09-19-2017, 09:49 PM | #23 | |
Rep 114
09-19-2017, 10:54 PM | #25 |
Rep 272
They told me to kick rocks and that their opinion (entirely disregarding my explanation + PICTURES + referrals, etc) was superior to Dinan's - and that they essentially excuse themselves from all blame or defect. My battle with them is far from over, so I'll update as it progresses.
09-20-2017, 01:37 AM | #26 |
Where Does He Get Those Wonderful Toys?
94
Rep 290
That sucks bad. I had a 190e merc that this happened to also. It blew my mind then and thought is was a complete fluke, just as it does now. Maybe its a straight six thing LOL!
good luck |
09-21-2017, 02:42 PM | #27 |
Rep 65
Drives: 08 3.0si Artic White with Red
Nissan had a huge issue with their 4 cylinder motors sucking the contents of the catalytic converters upstream into the combustion chamber. Strange but true.
09-22-2017, 12:40 AM | #28 | |
703
Rep 7,850
I get the competition angle for them potentially with Dinan (but for you given location who better to rebuild), and maybe a bit of defensiveness as a result. Was there any discussion of what would be required to make a claim they would look at and perhaps help with? What's the process? What are the requirements? If that's clear then you actually could check off the boxes I think. If not, how can you know what's need to prove a claim? Issues happen, the unforeseen happens, and those need to be addressed. This is actually a chance for a company to shine. How a company behaves when things go wrong is a true measure of a company. I hope your battle goes well and this gets cleared up. Maybe next spring we should meet up at Thunderhill and celebrate the car's rebirth! |
09-24-2017, 09:41 AM | #29 | |
Rep 506
Drives: 2007 M Coupe
Garage List 2007 E86 Coupe [0.00]
2006 Z4 3.0si Coupe [6.00] 2002 330 CI [0.00] 2018 BMW 240M [0.00] 2007 M Coupe [10.00] |
We originally thought it was the Vanos and had already planned to upgrade it add a TTC 300 Hub with the cams after the event. Once we got everything finished the top end of the motor, we noticed some additional sounds in the bottom and checked the rod bearings and sure enough we slug one and the crank facing your same issue. After weighing all the options, I thought it would be the perfect opportunity to go with 3.4 Stroker kit. After speaking with both Lang Racing and VAC, I have decided to go with the Lang Racing kit. At the end of the day you should be looking at about 13k with labor, new oil pump and all the other additional parts. I look at a number of other options and even with a rebuild, You are still looking at 9 to 10k, I just went with this option. I think we will probably end up at 425hp once we finish. I will also be adding the Evolve CSL Airbox, upgrading the clutch and flywheel as well. Last edited by M-Cast; 09-24-2017 at 09:47 AM.. |
09-24-2017, 01:44 PM | #30 | |
Rep 5,328
wow!
09-25-2017, 11:29 AM | #31 | |
Rep 272
That said, I have only heard positive things about Lang. He was friendly and knowledgeable in the numerous times we've spoken and will highly recommend him to those in SoCal. My only hesitation was the distance, lesser warranty, and Dinan is in my backyard. VAC on the other hand... I've been told to run. Countless times. From multiple unrelated sources. |
09-25-2017, 11:33 AM | #32 |
salty cowboys fan
6158
Rep 3,406
Interesting about the VAC kit. What did they say the issues were? I’ve been eyeballing it as it’s bearing time for me too and I have no willpower
09-25-2017, 03:48 PM | #33 | |
Rep 506
VAC components are good, it is just a different objective. They can get 450hp out of their stroker kit, but anytime you put that much stress on an engine the life and daily drivability of the car changes dramatically. If you want a something you can track and drive on the street, then Lang's kit might be your best bet. VAC runs a 97mm stroke vs. Lang's 95mm. You also will need to upgrade the cams and a few other areas to really get the most out of a stroker kit. Its a much different set up than a supercharger, and if you want to track your car, in my opinion going to a stroker motor is much more useful. |
10-01-2017, 10:42 AM | #34 |
Rep 747
I came to this thread expecting not to learn anything new about the options out there when folks have hit this sort of brick wall. I didn't know Dinan still looked at these cars or really put their hands into it much at all and that sounds like a fantastic option.
I was going to come here and simply suggest that you run a new motor or go to Lang especially since you're much closer to him than many others, and honestly you can see my story about local shops. However you've already found a solution and now I'm curious to see how it might compare to the products Lang offers and the overall reliability. I'm sure that many of us want to keep these cars running until our lifetime runs out and this will be a good experiment to see just how far we can push these cars with the various options out there. I wish you the best of luck with the build/rebuild. I know it's a painful process but trust me it's all worth it when you get to put your foot down count out of a corner again. Keep your head up and best wishes.
◙ Shane
10-03-2017, 03:24 AM | #37 |
Rep 506
Trust me, I try not to look at the stack of receipts I have accumulated with this car. Lot's of trial and error and time to find the right parts, but it has been worth the wait and the car has been by far one of my favorite builds.
I will be posting a build sheet for the rebuild soon. |
Arsonism158.00 |
10-08-2017, 08:36 PM | #38 | |
Rep 747
Looking forward to build updates OP!
◙ Shane
Finnegan703.00 |
