07-15-2009, 10:54 AM | #23 |
M Slut
18
Rep 564
Drives: 2011 M3 Coupe Mineral White
Location: Adenau, GE via 3 years in dreadful El Paso, TX
Any videos of the intake sound yet???
You have to be 100% behind someone before you can stab them in the back.
David Brent |
06-13-2012, 03:53 AM | #24 |
Rep 912
I installed my afe intake and there's something i noticed, when going uphill or even when mashing the throttle on 2K RPM for example (or a high throttle) the intake tend to make a tinny growly sound that tends to go away and transform to a kind of a howl on higher RPMs.
Is this normal? i don't like that tinny sound, i just want the induction howl and growl |
06-13-2012, 06:31 AM | #26 |
Rep 912
Sounds very tinny under 5K. Like a badly designed intake, although it is quite good.
I am thinking of modifying mine to eliminate that kind of rattle and leave the induction sound. I think that i will need vibration dampeners, i will put on the intersection parts of the housing and the chassis which should reduce this effect and leave the induction sound. |
06-13-2012, 10:18 AM | #27 |
Rep 1,739
Drives: 2008 Z4MC
No 'tinny' sound here.
Were either of you tuned for the intake? (ESS, AA, etc) If not you weren't experiencing its potential either |
06-13-2012, 10:37 AM | #28 |
Rep 740
When I had AFE on mine it never made any tinny sound...only deep and loud bass!
I wonder if something is rubbing due to vibration or if the cover isn't on tightly? |
06-13-2012, 11:03 AM | #29 |
Rep 999
Same here! No tinny sounds that i could hear
06-13-2012, 11:13 AM | #30 |
Rep 912
Maybe my choice of words is wrong.
It's still a loud growl but it's like an american muscle car type of a growl, not CSL snork type. To rephrase, you hear the deep growl but there's an extra sound that seems like metal on metal shriek |
06-13-2012, 02:59 PM | #31 |
Rep 862
06-13-2012, 05:01 PM | #33 |
Rep 740
I dunno...I honestly never heard any sound resembling a metal shriek when I had my AFE, and I listened very carefully through all types of driving and loads...
06-14-2012, 02:03 AM | #34 |
Rep 912
Did you reuse the stock ball like mushy bushing to mount the case of the AFE ? because i am thinking about puttin this part underneath the afe housing.
I feel that the metal to metal contact of the housing and the chassis is the reason why i am hearing this metallic sound when hard throttling on low RPM |
06-14-2012, 11:32 AM | #35 | |
Rep 740
06-14-2012, 11:55 AM | #36 | |
Rep 999
07-06-2012, 10:09 AM | #37 |
Rep 225
I just installed the aFe and made a recording with a Tascam DR-05 recorder. I don't feel the aFe is as deep or growly as I'd like it compared to my E46 K&N cai.
11-07-2020, 10:09 PM | #38 | |
I like Coffee & Z4s.
106
Rep 366
Drives: 2007 Z4MC
Here's what the mushy thing looks like from the underside: View post on imgur.com It's part #13717539903 here: https://www.realoem.com/bmw/enUS/sho...diagId=13_1174 I found that the aFe housing fits much better without said mushy thing, but the sound was tinny. Almost like you could hear the valve metallic noise amplified. With the mushy thing, the housing doesn't seat quite right, but the tinny noise is gone and the low growl is heard more clearly. I'm so glad to get rid of the annoying tinny noise! Here's how it currently sits in my setup. Was yours similar? View post on imgur.com There was a bit of a fitment issue after adding the mushy bushing. Of the two mounting points to the body, i could only comfortably affix one, due to the increased height of the housing due to the mushy bushing. The second one I left like this: View post on imgur.com |
