02-29-2016, 11:12 PM | #1 |
635
Rep 3,124
Engine Mount Height
Questions have arisen about whose mounts are taller or shorter than whose, so let's have a look.
Don't want to find out that those new mounts you bought cause your PCV line to crash into your strut brace. Height Summary: Unloaded, off the car, on the bench: Stock: 67.4 mm after 30k miles Vibra Technics: 68.0 mm new BimmerWorld: 63.5 mm new Rogue: [TBD] AKG: 69.1 mm after 2k miles
02-29-2016, 11:17 PM | #3 |
635
Rep 3,124
BimmerWorld
I take lousy pictures with 2 hands, let alone 1.
Other assorted dim sums: Bottom stud length: 20.0 mm Top stud length: 27.7 mm Diameter of rubber at top: 67.0 mm Diameter of rubber in middle: 92.0 mm Diameter of rubber at bottom: 103.5 mm Misc. notes: Has 2 keyholes for heat shield tab. Comes with stickers and Gummi Bears. Doesn't come with nuts. Macadamia, Nyloc, or otherwise.
03-01-2016, 04:41 AM | #4 |
Rep 5,327
my supercharger intake manifold sat around 10mm away from the SB on the stock mounts, it was always an area what concerned me, but after fitting the VT mounts the distance remained the same between these 2 components.
my stock mounts were removed with very low miles, under 10k for sure, so maybe the squash was small. Pleased to report I've never had a contact issue
Multi award winning Detailing | Wrap | PPF specialists UK based - www.topwrapz.com Last edited by Beedub; 03-01-2016 at 02:26 PM.. |
03-01-2016, 12:17 PM | #5 |
Rep 870
Drives: 2006 BMW Z4M Roadster
StickMon,
Until someone measures a new set of OEM mounts, I thought I could contribute some used measurements. I measured a set of OEM mounts that have 30K miles on them, but look in excellent shape. The battery on my caliper is dead, so this is +/- 1 mm: OEM 30K Mile Mounts: Top to bottom thickness excluding bolts: 67 mm Diameter of rubber at base: 104 mm Maybe the Bimmerworld mounts are shorter because they don't compress as much, and after compression, the stock mounts are compressed to a shorter height. Salty
03-01-2016, 12:37 PM | #6 |
Rep 11,665
Part of the reason for lower performance mounts is lower center of gravity.
03-02-2016, 04:23 PM | #7 |
Rep 1,546
For comparison's sake, and since I'm bored and happen to have it sitting in my living room, here's the specs for the AKG mount. Used roughly 2K miles.
Bolt end to end = 110.44mm Mount top to bottom = 69.06mm Top thickness = 60.32mm Bottom thickness = 89.27mm Weight with included hardware= 1 lb 4.1oz / 570g Subtract 1 oz / 28g for hardware
03-03-2016, 05:56 AM | #8 |
Rep 11,665
Does it make sense to modify this thread slightly to motor mount spec thread?
Add info for material type ( poly, rubber, etc) Mount bolt design; (through bolt, isolated, sheer protected, etc) ...... Might be a good sticky for mount selection
03-03-2016, 02:10 PM | #9 |
635
Rep 3,124
Could, but I think a lot of that is available from the manufacturer.
The height was the main thing I was trying to capture because they never seem to tell you that, and there was a lot of speculation going around.
03-09-2016, 05:59 AM | #10 |
Get Some
225
Rep 759
Drives: 07 Z4 3.0si
I vote for stickied thread, good info made better with hard numbers
03-09-2016, 09:59 AM | #11 |
Rep 870
I picked up a battery. OEM Mount 30K miles.
Salty
03-09-2016, 06:19 PM | #12 |
Get Some
225
Rep 759
Drives: 07 Z4 3.0si
Holy shit...they do come with gummy bears
Tags |
motor mount dimensions, motor mount height |
