11-27-2010, 07:46 PM | #111 |
Rep 243
This thread is starting to read like a soap opera, not that I watch soap opera's.
I'm learning alot, (not being sarcastic).
2008 Z4MC #1786/1815 "The Last IB w/ Extended Leather Made" Gone but Not Forgotten
2014 M235i E.Blue Mods in Progress |
11-28-2010, 03:18 PM | #112 | |
Rep 4,726
While that is BMW spec, you can't use an absolute value comparison for compression tests, only thing you can do is compare between cylinders for variance.
11-28-2010, 04:44 PM | #113 |
Rep 185
Ocha. What exactly does a leakdown test entail. I watched him do it. He removed all coil packs and sparkplugs , he did every cylinder at top dead center and measures them with a pressure meter. The meter read 100% each cylinder
11-28-2010, 04:46 PM | #114 |
Rep 4,726
All engines have leakdown past the rings to an extent, sounds like the correct process though. The leakdown test measures the amount of air that leaves the cylinder. usually it's at least 5% with most gauge sets.
11-28-2010, 06:36 PM | #116 |
Rep 4,726
No, usually a compression test will show "bad" and then a leakdown is used to pinpoint. Since your compression is good it's likely you don't have any leaks.
11-28-2010, 06:40 PM | #117 | |
Rep 421
