      10-16-2016, 02:18 AM   #155
AriuSen
AriuSen's Avatar
Drives: Z4M Coupe
If I had this car, i would do this.
It's a piece of art. I must see it in person one day.
Instagram: ariusen26
Youtube: Track vids
crfine88438.00
      10-19-2016, 09:56 AM   #156
Eau_Rouge111
Eau_Rouge111's Avatar
Drives: 2009 128i and 2007 Z4M Coupe
Originally Posted by crfine88 View Post
0042
VRS Cooling Bonnet Installation
Took my time on this one to get it right. Overall very smooth installation. I would rate fitment 9.9 out of 10. Best fitting carbon piece I have installed on any car. Not 10 out 10 only due to a minor flat spot along the nose of the hood. Hard to detect, but should be corrected when I go in for paint. Sort of shocked at how well everything fit really. I was expecting to have to massage the installation a bit as I have seen this with others. Either I got lucky, or VRS put some extra love/time into this piece
Seeing it on the car in raw carbon is very cool. Ultimately I will be painting, so I took a bunch pictures to capture the look
Pros:
  • Mounting locations were identical to OE
  • No adjustments needed at the hinges
  • No adjustments needed at the latches
  • No adjustments needed at the catch
  • Gaps were identical to OE
  • Arcs/Curves identical to OE
Cons:
  • All threads needed to have resin and other materials worked out of them (good idea to clean all threads before installation )
  • Very minor flat spot at the nose (seems to be from how it was sitting in the box, easy fix during paint)
PHOTOS:
I should be working but I find myself amazed at this job and car. Damn!! Congrats!
crfine88438.00
      10-25-2016, 03:03 PM   #157
nemex12
Drives: e60,z4
more pics, bitte
if you want perfection buy a mercedes, or marry an accountant
crfine88438.00
      11-08-2016, 05:59 PM   #158
crfine88
crfine88's Avatar
438
Drives: E86M
0043
0043
Bimmerworld Oil Distribution Block + Oil Pressure Sending Unit
Prepping for further data acquisition upgrades, needed to install an oil pressure sending unit. Chose the OE location just below the oil filter housing. This is a tight area work in, but the Bimmerworld distribution block made installation a breeze.
Pros:
  • Allows for three sending units (including OE)
  • Allows infinite angle adjustment (this is key to avoiding all the other stuff in this already crowded location)
  • A very complete kit (including gummy bears, a big win for my 4 year old daughter )
  • Bimmerworld provided surprisingly fast order processing and shipping, twice. ( cross threaded the first one I received by applying way to much torque during installation)
Cons:
  • None observed
PHOTOS:
      11-08-2016, 06:01 PM   #159
Drives: M2 Comp
Have the same block, it works great!!
crfine88438.00
      11-13-2016, 01:27 PM   #160
Reborn_
Drives: 2007 BMW Z4MC
Awesome build, and great thread. Keep them coming!
crfine88438.00
      11-14-2016, 03:37 PM   #161
kihtay
kihtay's Avatar
18
Drives: 98 hellrot red m3
Wow!! What an amazing build, and even more amazing write up!! I am really loving the front bumper on it! Where did you find that through?
Also noticed the AZ plates Wooo!!
crfine88438.00
      11-14-2016, 05:19 PM   #162
crfine88
crfine88's Avatar
438
Drives: E86M
Thank you! The bumper is a two piece add on from VRS Japan.
gotta love the year round driving in AZ, especially the cool winter months
      12-02-2016, 05:34 PM   #163
crfine88
crfine88's Avatar
438
Drives: E86M
0044
0044
Exhaust Upgrade: KKS Performance Titanium Axle Back
Looking for minimal drone and lightweight, KKS was the way to go. The weight of RPI's with drone levels slightly more than Super Sprint Powerloop. Ultimately planning tor running electronic dump valves to open and bypass mufflers for wide open Motorsport sound & close the valves for more cruising friendly drone and volume levels. KKS axle backs fit perfectly into this plan
Pros:
  • Light weight construction
  • Minimal drone
  • Enhanced tone
  • Aesthetically, titanium looks great next to the Imola Red!
Cons:
  • Can size and configuration prevents running tip up high and tight in proximity to bumper cut outs without making contact with heat shield (not a big deal because I plan to center tips between bumper and VRS diffuser.
PHOTOS:
gds52886.00
      12-03-2016, 03:46 PM   #164
Drives: M2 Comp
I didn't realize that the cans were so big on the KKS Chris!
Is there any left that you haven't tried yet?
crfine88438.00
      12-03-2016, 07:07 PM   #165
EMKOOP
Drives: M3
We need to build this man a statue
crfine88438.00
      12-05-2016, 10:46 AM   #166
crfine88
crfine88's Avatar
438
Drives: E86M
Might finally be done trying axle back configurations, really digging the KKS
      12-05-2016, 11:30 AM   #167
Beedub
very good pickup!! super jealous!!
crfine88438.00
      12-18-2016, 01:15 PM   #168
Shutterspeed
Shutterspeed's Avatar
Drives: 2008 Z4 M Coupe
Update this thread with the Varis rear diffuser install i saw on Instagram for these good people!!!
crfine88438.00
      12-18-2016, 07:58 PM   #169
crfine88
crfine88's Avatar
438
Drives: E86M
Soon, need to put together a write up
      12-18-2016, 07:59 PM   #170
crfine88
crfine88's Avatar
438
Drives: E86M
Teaser from Instagram
      12-19-2016, 06:15 PM   #171
EMKOOP
Drives: M3
G-O-R-G-E-O-U-S
crfine88438.00
      12-19-2016, 06:54 PM   #172
tiltmode43
I plead the 5th.
tiltmode43's Avatar
Oh man, this is pretty! Hopefully you can feel the jealousy all the way from here.
What's your IG? Don't recall seeing it.
-Matt
crfine88438.00
      12-19-2016, 07:14 PM   #173
crfine88
crfine88's Avatar
438
Drives: E86M
G-O-R-G-E-O-U-S
Thank you!
      12-19-2016, 07:14 PM   #174
crfine88
crfine88's Avatar
438
Drives: E86M
Thanks!
IG: CSLFMotorsport
      12-20-2016, 03:25 PM   #175
Beedub
does that all bolt to stock locations ?? very impressive stuff from varis as always.
crfine88438.00
      12-20-2016, 06:37 PM   #176
crfine88
crfine88's Avatar
438
Drives: E86M
Sort of. No modifications needed. Uses some factory mounting points and some additional brackets attached to factory mounting points. Sys 1 is a little bit of a pain to install due to all the different hardware. Sys 2 is a piece of cake
