07-06-2017, 04:01 AM | #23 | |
The Builder
14
Rep 80
06 Z4MC
H.N.I.C. Don't ask what that stands for |
07-06-2017, 05:05 AM | #24 |
Rep 45
Drives: 06 Mcoupe and LRPE M3
NYC
07-06-2017, 07:43 AM | #25 |
Rep 186
This is probably a dumb q but with the angle of the diffuser so aggressive, doesn't it eliminate downforce? ie. lift the rear wheels?
As I understood it, the bottom plate is meant to smooth things out and the vertical fins are to provide stability (looking for input from aero gurus) |
07-06-2017, 07:57 AM | #26 |
Rep 5,328
is this functional?
07-06-2017, 09:38 AM | #27 |
Proud E86M Owner
79
Rep 650
Im located in South Cal too "91748" Not too far away.
2007 Z4///M Coupe Monaco Blue (Weekend + Track)
2018 S1000RR San Marino Blue Wrap (Weekend + Commute) 2016 Honda CR-Z EX Jet Black (Daily Commute) 2008 Kawasaki ZX6R Plasma Blue (SOLD) 2008 Z4///M Roadster Space Gray (SOLD) |
07-06-2017, 12:49 PM | #28 |
Rep 270
@ariusen whatever happened to the track spec diffuser.
http://www.zpost.com/forums/showthread.php?t=1339025 |
07-06-2017, 12:53 PM | #29 | |
Rep 1,923
That?s why I?m going with this diffuser.
07-06-2017, 01:23 PM | #30 | |
Rep 11,667
To create downforce under the car you really need to extract air before it gets to the back. This can be done with NACA ducts and tubing to extract upstream. Or, minimizing the air that gets under the car in the first place with splitters and reducing the gap under the front bumper. The FW angle looks aggressive, but it basically follows the same line as the OE under tray. A diffuser angle is considered too big when it causes the air to separate from the plane of diffuser. It has to follow the plane to work effectively. Since this one closely follows the stock piece I don't think it should be a problem. Ideally a curved plane works best and that is the one shortcoming of the FW, but that does not mean it doesn't work well. A diffuser is not really as much about down force as it is about minimizing turbulence behind the car and thus less drag. Yes, the vertical fins are to reduce side wash which disturbs the underflow. One of the excellent features of this diffuser is the large fin that catches the wash from the rear tires and directs it back. BTW, I have already purchased one of these, otherwise I would be in on this GB.
07-06-2017, 01:50 PM | #31 | |
Admiral
240
Rep 314
07-06-2017, 02:01 PM | #32 | |
Rep 11,667
But it depends on which mufflers are on the car. There is a thread posted by the Hack where he had a fair amount to trim with the OE mufflers. I have Stromung mufflers and expect a little trimming but not much. There is no cutting of the bumper.
07-06-2017, 03:52 PM | #34 | |
Rep 1,923
NavZ4.00 |
07-06-2017, 03:53 PM | #35 |
Rep 1,923
07-07-2017, 08:02 AM | #37 | |
Rep 11,667
It bolts up to the dual exhaust cutouts for the M bumper.
07-07-2017, 10:13 AM | #38 |
Rep 270
Perhaps check out Driveway Labs or Velox Motorsports. They both make rear diffusers for the FRS/BRZ platform. I figure the Z is pretty close to the same size. And might be able to set something up for Z specific one.
07-07-2017, 10:39 AM | #39 |
Rep 528
Drives: E86 Z4MC; E92 M3
ah...you can count me in as a definite participant. I'm in Ontario, Canada but if there's significant savings can take delivery in NY state.
E46 M3 Coupe 6MT Jet Black/Cinnamon GONE
E85 Z4M Roadster Imola Red/Black GONE E90 M3 Sedan 6MT Jerez Black/Fox Red GONE E86 Z4M Coupe Interlagos Blue/Black E92 M3 Coupe 6MT Interlagos Blue/Fox Red - Build Thread |
07-08-2017, 01:28 PM | #40 |
Rep 45
How many people we got here so far,let's get it going I need this diffuser?
07-10-2017, 07:21 AM | #41 |
Rep 912
07-10-2017, 07:53 AM | #42 |
Rep 11,667
...ahhhhh
I see a dual exhaust mod in your future.
07-11-2017, 09:07 AM | #44 | |
Admiral
240
Rep 314
