10-01-2015, 09:45 AM | #2 |
Rep 11,667
great stuff!
10-01-2015, 11:55 AM | #3 |
Rep 2,782
I've hit 100k in two Z's. The first was my non-M, which has only required a few things beyond regular oil changes, and nearly everything could be considered standard maintenance:
- Belts - Starter - Fluids - Battery - FCABs - Window Regulator - Shift Knob - Windshield - Alignment - Spark Plugs - Valve Cover Gasket - HID Bulb - Both Side Mirrors (auto-dimming fluid leaks) - Oil Filter Housing Gasket - Dampers The M has required a little more: - HID Bulbs - Fluid Changes - Brake Duct - Battery (x3) - Steering Wheel Trim - Shift Knob + Light - Alignment - Valve Adjustment - Spark Plugs - Rear View Mirror - Vanos Rebuild - Rod Bearing - Motor Mounts - Alternator (+ Reprogramming DME After Failure) - Fuel Pump / Filter - Weather Stripping
10-18-2015, 11:05 AM | #11 |
Rep 1,908
Glad to see all the 100k cars. I'm at 72k right now and that has always been a concern for me since I would like to keep the car forever but in the back of my head I'm always thinking how long she will last.
11-03-2015, 08:12 PM | #13 |
Rep 588
Drives: 2007 Z4M Coupe
Great thread. I'm at 84k. Bought it with 41k two years ago. Daily driving and just driving for fun. An all around great car. I bought the car to drive not to keep the miles off! Glad to see I'm not the only one who enjoys driving their cars.
2021 m240i on order
11-11-2015, 08:56 PM | #15 |
Rep 1,253
Drives: F10535, E90M3, E30M3, E28M5
Garage List 2017 Alpina B6 GC [0.00]
2014 535xi M Sport [0.00] 2014 X3 3.5 M Sport [0.00] 2011 M3 E90 [9.74] 2007 Z4 M Coupe [7.00] 1990 M3 [9.50] 1988 M5 [10.00] |
Nice to see the S54 is doing well for everyone!
ESS VT-1 550 | M24 Oil Cooler | Fall Line Half Cage | RaceTech 4009W | 6 pt Harness | Lifeline Zero 360 Fire Suppression | Rear Seat Delete | Motion Control DA Dampers w/remote reservoirs | 900/650 Hyperco Springs | RD Sport Sway Bars | Brembo 380 BBK | GC Camber Plates | Hoosier R7 | Eisenmann Sport | Stack Gauges | Painted Challenge Front Lip | Painted ZCP Rear Spoiler | Xpel Ultimate Film | LuxAngelEyes |
11-20-2015, 03:42 PM | #16 |
John 14:6
59
Rep 587
My 03 Z4 hit 100K early last year. I'm currently at 101, 961 and it runs like a champ, besides the low mpg (gas guzzler for some reason). I just change the oil and recently changed spark plugs. Driver seat was jacked up (rips and tears) and plastic parts (interior) are starting to break. Other than that, solid vehicle!!!
Mods: Eibachs/Konis, Eibach camber kit, JTD RSMs, 19" WedsSport SA67, Hamann headlight trim, Aero front bumper, Aero sides, AC Schnitzer side deflectors, Hella euro taillights, Hardtop, Dinan strut & supplemental bars, RD Sport intake, Dinan Stage 2 Software, RPI scoop, Bastuck catback exhaust, Radenergie CF engine cover... |
02-08-2016, 02:55 PM | #17 |
Rep 243
I'm at 140k.
Latest issues besides having to replace waterpump, valve cover gasket, ac repair, bushings, 2 broken exterior door handles, emblem replacements, new rims (old ones cracked) and tires, broken convertible top (i can do it by hand..), broken passenger window regulator, dry rotted lower intake boot, new headlight bulb, SRS airbag light, windshield weather stripping, rear 3rd light broken, one more... the CVV line replacements.. jeez.. I've put a lot of work into this. Edit+ Had to change starter, battery, alternator, and inner roof lining came off. suspension bushings had to be replaced too This is a great list for anyone buying a new z4 (e85) to check. I'll actually use it for my next purchase. Last edited by ljkiter; 03-04-2016 at 08:57 PM.. |
02-09-2016, 09:39 AM | #18 | |
Rep 243
02-20-2016, 06:18 AM | #19 |
Rep 2
I just drive over 162'000km (100K miles) with my Z4, I buy it 3 year ago at 37'000km (23K miles), I drive a lot ~40'000km (25K miles) per year.
Specifications Z4, 2004, 3.0l, roadster, Euro, 6 speed man, business nav, zenon, gray with red leather interior. Retrofit Cruise control Repairs (since I own it) 4x new M-technic coilover 4x new brake disc and pads 6x sparkplugs Audio Intravee + ipod 60Go Pictures with some friends Last edited by torrentmt; 02-21-2016 at 08:53 AM.. |
02-22-2016, 11:54 AM | #20 |
Rep 31
I'm at 244k on my 2003 2.5 Z4.
It is a DD for me and still going strong. Believe it or not I also still have the original clutch. I keep wondering how long it will last Donovan |
02-22-2016, 07:13 PM | #21 | |
Rep 870
Drives: 2006 BMW Z4M Roadster
Salty
02-22-2016, 11:41 PM | #22 | |
636
Rep 3,124
You must be an excellent dancer. I got about 170k out of my MR2's clutch, and I thought that was good. I did tend to drag it on downshifts to throw some stop bias to the rear. This was before the days of ABS.
