      04-16-2012, 06:02 PM   #1
aaaafamily
aaaafamily's Avatar
Drives: E86 M
Anyone know BBK option on Z4m?
Does anyone know BBK option on Z4m beside brembo or Stoptech? Thanks
      04-16-2012, 06:08 PM   #2
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
I'm pretty sure there are several threads on this.
I have Stoptechs myself....
Are you looking for something in particular?
      04-16-2012, 07:39 PM   #3
Cal@Sonic MS
Cal@Sonic MS's Avatar
Drives: bmw
AP Racing and Rotora come to mind as well.
There's also K-Sport but that stuff is garbage.
      04-16-2012, 08:00 PM   #4
sabbanick
Drives: 08 SBM M coupe
Performance friction!
      04-17-2012, 07:18 PM   #5
aaaafamily
aaaafamily's Avatar
Drives: E86 M
I found a member use 135i 6 piston brake on his Z4 3.0, I was thinking is possible on Z4m?
      04-17-2012, 07:57 PM   #6
Cal@Sonic MS
Drives: bmw
Should be possible, but might require a custom bracket to be fabricated.
      04-18-2012, 07:19 AM   #7
Beedub
AP racing BBK.... these guys have proper race heritage, ever other race car runs APs so im happy with what i have, interestingly the mclaren mp4 12-c uses the exact same caliper used in the z4m bbk application ;-)
      04-18-2012, 07:25 AM   #8
onelove
Track Head
onelove's Avatar
Drives: 07 Z4M
Good to note that Brembo owns AP Racing now.
2004 Porsche GT3 |White
HRE R40 Monoblocks | KW Clubsport Suspension | RSS Lower Control Arms and Suspension Links | GT3RS Wing and Front Bumper | Cup Car Lip | Euro GT3 Seat | GMG Half Cage | Europipe Exhaust | EPL Tuning
      04-18-2012, 07:32 AM   #9
Beedub
they do indeed, AP is still seen as the race division ;-)
      04-18-2012, 08:19 AM   #10
RandysV10
MPOWERD
RandysV10's Avatar
15
Drives: 2010 M6
2006 Z4M  [8.00]
2010 BMW M6  [9.00]
Have you driven beyond the ability of OEMs? The stock brakes work very well and can hold up to quite a bit. I've tracked my Moupe many times and just gone with track pads (PFC 01s), SS lines and high temp fluid changes without any fade at all after a full day or weekend on the track. I can think of other areas of the car that I would spend BBK money on before upgrading the brakes. Just my .02 worth.
2010 Dinan M6 Coupe--2006 Z4MC--1994 E36/M3 Track Prepped
BMWCCA #442445
YouTube Channel: http://www.youtube.com/user/Randy23185
      04-18-2012, 11:28 AM   #11
Beedub
i agree with this tbh ....
      04-18-2012, 04:29 PM   #12
aaaafamily
aaaafamily's Avatar
Drives: E86 M
Thanks for your suggestion, it is good idea to save money on other parts first. but I would like to know option for the brake kit.
      04-18-2012, 05:16 PM   #13
3002 tii
3002 tii's Avatar
2286
Randy's point on saving money was only half the takeaway, the other half being do you actually feel the need to purchase a bbk given that 1) on the street it won't yield any better braking over stock and 2) on the track if you are experiencing fade with the stock setup, you could easily upgrade pads and fluid only for a fraction of the cost and achieve the same results as a bbk.
If you're doing this for looks then both points above are moot. To answer your question, the following companies offer a bbk: Stoptech, Brembo, AP, Alcon, Wildwood, K-sport and Rotora. If it were my money I'd go with either of the first 3, although Stoptech appears to be the cheapest of the 3.
Follow for latest mods
      04-19-2012, 01:01 PM   #14
aaaafamily
aaaafamily's Avatar
Drives: E86 M
Dubbeddown, thanks for information and advise. I will keep all these in mind.
      07-31-2015, 05:30 AM   #15
Blakkflame
Blakkflame's Avatar
Italy
44
Drives: Z4M - E91 MSport
You must use some spacers, with 224M stock ??
      07-31-2015, 05:33 AM   #16
ga41
ga41's Avatar
Cyprus
31
Drives: Z4 M Coupe
2006 Z4 M Coupe  [0.00]
I have Stoptech 355mm, 6 piston front, 4 piston rear, with stock wheels, you need at least 12mm spacers for the front wheels to fit.
      07-31-2015, 06:40 AM   #17
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
I haven't actually done a test fit on the stock wheel.
If you need the info, I have a stock wheel sitting here and can get some clearance data for you.
Let me know.
      07-31-2015, 07:55 AM   #18
Mirko
Mirko's Avatar
Like GA41 wrote, you need at least 12mm spacers for the fronts with stock rims. I have Stoptech and have run it with stock rims. The rears are fine without it but look nice pushed out with the 12mm spacer.
      07-31-2015, 09:28 AM   #19
ga41
ga41's Avatar
Cyprus
31
Drives: Z4 M Coupe
Did the same as well. I have both front and rear but mine are 12.5mm Turner Motorsport spacers.
      07-31-2015, 04:29 PM   #20
The HACK
The HACK's Avatar
1821
The RacingBrake kit requires a 5mm spacer to clear the front. If you run the rears up front then no spacers.
      08-01-2015, 04:39 AM   #21
Blakkflame
Blakkflame's Avatar
Italy
44
6+6, or 12+12mm ??!?
Let me know.
Thanks for your offer, but I've bought a Brembo monobloc 6 kit and I think that they're more big than ST6: it's only to know if I must buy also the spacers BEFORE to install it ......
Really, I don't understand WHY on Brembo website absolutely nothing for problem to use it: if I need to change suspension, wheels or must use spacers, EVERY caliper fit !!
      08-01-2015, 04:43 AM   #22
Blakkflame
Blakkflame's Avatar
Italy
44
.....I've a extra set of 224M, but, with stock suspension, 9ET30 fit ??
I don't think: I read that some problem to fit the 359M, and they're 9ET31....
And also with 225/45 it's very stretched ....
