09-03-2012, 08:41 PM | #23 |
Rep 11,667
Ive seen this issue on other cars.
I think it's usually related to replacing one piece rotors with 2pce ...not the case with ours
09-04-2012, 02:13 AM | #25 |
Rep 5,329
Ap bbk here. Still have park brake.
09-04-2012, 02:37 PM | #26 |
Rep 879
On my E46 M3, I had Stoptech on 4 corners and I had to trim the rear backing plates to fit the rear Stoptech. But the handbrake still work if you don't trim too much material.
09-06-2012, 11:13 AM | #27 |
#dubspec
6336
Rep 5,201
those of you with stoptech's, how far do the caliper stick out from the rotor. im sure my morr wheels will clear but i want to make sure. i have about 1-1.5" of space from my current caliper to my wheel spoke
09-06-2012, 11:23 AM | #28 |
Rep 503
Drives: Z4 M Coupe
With stock wheels i need at least 12mm spacers for the fronts to clear.
09-06-2012, 12:38 PM | #29 |
#dubspec
6336
Rep 5,201
How close does the stock wheel sit in comparison with the oem caliper?
09-06-2012, 12:40 PM | #30 |
Rep 503
Drives: Z4 M Coupe
Dont remember exact dimensions mate...
09-12-2012, 02:35 AM | #31 | |
Rep 700
That is why StopTech put them there. So you can make sure 100% before you buy them. Asking people on here about clearance is really not the best way to do things.
09-13-2012, 09:03 PM | #33 | |
#dubspec
6336
Rep 5,201
09-13-2012, 09:44 PM | #34 |
Rep 700
Well I would disagree as they worked out to be perfectly accurate for me
Are you saying they are all incorrect? What did StopTech say when you brought this to their attention? If you haven't e-mailed them your findings I am sure they would appreciate some feedback so they can correct any errors for other customers.
09-14-2012, 01:44 PM | #35 |
#dubspec
6336
Rep 5,201
i called and told them. they said they are not 100% accurate
09-15-2012, 04:02 AM | #37 |
Rep 5,329
dub.... to help with your question.... i can 98% guarantee this will fit behind your ET35 8.5" rim... why?? i have the CSL AP caliper which is significantly larger than the stoptech/alcon/ z4m AP caliper, when i say larger i mean thicker..... they wouldn't fit behind my stocks, couldn't even get the wheel on, let alone drive.... stock CSL wouldn't fit, now running et34 up front and a 8.5" rim.... i have around 8mm of space between caliper and spoke, AP ask for a minimum of 3mm, so you've got plenty of room for a little discrepancy. hope this helps a little.
get the template, although it may not be 100% accurate you'll see that you'll have PLENTY of room :-)
09-15-2012, 06:13 AM | #38 |
Rep 503
Drives: Z4 M Coupe
Hope this helps:
09-15-2012, 07:14 AM | #39 |
#dubspec
6336
Rep 5,201
Thanks guys. I ordered the kit last week. Should have them mounted soon
09-16-2012, 03:38 PM | #41 |
///M-fanatic
193
Rep 3,885
Should just trim whatever's needed to fit the calipers to the backets and as long as the rotors clear the edges of the shield. Leave the rest of the dust shield untouched; as it's there for a reason. Unless of course you go in there frequently and spray stuff down like a good detailer does
09-16-2012, 03:45 PM | #42 | |
Rep 5,329
09-16-2012, 07:48 PM | #43 |
#dubspec
6336
Rep 5,201
Any pics of your car with them mounted?
