      04-29-2015, 05:25 PM   #23
BGR
Drives: C7 GS 7MT; e90 M3 6MT
I wanted to bump this thread as I just swapped mine.
Center bolt is a 5/8" of all things. I've also never seen clips like what are on the air bag. The screwdriver slides up the bottom and the whole bit slides up.
      04-29-2015, 05:28 PM   #24
BGR
See attached pic
      10-13-2015, 04:49 PM   #25
Sterling Roadster
Drives: e85 Z4 3.0i & e92 328i
Originally Posted by BGR View Post
See attached pic
Quick question, while I have everything apart should I be lubricating or replacing anything?
I ask because my E36 had the squeaky wheel problem.
      10-13-2015, 05:44 PM   #26
BGR
See attached pic
I did not. It's been a few months, but I don't even know what you would have access to to grease up.
      10-15-2015, 12:40 AM   #27
2288
Reviewed my steering wheel few times over the years, never had to grease anything. Money shot:
      10-17-2015, 02:19 PM   #28
Sterling Roadster
Okay cool, may be an e36 thing. thanks!
      09-12-2020, 12:01 AM   #29
CrazyOneToo
1999 E46, 2002 E53, 2007 E85....all in progress
Drives: 2007 Z4 3.0Si Roadster
Originally Posted by BlackSapphireZ View Post
before you begin, make sure you have a valid reason to do this...and only reason would be to install an M steering wheel also unplug the battery for a good amount of time. I left it for 5 minutes, others may do it for 30.
oh yea and don't sue me if you screw up. i'm not responsible for your mistake!
*it is possible for you to install any 3 series airbag/steering wheel combo if you like. Also the X series I believe fits as well*
moving on...
1)find the little holes by 10 and 2 o' clock position behind the steering wheel it self
2)Insert small and long screw driver into the hole. and you have to push the bar towards the center. it's really hard to find(was for me at least)
3)Airbag will "pop" out and hang..it's okay don't freak out. and start to unplug the wires. when unplugging the wires from the airbag, use a very small flat head for the connector...you wont be able to use your hands for that more than likely. Also if you have those black connectors in the steering column, it means you may add steering wheel controls(if i remember correctly)
4)take off the center nut which is pictured above, and steering wheel should come straight out. Make sure when you are RE installing, line up the notches on the wheel and the column.
Yes I know, I am late to the party. I am also wanting to swap my steering wheel but just for one that is in better condition.
Is the clock spring fixed in place or is there a possibility of it coming loose and unwinding after the steering wheel is removed?
Thanks
1999 328i - 2002 X5 3.0i - 2007 Z4 3.0i...always in progress.....
