      11-11-2011, 10:39 PM   #23
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
pretty sure the OP is installing a supercharger, not a turbocharger
also, superchargers are "blowers" because they blow more air into the engine, turbochargers suck it out
      11-11-2011, 11:01 PM   #24
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
193
Drives: '01 911 Turbo
What?! I hope you're joking here Wafflez..
Both superchargers AND turbos are referred to as "blowers," because they force air into the intake manifold (hence "forced induction"). More air + more fuel + proper tuning = more power. Neither of them suck anything..
Superchargers run off of the engine's crank (belt-driven), while turbochargers run off of the engine's exhaust gases (flow-driven).
      11-12-2011, 01:57 AM   #25
johanness
Drives: 2008 Z4MC
Both supercharges AND turbos are referred to as "blowers," because they force air into the intake manifold (hence "forced induction"). More air + more fuel + proper tuning = more power. Neither of them suck anything..
Exactly. The drive system is the only thing that separates the two (of this type). I had been staring at the detailed pics of the ASA units themselves, so i said turbo. Semantics.
Blower, compressor, whatever... she's going to be a beast!
      11-12-2011, 04:26 AM   #26
Beedub
eagerly awaiting more pics!!
      11-12-2011, 05:22 AM   #27
IronZ4M
First Class M
IronZ4M's Avatar
20
Drives: Z4M Coupe, E36 Coupe
Originally Posted by Beedub View Post
wowza!!!!! LOVE IT!!!!
im really suprised the stock oil cooler wasnt uprated........ you may want to look into that and uprate to a new unit, you will easily get the oil into the red @ this power level, my sterab unit adds nearly an extra litre of oil and in really hot weather i can get it to the 1 oclock with a trackday.... the quality of this kit screams German made!!! Really impressed, love all the water line routing...... your doing a really good job!!
keep the pics coming.... amazing quality......
I'll keep that in mind. I just thought about it we are not upgrading the oil cooler actually our weather is too hot in summer time I'll be careful about
this it's a really issue I have to keep it in mine while I'm running the force injection.
Originally Posted by johanness View Post
Can't w8 till it's functional and getting some #'s out. Any plans for a ventilated hood? That blower sits well, but I can imagine some huge underwood temps, or?
I dont think that I'll get a ventilated hood bcoz I didnt like any. BTW we bought RPI scoops to have some ventilation to the turbocharger area but it seems we couldnt install it due to the water pump I'll try to fix on if not we will sell the scoops.
op are you sure that top water pump is going to be ok?? the pipeing looks alittle restricted, any other way to get a nicer bend in that top water pipe??? Remember thats cooling your charge air so you dont want any restrictions at all, it seems ok from the pics but just be 100%......
Beebdub, yah it looks not perfect in the picture in fact that hose is a V shape. but I'll keep it in mind I'll check it while we make a run test
'07 Z4MC l Alpine White l Supersprint Race Exhaust l Supersprint X Pipe l OEM Carbon fiber Spoiler l H&R Springs l Vossen VF051 l G-Power SK I 415 rwhp l RPI Scoop l ///M Performance Knop.
      11-12-2011, 07:21 AM   #28
Beedub
Definatly..... bear in mind my summer here is a max of 35 deg C, with the large front mount oil cooler it really keeps temps far more stable than the stock unit ever did, even when the car was stock, now with the forced induction it REALLY takes some weather and REALLY hard use to heat it up but it does get their, with your climate you'll notice this WILL 100% become an issue, as youve still got the stock unit inplace it will be really easy to get a stock uprated replacement that slots right in, probably one of the easiest jobs we can do..... i personally would like an alloy rad as well with silicone hosing...
Arhhh ok its shaped that way.... awesome, everything fits sick imo!!!
right iron, please go away and carry on and take REALLY detailed pics as your currently doing so, im hanging off this thread waiting for progress!!
      11-12-2011, 10:42 AM   #29
ZStig
279
edit: I didn't phrase things right about the turbo, but I do know how it works. And it might be a regional thing, but I've never heard of a turbo being called a "blower". http://en.wikipedia.org/wiki/Blower
Anyway, lets not ruin this thread with side conversation
      11-12-2011, 11:00 AM   #30
ZStig
279
if the car doesn't start on your first try, check the ECU connections. hahahah. that was my issue
      11-12-2011, 11:35 AM   #31
O-cha
O-cha's Avatar
218
Drives: Mcoupe
Aww don't try to save face, just admit the error.
      11-12-2011, 11:39 AM   #32
O-cha
O-cha's Avatar
218
Drives: Mcoupe
These asa blowers run a planetary type sytem so they spin up really fast they make a very very turboish whoooosshh....... They sound nuts!!!
NO AFAIK ASA blowers run a standard gear set, that's rotrex that has a sort of planetary variable gear. That quick spinup woosh thing is when the pulley clutch starts to grab and starts spinning the blower.
      11-12-2011, 01:49 PM   #33
Beedub
yeah my wording is wrong, i was wrong, they use a helical gearset which increases impellar speeds 1:15, i believe they spin up alot faster than my giant vortech does, CFM is alot lower however...... my main point is the "turbo" like sound these asa units make.
AFAIK, they have to be specified with the "clutch system" as an optional extra, looking at the gpower site the clutch is a payable option.
Always was a fan of the ESS CFR range, i really thought that was a solid kit tbh......
