07-07-2017, 10:06 AM | #1 |
Rep 1,483
Impromptu Cars & Coffee - Tomorrow Saturday July 7th in Milton
Just throwing it out there if anyone's interested in a quick C&C and 1.5hr rip around the Niagara Escarpment between Milton and Burlington maybe into Hamilton. Meet up at a Tim Horton in Milton (close to 401/HWY 25) at 9:30AM, tomorrow Saturday July 7th.
Let me know if there is any interest. Tim Hortons 80 Market Dr, Milton, ON L9T 3H5 https://goo.gl/maps/oYCrwhJVfHN2
- Instagram ->@e91kiter Last edited by Cyclops; 07-07-2017 at 07:54 PM.. |
07-07-2017, 11:11 AM | #3 |
Rep 478
Might be able to pop in around 10am for the Milton rip...car is a mess still from the last time I took it to Mosport and I doubt I'll have time to wash it before hand.
07-07-2017, 04:45 PM | #4 |
Rep 209
Drives: Z4M roadster
Sorry - not this time. Heading over to Ajax tomorrow, then Mosport on Sunday😀
2006 Z4M roadster. Interlagos Blue, black extended leather with carbon trim. Apex EC7 8.5/9.5 x 18 rims, Strong Strut brace, KW V3s with RE rear shock mounts, Vibra Tech and Rogue engine/transmission mounts, Stromung exhaust, CDV delete.
07-07-2017, 07:52 PM | #5 |
Rep 1,483
Ok let's meet up 9:30 and head out at 10:15
- Instagram ->@e91kiter |
07-07-2017, 07:55 PM | #6 |
Rep 1,483
There's a coin car was on steels.
Eau_Rouge111355.50 |
07-08-2017, 01:28 PM | #8 |
Rep 1,483
Yup that was a fun run! We need to do that again.
07-08-2017, 01:30 PM | #9 |
Rep 478
07-08-2017, 02:41 PM | #11 | |
Rep 478
Plus...some cyclist flipped me off too as I opposite locked a corner (location to remain between me and my dash cam)...good times!! |
07-10-2017, 08:20 AM | #12 |
Rep 528
Drives: E86 Z4MC; E92 M3
Was nice to meet up with you guys for a quick chat - next time I'll definitely have to do the drive too.
E46 M3 Coupe 6MT Jet Black/Cinnamon GONE
E85 Z4M Roadster Imola Red/Black GONE E90 M3 Sedan 6MT Jerez Black/Fox Red GONE E86 Z4M Coupe Interlagos Blue/Black E92 M3 Coupe 6MT Interlagos Blue/Fox Red - Build Thread |
07-18-2017, 07:43 AM | #13 | |
Rep 478
07-18-2017, 08:50 AM | #14 |
Rep 478
Hey guys...before we left for that quick spin on a Saturday...we were chatting about brakes given how I picked up a set of front M4 calipers. Well, from the thread below (I know is an e46 M3 but would I be wrong in assuming they are very similar to the Z4M?)...it does not look like too hard a job as that bracket I can build quite easily around here at my shop...ordered a set of rear M4 calipers from the same crashed car I picked up the fronts from...so plan is to do a lot more research and if possible...this winter the plan is to get it done...should be a fun little project if I can pull it off.
Cheers. http://www.m3forum.net/m3forum/showthread.php?t=558795 |
07-18-2017, 08:07 PM | #15 | |
Rep 1,483
Also if you want some expert advice on brake bias etc ask The HACK as he seem to be very knowledgeable in that area.
07-19-2017, 06:18 AM | #16 | ||
Rep 478
07-19-2017, 09:12 AM | #17 | |
Commander
219
Rep 850
Drives: Z4MC/M5/640iX/M1000RR
The thread you are linking from M3forum, I just want to clarify that the brake kit they have pictured is NOT from an M4, it is in fact an F3x M Performance kit. That being said, I had purchased one of those kits myself in hopes of retrofitting. In the end, with the modifications required to run the kit I decided against it. The deal breaker for me was having to bring out the rotor another 10mm, which meant losing even more room under the already small amount we have to play with under our front fenders. The stock Z4M rotors, and every proper BBK made for the car happens to have very shallow hats, any newer gen BMW rotor however has such a deep hat that it can't be bolted to the hub due the disk itself making contact with the control arm and tie rod end. Basically, I would have had to run a 10MM spacer between the rotor and hub. Decided against it and got a proper BBK. Second time around looking to do a retrofit brake was helping a friend with a pretty serious E30 build. The reason this is relevant to what you are looking to do is because of the similarity between the Z4M front suspension and the E36 M3 front suspension, which this E30 was running. To be able to run an M4 caliper we had to: Trim control arm Trim tie rod end run 6.8mm spacer between hub and rotor custom wheels 18" had to be made (may not be an issue with 19s), any 18" wheel that was test fitted either had too small of a barrel or not enough clearance between mounting surface and spoke. This M240i wheel below barely cleared and only with a 15mm spacer.
E60 ///M5 - (6 Speed) Silverstone Metallic/Black F06 640iX - Tanzanite Blue/Amaro Brown K66 ///M1000RR - Competition |
07-19-2017, 09:29 AM | #18 | ||
Rep 478
Would be pretty cool to have it all fit in my Z4M but I'm not prepared to go to the level you say I would need to to get it all to work. Again, thanks for your input on this |
07-20-2017, 07:32 PM | #19 | ||
Rep 478
07-22-2017, 10:14 AM | #20 | |
Commander
219
Rep 850
07-22-2017, 11:53 AM | #21 | ||
Rep 478
Again, much appreciated on your input on this. |
07-22-2017, 02:34 PM | #22 | ||
Rep 478
The brackets/machining of anything I need to I can do personally so the cost is insignificant and I'm just stubborn....I hate giving in/up Cyclops....sorry for hijacking your thread dude Again...thank you for your input...you saved me from buying M4 rotors and a few other things and the associated time and grief then only to find out it's a dead end |
