09-06-2019, 10:13 AM | #1 |
I like Coffee & Z4s.
106
Rep 366
Drives: 2007 Z4MC
Clunk noise when disengaging clutch while engine is applying torque to drivetrain
y'know the noise I'm talking about? it often happens when you're in 2nd or 1st gear, and the car is engine braking and you press the clutch pedal.
I read somewhere that this is normal, but what causes this noise? |
09-06-2019, 07:29 PM | #2 | |
Rep 264
Not sure if links to other forums are welcome here or not.. so just copy-pasting it
09-09-2019, 04:06 AM | #3 |
Down Under!!
1621
Rep 4,295
Hmm I don't think it's normal at all. Mine never used to do it, now does it all the time. How many miles on the car. Refurbing my driveshaft due to this. Guibo, hanger and most likely culprit , the CVJ.
09-20-2019, 03:14 PM | #4 |
106
Rep 366
Drives: 2007 Z4MC
That snippet sounds a lot like sales BS. "acoustic feedback that can be interpreted as a clunking noise" lol. it is definitely a clunk.
Also I have a lightweight single mass flywheel so it's definitely not just the DMF. |
09-20-2019, 08:24 PM | #5 |
Rep 264
Well.. I had a worn out DMF replaced on my previous BMW and it did improve the sound during gear switch.
But since you don't have DMF here is another (probably even more common) clunk generator PS: and I assume you've checked axles and guibo already |
09-21-2019, 09:08 PM | #6 |
Rep 49
Drives: Z4MR
Could be clutch disc spline wear.
09-22-2019, 10:09 PM | #7 |
Down Under!!
1621
Rep 4,295
Hmm. I accidentally deleted something here??
Powered by Last edited by Vanne; 09-23-2019 at 11:53 PM.. |
09-22-2019, 11:02 PM | #8 |
106
Rep 366
Drives: 2007 Z4MC
Why do you say most probably the CVJ?
09-23-2019, 03:33 PM | #10 |
106
Rep 366
Drives: 2007 Z4MC
Yeah, I am just wondering why you think that is the most likely cause of all the possibilities. I don't remember my wheel wiggling like that last time the car was on a lift - but I will try the wheel wiggle test more vigorously next time the car is on a lift and report back. Might be a while since I don't have convenient access to a lift.
09-23-2019, 11:52 PM | #11 |
Down Under!!
1621
Rep 4,295
Well that list is in a cheap to expensive to replace parts/labour.
Only reason I am saying CVJ, is that is because that's what mine was/is. Which sounds EXACTLY like what your describing. |
01-13-2020, 03:50 PM | #12 |
106
Rep 366
Drives: 2007 Z4MC
Yep, I have the exact wiggle problem described in the video. Thanks Vanne!
