12-10-2016, 12:04 PM | #1 |
Rep 71
19" Bbs Rg-r (mint)
Posting these up for sale 19x8.5 +32 19x10 +20 Freshly powdercoated. Michelin PSS 95% tread. 245/35/19 and 265/35/19 $2500 firm Located in Allentown Pa [/QUOTE] Last edited by MTreeGuy; 01-04-2017 at 03:52 PM.. |
12-11-2016, 05:34 AM | #3 |
Rep 453
Drives: 2007 Z4M Coupe
Wow, love theses! I know it's only a 265 tire in the rear but I'd be worried about rubbing with that low offset, 35 profile tire and my 25 mm lowered suspension. Any ideas whether these would clear?
12-11-2016, 11:03 AM | #4 |
Rep 10,662
I'm pretty sure that's a proper offset for the Z4M in the rear.
12-11-2016, 12:59 PM | #5 |
Rep 2,866
12-11-2016, 02:09 PM | #6 |
Rep 10,662
12-11-2016, 03:16 PM | #7 |
Rep 2,866
Did you have fender work? Otherwise, must be a variation with tires. I run 19x9.5 +25, also with 275/30/19 tire - I have less than 10mm clearance to fender. If you do the calculation, a 19x10 with +20 would sure to rub.
12-11-2016, 03:53 PM | #8 |
Rep 453
This guy was running the same set up but with a 275 tire and he sure looks pokey in the rear....a 265 tire should help but too close for comfort for my taste.
http://www.zpost.com/forums/showthread.php?t=629084 |
12-11-2016, 06:46 PM | #9 |
Rep 10,662
No, absolutely zero fender work. I currently have Hankook V12s on there I believe. They came with the wheels I purchased. I have a set of Conti DWs just waiting for Spring to install. Same size.
12-12-2016, 10:57 AM | #10 | |
Rep 2,866
OP, sorry for the thread jacking |
12-12-2016, 03:51 PM | #11 |
Rep 1,543
my favorite set of wheels. classy and one of the lightest out of all the street spec bbs wheels.
I let mine set go a couple of years ago with these same spec. I had 245/275 MPSS on these at HPDE without rub. I was on OE suspension and 1.3° camber at the rear. Any alignment shop can dial that in for you without additional hardware. They're lighter than 18? OE and since the rear is at 10", there's a tiny stretch look to it. It tucked under the fender well just right. maybe I should get them again.
FB Group-- > fb.com/groups/z4group Instagram --> @Skyermotorsport FB Page-- > fb.com/Skyermotorsport |
coh661191.00 |
12-13-2016, 10:55 AM | #12 |
Rep 453
Starting to look tempting....
