05-31-2015, 09:09 PM | #1 |
Rep 904
Mounting spot for toll transponder
I finally got around to ordering an EZ pass for the Z4. It comes with 2 adhesive strips and they recommend mounting it behind the rear view mirror. All the loaner cars I've gotten from Audi have the transponder mounted somewhere in the engine bay or bumper. Has anyone found a good spot to do this on the Z4?
06-01-2015, 07:28 AM | #3 |
Rep 904
06-01-2015, 09:15 AM | #4 |
Rep 1,134
Drives: '07 M Roadster
There isnt a ton of space in the trim at the top of the windshield on the roadsters so unless if this thing is really small, you wont get it up there. I don't know what is inside the center part of the convertible top, but I imagine it is full of motor stuff for the latches. How often are you going through the tolls? Would it be too much of a hassel to just put it in the center storage and pull it out when you need to use it?
06-01-2015, 10:03 AM | #5 |
Rep 904
Ah, so that's where the motor goes? I always wondered why roadsters didn't have a sunglass holder. The transponder is about 2" x 3" x 1" so I probably couldn't squeeze it behind any trim piece. Any place near the bumper that's good?
I don't want to put it in my center storage because I don't go through toll booths that often, so I know I'll forget to take it out in time while going through the express lane. My body isn't flexible enough to allow me get anything out of the central storage while driving anyway. My other 2 cars have it mounted in the windshield so I don't have to think about it. Even before I got the transponder for the Z4 I kept swerving into the cash lane at the last second because I kept forgetting I don't have a transponder |
06-01-2015, 10:24 AM | #6 |
Rep 1,107
Two steps for making a huge EZ-Pass transponder disappear (for the driver at least):
1. If any color other than black, Spray-Dip it black 2. While seated in the driver's seat, position the transponder on the windshield on the right side of the rear-view mirror so that the mirror is blocking sight of the transponder. Out of sight, out of mind. When it's black, it's also not as noticeable to the passenger. |
06-01-2015, 11:53 AM | #7 | |
Rep 904
06-01-2015, 02:10 PM | #9 |
Mechanical Engineer
96
Rep 1,025
You can also buy a black version of that special hard plastic velcro they come with (3M Dual Lock). They sell it at staples.
Black velcro plus black paint and it will disappear pretty effectively. OP, since you're in MA I'm assuming you have an EZPass. EZPass also offers a license plate mounted transponder that would eliminate this problem for you. |
06-01-2015, 02:27 PM | #10 | |
Rep 904
I don't think the license plate mount works well for MA plates. http://www.teslamotorsclub.com/attac...0&d=1358571702 It blocks the entire state name and part of the registration month. |
06-01-2015, 03:17 PM | #11 |
Mechanical Engineer
96
Rep 1,025
that license plate tag is huge and obnoxious, I was thinking they were a lot thinner than that. i guess thats not a better option after all.
06-02-2015, 09:06 PM | #12 |
Rep 18,724
Mount it underneath and recessed and you barely notice them. Both my cars are mounted that way. It's very easy to do.
06-02-2015, 09:26 PM | #13 |
Rep 904
06-03-2015, 12:10 AM | #14 |
636
Rep 3,124
Just use a couple metal strips with a hole in each end to extend it down from the bottom holes on the plate.
06-03-2015, 05:17 AM | #15 |
Rep 18,724
Not the best pic, and this is the older version of the bumper transponder used in Virginia, the newer ones are a bit slimmer and only have one mounting hole per side. But you get the idea. I just made some brackets and mount them from the backside of the lower tag bolt locations. It's stealth, protects the transponder from bumper rash, and works good.
06-03-2015, 09:01 AM | #16 |
Rep 1,001
Call me paranoid if you wish but I do not want to be tracked everywhere I go so I always keep my in the anti-static bag and take it out only when needed.
http://www.forbes.com/sites/kashmirh...t-toll-booths/ |
06-04-2015, 05:28 AM | #17 | |
Rep 18,724
Maybe you need to visit goanalog.com to get some peace of mind.
06-04-2015, 06:54 AM | #18 |
Rep 168
I am not sure which transponder you have, but the newer, smaller component is a good candidate for plasti-dip. Then placed behind the rear view mirror will, as mentioned earlier, be out of sight out of mind.
Do be careful with the recent change in temps... I've noticed colder nights that lead into warmer afternoons affect the adhesive. Sometimes I will enter the car and the ezpass is on the floor lol. R. |
06-04-2015, 08:00 AM | #19 | |
Rep 1,107
That said, the second there is even a whiff of using tracking information for non-anonymous reasons (e.g. infractions) that thing is going in the bag! |
06-04-2015, 08:29 AM | #20 |
Rep 904
There are many documented cases where the prosecution has used highway tolling data to show a murder suspect was in a certain place at a certain time, which contradicted the suspect's original alibi. I hope that's not why Pheonix is scared of using it though
06-04-2015, 11:59 AM | #21 |
Mechanical Engineer
96
Rep 1,025
as long as we all have cellphones, any other anti-tracking efforts are a waste of time. its like driving a semi, but taking the antennas off to give it a lower profile.
