04-08-2016, 01:25 PM | #1 |
Rep 211
Drives: 2007 BMW Z4M Coupe
Coilover Install
Guys,
I just got my coilovers and before I take the car apart I want to make sure I have all the parts that I am going to need I have the coilovers with camber plates at the front. Do I need any of the items below: 1) Adjustable Front Sway Bar End Links 2) Rear Adjustable Camber Arms I am running 9.5" front rim and 10.5 rear rim so I know I need at least -2° camber front and rear. Much appreciated |
04-08-2016, 01:36 PM | #2 |
1821
Rep 5,337
IMO those things are stuff that you figure out as you install. No way to tell whether you'll need EITHER until you've installed it and determined ride-height.
The answer is yes, no, and maybe.
04-08-2016, 01:40 PM | #3 |
Rep 211
It's pretty much the same for all of us. I am talking reasonable height that most of us are using.
The one that really bothers me is the front sway bar link. I don't want my car to be sitting on my mechanic's hoist because I am missing those. Thanks |
04-08-2016, 03:03 PM | #4 |
1821
Rep 5,337
Sigh.
Yes. No. And Maybe. You will need end-links if the ride height results in uneven preload. You will need camber arms if you're slammed to the ground. With ZERO variables you've given us, there's nothing else to go on but... Yes. No. And Maybe. Maybe if you provided the actual coil-over system (say, a coil-over that one of us have installed), the actual ride-height you're planning on (the coil-over I have varies in ride height from almost an inch higher than stock at the highest position, to about 1/2 inch lower than stock at the lowest position...Again, that's a HUGE variable), and/or if the installation process ends with both side being of uneven height (say, if you were to corner balance the car and it requires several turns of one collar vs. the other). This is akin to "my car understeers. Help me fix it."
04-09-2016, 02:21 PM | #5 |
salty cowboys fan
6188
Rep 3,419
FWIW, I needed a new set of end links when I installed mine. Not because they didn't fit, but because the boots had worn out. ~60k miles at the time, check yours out
04-18-2016, 08:37 PM | #6 |
Rep 211
I bought the Scale off of Montreal. Turns out they forgot to ship the Sway bar mount - it's adjustable so I am happy.
Because it looks like Scale is very similar to Fortune Auto but not as popular I have one question regarding the rear suspension. Do you need to change the top spring pad or not? Please look at the picture To me that looks way too big of a difference between the two diameters. It's is extreme hard to get in touch with Scale - well it's impossible, so I need some help here. Thanks in advance |
04-19-2016, 06:53 AM | #7 |
Rep 11,668
Pic isn't showing
I assume it's a 2.5" dia spring. There are rear upper perches available from R.Eng Turner et al.
04-19-2016, 11:05 AM | #8 |
Rep 211
04-19-2016, 08:14 PM | #9 |
Rep 211
Got the 2.5" perches, the rear shock mounts and the rear adjustable control arms. I guess when you do a job you do it right the first time.
I've spent a bit too much this season but I hope I get it right. Now I hope I make it all happen before May 15th. |
04-19-2016, 08:54 PM | #10 |
Rep 11,668
Sounds good.
04-22-2016, 12:42 PM | #11 |
Rep 211
Do swift springs settle a little bit? I have 10K front and 10K rear. Does anyone have personal experience how much they'll settle?
It seems like I am going to be adjusting the coilovers all the way down and probably still be too high. Anyone with Fortune Auto coilovers that could chip in with experience. There isn't much difference between Scale and Fortune Auto. Thank you |
04-22-2016, 02:00 PM | #12 |
Rep 11,668
Settling with Swift is negligible.
05-11-2016, 12:26 PM | #13 |
Rep 211
Can someone give me a good BMW shop in the east end of GTA - Scarborough? Or an alignment/suspension shop. By the looks I need to roll my fenders. Something I didn't want to do but I need second opinion and someone that has worked on BMWs and can give me straight and informed answer.
Thanks |
05-16-2016, 06:57 PM | #14 | |
Rep 1,483
- Instagram ->@e91kiter |
05-18-2016, 09:57 AM | #15 |
Rep 211
All done.
05-18-2016, 10:16 AM | #16 |
Rep 1,483
Looks great and love that colour! did you end up rolling your fenders? Makes me want to go out and drive mine, I think I just might do that right now and drive a few twisties for an hour before lunch LOL.
You gotta loose that "Best Buy Auto" frame though.
05-18-2016, 10:19 AM | #17 |
Rep 211
Agreed. Will be done
05-18-2016, 10:22 AM | #18 |
Rep 1,483
FYI post the photos in the Photo section. BMW Z4 Photos, Photoshops, Videos and other Media
05-18-2016, 01:01 PM | #19 | |
Rep 211
