06-27-2017, 10:48 PM | #1 |
Rep 12,565
Help: Mysterious Soft Brake Pedal
Would be great if anyone can provide insight on this mysterious soft brake pedal I've been experiencing during these past 2 weeks. First occurred when entering pre-grid at NJMP. As I pull up to my spot and try to slow down the pedal went all the way to floor. Pumped the brake and everything felt 'normal' but needless to say I didn't set any track records during that session.
Thought it was an isolated event but it happened again 2x more... once as I pull up to a red light and once as I was backing into my parking spot. For what it's worth, pads and rotors have tons of life left and I did a full flush 2 weeks ago, followed with 4 corner bleed this past weekend. Could it be the master cylinder failing? Someone on BFC mentioned checking the wheel bearings as that could cause knock back. Haven't had a chance to pull the wheels off so I'll do that next. |
06-27-2017, 11:02 PM | #2 |
1621
Rep 4,294
Wow.. man, i had this exact same thing when i took my car in for my BBK upgrade. As i drove into the garage, pedal went as you said all the way to the floor, scared the shit out of me, then re-pumped and was back to normal.
I instructed my mechanics to check the whole system during the BBK install, after telling them the story. They found nothing and were unable to reproduce said event.. at all.. period.. I instructed them to pull the master cylinder and refresh all the seals. Ive since driven the car after the new BBK install, new high temp fluid, for probably 500 KMS, with zero events.. The seals in the master cylinder/actuator were also found to be in great shape... Fricken crazy thing eh?? edit: wheel bearings to cause knock back?? man those would have to be some seriously rooted wheel bearings.. and thats certainly not it for me, new bearings front and back less than 10K kilometres..
Powered by |
06-28-2017, 01:15 AM | #3 |
636
Rep 3,124
Haven't experienced this with the Zed, yet, but on all 3 of my Suburbans it was master cylinder.
06-28-2017, 08:06 AM | #4 | |
Rep 12,565
Yea I didn't realize this but apparently if the rotor deflects enough laterally it can cause the pistons to move in so when you push the pedal most of the travel is used to push the piston back to the rotor. |
06-28-2017, 08:07 AM | #5 |
Rep 12,565
Was it the just the seals or the cylinder itself?
06-28-2017, 11:12 AM | #6 |
636
Rep 3,124
I think the seals are the only part that has any probability of failure, but I've never actually examined or replaced them, so I don't know 100%.
On something like a Suburban, you don't replace the seals, you just run up to AutoZone and get a rebuilt.
06-28-2017, 01:34 PM | #7 | |
Rep 11,667
06-28-2017, 09:52 PM | #8 |
Rep 196
Take a close look at the ears of the brake pads themselves. Since we push back the pistons almost all the way into the slave cylinder when we swap from street to race compound pads, there is sometimes more space than needed especially if the race pads have some wear on them.
If you don't pump your pedal before reinstalling your wheel, you may miss the time where your pad falls over onto it's side and becomes wedged against the rotor. The bottom ear is now bent over as top of the pad is leaning against the rotor. The metal backing plate effectively becomes a spring and returns the piston to it's original position, but hasn't advanced the pad towards the rotor. That'll cause the soft pedal with a long travel. I know this problem so well because I went through a set of R-4s because of this. Now I pump the pedal and ensure that the piston and pads are tight against the rotor with no binding. Hope this helps!
06-28-2017, 10:04 PM | #9 | |
Rep 758
I had replaced the rotors when I installed the pads, and an out of line rotor can definitely give you kick back, and I somewhat suspected that first, but it didn't explain why it was intermittent. Same with a bad wheel bearing. The way I finally found it was the pads was driving the car up and down our street and lightly testing if I had full pedal. When I got the start of feeling like it was going to be a "long" pedal I used the e brake for braking, got the car back into the garage, on the jack stands, pulled the wheels and visually inspected each caliper to see where the pads were sitting and how much if any gap had developed between pads and rotors. I had about 1/16" on each of the front calipers and by experimentation I could see the pads weren't locked into the pistons. Replaced the Ferodos whith some EBC Yellows (because I could get the next day Amazon Prime and I had a track day 3 days from then), and problem gone. 1/16" doesn't seem like a lot but when you think about when you replace brake pads and have pushed the pistons all the way back into the caliper you have maybe 1/8" of clearance when you put the caliper back over the rotor. It usually takes 2 or 3 full pedal travel pumps to get the calipers refilled and the pads against the rotors so getting almost to the floor on one pump with 1/16" isn't unreasonable. 3002tii, I think I'd be looking to see if you've had a pad retainer spring break on one of the inner pads which would let a pad drift out of the piston and give you "knock back" or push back, particularly if what you felt is an initial long pedal travel like you had no brakes and then firm braking after a pump. If you had some brake feel but it was spongy until you pumped and then it got firm, I'd be looking at master cylinder.
Top Down 365
3002 tii2281.50 |
06-28-2017, 11:01 PM | #10 |
1621
Rep 4,294
Intresting.. with me there was no brake feel at all, just like you guys said, when your pumping to push the pad to the rotor.. having my fingers crossed that what it was. Either way, since then i now have a completely new brake system.
Powered by |
06-29-2017, 12:52 AM | #11 | |
Rep 12,565
06-29-2017, 06:30 AM | #12 | |
Rep 758
It does certainly suck! The Ferodo's were the most expensive brake pads I've ever bought to date. I've tried reforming the pad clip to try to get them to hold in place, but no success. They were special order for the 3.0si so it was a no refund, no return purchase. At best I might be able to wrangle another set out of them with some kind of proration charge to me, but at this point I'm done with Ferodo's regardless so moving on. Lesson learned. Side note: I did leave them in the rear, and they were somewhat short lived, so even if I hadn't had the spring clip issue I think I would have been back where I am with the Hawk pads again.
Top Down 365
06-29-2017, 07:30 AM | #13 | |
Rep 12,565
Now I have more reason to try winning Hawk contingency at my next event. |
06-29-2017, 09:12 AM | #14 | |
Rep 1,373
Are you on stock calipers or aftermarket? Do you have after market sway bars?
07 Z4 M Coupe AW/IR |
06-29-2017, 10:07 AM | #15 |
Rep 12,565
Stock brakes and sways
06-29-2017, 11:45 AM | #16 | |
Rep 758
I know several people that run the PFC 08's on their track cars and really like them. I haven't gotten much feedback on autocross use though...
Top Down 365
07-06-2017, 09:12 PM | #17 | |
Rep 12,565