      11-12-2011, 02:15 PM   #34
Beedub
OP, update??
      11-12-2011, 04:11 PM   #35
O-cha
O-cha's Avatar
218
Drives: Mcoupe
All the applications have clutches on them. You wont see an ASA blower on a BMW other then Gpower anymore. Gpower and ASA are one company and they don't sell to BMW tuners anymore.
All superchargers have internal step ups, they all spin at 100,000 + RPMs you would need a crank pulley bigger then the car and a tiny blower pulley to achieve those speed without an internal step up gearset.
Your vortech blower is designed with a much lower impeller speed, where as the ASA is a much higher. It's different theories of design, large impeller low speeds or small impellar high speeds. Each has their benefit and downside on providing better torque or HP, efficiency or fuel economy.
      11-13-2011, 07:53 AM   #36
Beedub
Op :-) awaiting daily fix :-)
      11-13-2011, 08:57 AM   #37
NeoGeo
Drives: E92 M3
Did someone mention that Asa doesn't supply devices for BMW anymore? Why is that the case? I recall that in the early 2000s their kits were very popular with the e46 crowd. What happened?
      11-13-2011, 06:11 PM   #38
Rated M Roadster
Rated M Roadster's Avatar
160
Drives: F10 M5, i3, Z4M
LOL. Not even close...
      11-14-2011, 04:39 AM   #39
Beedub
Op whats happening??? Are you out driving like this beast yet??? Updates????
      11-14-2011, 05:07 AM   #40
tikamak
Lebanon
58
Subscribed.
@O-cha: If the ASA blower has internal gearsets to achieve 100K RPMs, doesn't this mean that the ESS Vortech is more reliable in the long run?
      11-14-2011, 06:37 AM   #41
Beedub
Originally Posted by tikamak View Post
Subscribed.
Not really no as its designed to spin like this.... The vortech is a big unit and moves alot of air in a different way and even though it spins at half the rpm can move considerably more air and is very effiecient in doing so........
Each has advantages and dissadvantages, i like that my blower can make 750hp plus but i pay for that low down in the rev range...
Either wsy each option is sick and will give you mad power :-)
      11-14-2011, 07:59 AM   #42
IronZ4M
First Class M
IronZ4M's Avatar
20
sorry for the delay actually I was so busy and I couldnt even check the thread. Anyway, we just removed the injectors and replace them. mostly we installed everything. still to be done is connecting supercharger outlet oil hose...
DSC_0325 by Saihati Shabiboo, on Flickr
looks dirty!
DSC_0327 by Saihati Shabiboo, on Flickr
DSC_0331 by Saihati Shabiboo, on Flickr
Old injectors
DSC_0338 by Saihati Shabiboo, on Flickr
DSC_0335 by Saihati Shabiboo, on Flickr
DSC_0337 by Saihati Shabiboo, on Flickr
DSC_0340 by Saihati Shabiboo, on Flickr
DSC_0352 by Saihati Shabiboo, on Flickr
I might not finish and have some delay coz I'm so busy at work and working so far away from home maybe a delay of a week . can't wait to drive it .
      11-14-2011, 08:08 AM   #43
IronZ4M
First Class M
IronZ4M's Avatar
20
btw this kit is rated @ 450hp :-)
heres the bumpf from the the gpower site
G-POWER supercharger system SK I "Sporty Drive"
Basis: Z4 M, 343 hp (252 kW) increased to 450 hp (330 kW)/ 460 Nm
consisting of:
Belt Drive:
ultra stiff CNC shaped supercharger bracket system made from cast aluminium including an extended support-aggregate belt drive for the superchargerīs drive;
Air Intake Manifold:
racing air filter;
flow optimized clean air intake with large diameters made from cast aluminium;
Forced Induction/Intercooling:
ASA T1 518 supercharger with centrifugal clutch ASA K07 (optional);
supercharger lubrication through bypass from motor oil circuit;
air/water recuperator with front mount intercooler;
engine inlet manifold made from cast aluminium;
pneumatic, load-dependent boost regulation
boost level approx. 5,8 psi rel.;
Engine Modification:
6 racing spark plugs with modified heat values.
Fuel Management/Electronics:
adaptation of the software of the standard electronic engine control unite (BMW OBD remains fully preserved), enabling an unlimited top speed according to the capacity of the tyres;
6 x fuel injectors with enlarged mass flow.
interestly this blower needs nearly 6psi to make the power the ess unit does @ 4.5-5psi, this is where the flow characteristics come in for each blower, that big vortech can make upto 750hp with no mods just a pulley change, the ASA unit needs to be swapped out to the top units, this unit is maxed out by 550hp..... That said our Vortech units lack Tq, what our cars need imo..... This kit @ 450hp will gain significantly in TQ due to the nature of the asa units...... make no mistake, this will be a very fast car....
interestingly they tune with MAF in place.... i say it again the hardware looks fanatastic!!
look forward to seeing how the AFRs look on this....
I've been mistaken about the Supercharger unit actually the superchager we have is ASA T-521 and it's the same supercharger that G-Power use it for the E9X M3 SK I. ASA T-521 is maxed out by 580hp.
DSC_0373 by Saihati Shabiboo, on Flickr
      11-14-2011, 09:42 AM   #44
ZStig
279
nice
I think 600hp crank is close to perfection on this chassis, so you wouldn't be far off maxed out at 580
