10-16-2019, 06:51 AM | #23 |
Rep 410
Thanks! I added your cable to the first post. As you play with some coding, please post back. I'd like to start building up post 3 of 3 with confirmed options.
10-16-2019, 04:16 PM | #24 | |
Rep 264
PS: Tried Parallels also but couldn't manage to boot it up correctly. |
11-01-2019, 02:51 PM | #25 |
Rep 645
Just wanted to share an update from my recent experience:
1. This amazon cable works, there is a switch built in, set it all the way to the right. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 2. Use the Bimmergeek Coding Tools, it did everything i needed, including a working "Manipulation" profile for NCS Expert. Works on mac with VMWare Fusion - Windows 10 3. Basically dug through numerous threads just to find out how to deactivate all amber light regardless off headlight switch position, and to only function as turn signals. Just wanted to throw this out here as there were so many combinations around. This worked for me. ECU Module: LSZ.C36 PIN_20_37_ALS_PO = Set to nicht_aktiv SL_VO_ANSTEUERUNG = Set to nicht_aktiv SIDEMARKER_US = Set to nicht_aktiv Also managed to do M Dynamic Mode with just one change: ECU Module: MK60 TDR = Set to Aktiv Did a couple more, but the guide to them is easily available. Happy to share any specific ones if you reach out. At the same time, i am still figuring out the following: AMP Setting, Mirror Tilt in Reverse, Auto Unlock Doors when the engine is shut off. If anyone has had success, please share! Thanks OP for creating this thread. Mandatory pic for being almost eggless! �� Last edited by CSM3; 11-01-2019 at 09:21 PM.. |
Reborn_298.00 |
11-01-2019, 04:36 PM | #26 | |
Rep 410
The ones you listed, are you asking for help with those? I'd also like help for auto unlock doors when engine is shut off, and even lock doors automatically (haven't gotten that to work). |
11-01-2019, 04:40 PM | #27 | ||||
Rep 645
I can definitely help with auto lock. Basically you also need to code the key memory to auto lock. Will respond here with the specific modules shortly! Thanks again for getting this started OP! |
11-01-2019, 07:09 PM | #28 | |
Rep 410
11-01-2019, 09:15 PM | #29 | |
Rep 645
Module: GM5.C05 VERRIEGELN_AUT_AB_X_KMH: Select the speed you would like auto lock to happen VERRIEGELN_XKM/H_SENDER 1: Select the option to auto lock, and do the same for Sender 2, 3 and 4. Basically this is the coding to tell the key to allow autolocking based on all the keys you might use to start/unlock your car. VERRIEGELUNGSSCHWELLE: Set to Aktiv |
11-01-2019, 09:27 PM | #30 |
Rep 645
Couple more options i did:
1. One Click Unlock all Doors with remote: Module: GM5.C05 Setting 1: FUNKTIONTUERSCHLOSS: Select the option for all doors Setting 2: FERNBEDIENUNG_1: This is the memory setting of your car key, there are four of these, FERNBEDIENUNG 1, 2,3 and 4. All should be set to the option of all doors unlock. 2. Wipers complete cycle (When you shut off the engine, the wipers will complete their cycle and not just stop halfway on the windshield) Module: GM5.C05 Setting: WISCHER_VOLLEND_KLR_AUS: Set to Aktiv 3. One touch indicators: Module GM5.C05 Setting: CYCL_TI_BLK: Select 3 |
11-10-2019, 06:38 PM | #31 |
Rep 208
Drives: 08 Z4 M Coupe
Great guide Reborn_!
I got the cable with the built-in switch and it worked fine.
11-30-2019, 03:50 PM | #32 |
Rep 208
If you upgrade your DRL angel eyes to LED, here's how you can disable warning lights.
1. Disable bulb monitor for Angel Eye DRL bulbs: Module: LSZ Setting 1: WARMUEBERWACHUNG_FL - HOT MONITORING OF HIGH BEAMS set to nicht_aktiv - not enabled Setting 2: KALTUEBERWACHUNG_FL - COLD MONITORING OF HIGH BEAMS set to nicht_aktiv - not enabled
Last edited by bwright657; 05-28-2020 at 02:22 PM.. Reason: Correct module for coding |
12-10-2019, 01:51 PM | #33 | |
Rep 775
01-23-2020, 12:44 AM | #34 |
E86 M Coupe
265
Rep 406
Well thanks reborn_ ! Going to attempt some of these coding soon!
04-14-2020, 09:39 AM | #35 |
English Member
25
Rep 99
Drives: 2006 Z4M Roadster
I have a Carly which has been great to add some extra features, but I've really got to give this a go one day. There are things I want to do which Carly doesn't have the functionality for, such as turning off all the bloody amber lights on the front when the lights are on.
05-05-2020, 12:26 PM | #37 | |
Rep 1,483
Drives: 09 E91 328i & 07 E86 M
2007 #1432 ///M Coupe Silver Gray - KW V3 Coilovers - AFE Intake - Strong-Strut Brace - Status Grupee Headers - Super Sprint Race Exhaust & Xpipe - 19" Avant Garde M359 - Stoptech 380 6 pot BBK - EPIC Motorsports Tuning ////////////2009 328xi M-Tech E91 manual 6spd
- Instagram ->@e91kiter |
05-08-2020, 12:14 PM | #38 | |
Rep 3
Also here's a video that shows the switch positions on the USB cables that have the switch. https://www.youtube.com/watch?v=VBW4vP41Qyc My Z4 will only fully connect in switch position K Last edited by g2096; 05-08-2020 at 12:21 PM.. |
05-13-2020, 11:06 AM | #40 |
Rep 27
Has anyone figured out how to disable or otherwise bypass issues with the secondary air pump and secondary 02 sensors? I'd like to drop my SAP and get rid of the code for my headers.
05-16-2020, 02:35 PM | #42 |
Rep 2,560
I have ista-d working on my F25 (ethernet obd interface), but have not tried it on my E86 (dcan obd interface). I assume I would need to change some settings. I have a old laptop set up with NCSexpert & inpa for my e86/e39 and a newer laptop set up with e-sys & ista-d for my F25.
What problem are you having? |
05-18-2020, 05:57 AM | #43 | |
Rep 30
So I managed to get it working and deleted transport mode. took some tweaking of EDIABAS and ODB config file. Not sure if I changed the switch position on dcan cable. being the nice guy I am i thought i would do a guide and video and therefore wiped my laptop to reinstall everything and DOH. Something not working. I created a video and uploaded here: https://www.dropbox.com/s/wud6dmd2yl...error.mkv?dl=0 |
06-10-2020, 06:20 AM | #44 |
Rep 165
Hand held scanner
Sooo looking to invest in a hand held scanner is the Foxwell unit a good all rounder to use. I see on the bimmergeeks they have one, ProTool is ir? but not for the E85 / E86 chassis. The cables etc coming from them and will download the software in the trusty laptop. But looking to acquire a hand held well, just 'cos we can.
Any and all advice taken on board, thanks for reading, Bill |
