel Camber
I’ve got a 2006 e85 with the M sport package, just replaced the rear tires and went from 255 to 265 for a more aggressive stance. The tilt inward looks a little more pronounced now, is it an optical illusion? I love the wider tires and the cornering is insane with Michelin A/S 4’s, and everyone knows the ride is incredible compared to the run-flats. But should I adjust the camber to level them better?
      04-02-2024, 07:45 AM   #2
Michael9218
Michael9218's Avatar
595
Drives: 2007 Z4 M Coupe
No. If you’re concerned that they’re out of spec, have the car aligned.
DFW Tom11.00
      04-04-2024, 10:54 PM   #3
jwolf
Drives: 135i M-Sport MT N-55 / Z4 3.0i
The spec for negative camber is pretty aggressive for the Z4. The wider the tires, the more you see it. I think is does put more pressure on the RTAB (rear trailing arm bushings. If you do not know for sure those have been changed, it is time. The inside edge of the tire will wear very fast. keep an eye on it.
