04-13-2024, 06:20 PM | #1 |
Rep 700
No audio for phone calls over bluetooth
I have a strange problem that has just recently occurred.
When I make or receive a call there is no audio and the other person cannot hear me. I've got an Android phone but I have also tried an iPhone and the problem is still there so the issue looks to be with the car. I've tried:
The car makes and receives calls fine and I can see the phone is connecting but there is no sound through the car speakers. Has anyone else had this issue or know of how to fix it? I had heard of people wth other models resetting the audio system but I have no idea of how to do this. I've got the premium sound system with CID.
04-13-2024, 06:37 PM | #2 |
Rep 410
Does the music play via the radio….
Is it in “Bluetooth mode” on the radio…. If using Blu-bus are you in the correct mode… If using a Bluetooth adapter plugged into the “aux” circuit… is the radio on aux… And finally…. Is your amp working (not applicable if you can get music via the speakers….) I have the Carver DSP system/amp…..and blu-bus and have on occasion unable to hear. I solved the problem by trial and error and damned if I can remember exactly what I did in that case…. But resetting…unplugging… reloading blu-bus software (ensure you have the upgraded version for carver/DSP connectivity… worked with Ted/Blubus developer on that update) eventually restored my audio. Edit to add…. With Blubus… pressing Button 1 “pauses” music playback… pressing it again, restores/unpauses audio.
Sent from my smart phone...
04-13-2024, 07:55 PM | #3 |
Rep 700
Hello, thank you for your reply.
Yes, I get audio through the speakers via Radio and all other inputs. “Bluetooth mode” on the radio What do you mean by this? I am not using any Bluetooth adapter. Just the factory TCU Bluetooth system. Coincidently, I have been researching the BlueBus system if I cannot get this fixed as it would add extra functionality in the form of Audio streaming. I have a question for you. With BB how do you select tracks on the head unit or Nav screen? I know you can do track up and down but can you select the artist or song via the head unit?
04-14-2024, 12:30 PM | #4 |
Rep 410
My radio was non nav…
I had Audiovox system prior to my Bluebus unit. With Bluebus I get a BT selection on my radio but different radios/radio systems may differ. I’d just get the Bluebus…. Bluebus.dev has further info if you follow the various links and dig down.
