      06-22-2017, 05:09 PM   #1
tominizer
tominizer's Avatar
Drives: 2007 Z4M Roadster
Complete Fluid Maintenance
I think I'm going to jump on this one really soon as the PO didn't keep the best records. So why not restart the process. And I just brought her out of hibernation. Just wondering if anyone has posted up anything relating to this all in one place. I didn't see anything but then again as I get close to 50 years old, when I search the forums I often skate right past stuff right in front of my nose.
Here's what's on the list...... for my Z4M roadster.
Replace both belts - OEM BMW
Brake fluid
Clutch fluid
Transmission fluid
Rear Differential fluid
Engine oil
Coolant
      06-22-2017, 10:26 PM   #2
KevinM
KevinM's Avatar
2936
Drives: 2002 M5;2007 M Coupe;2020 M2C
2020 M2 Competition  [10.00]
2007 E86 M coupe  [8.38]
2002 E39 M5  [9.00]
Brake fluid
Clutch fluid
Transmission fluid
Engine oil
Coolant
Here is a start: http://www.zpost.com/forums/showthread.php?t=537104
Not sure what the clutch fluid is.
2020 F87 M2C Hockenheim Silver/MT
2002 E39 M5 Sterling Gray/Caramel
2007 E86 Z4M Coupe Silver Gray/Black
2021 Kia Telluride (hauler)
      06-22-2017, 10:38 PM   #3
conceptautogroupla
Drives: Z4MC
The clutch fluid is the same fluid/reservoir as the brake fluid. You just bleed the clutch from the bottom of the car.
      06-22-2017, 10:47 PM   #4
conceptautogroupla
Drives: Z4MC
-Transmission fluid : OEM BMW 75w90 MTF-LT3 (buy 2 liters fill till pours)
-Differential fluid : OEM is pricy $160, but I've been using Liqui-Moly Fully Synthetic Limited Slip Differential Fluid 75W140 (buy 2 liter fill till pours) It works amazing, for half the price.
-Brake fluid : OEM recommended unless you plan on tracking it (buy 2-3 bottles to flush out entire brake system and clutch)
-Coolant : OEM recommended of course
-Engine oil : 10w60 Castrol or BMW brand (shell) w/oem filter
EcsTuning.com has all these products at great prices! All in stock too. Should cost you around $300-350 for all the fluids (recommend changing the diff (2)/trans (2)/oil pan plugs too)
      06-23-2017, 09:53 AM   #5
Mirko
Mirko's Avatar
Would you guys recommend "Royal Purple 01512 Synchromax High Performance Synthetic Manual Transmission Fluid" as a substitute?
      06-23-2017, 10:41 AM   #6
rockstar93
rockstar93's Avatar
Drives: E86 Z4MC; E92 M3
That's what I have in my coupe and I love it. Big difference over the OE fluid (that's in my roadie) in terms of feel, especially with the 1-2 shift.
E46 M3 Coupe 6MT Jet Black/Cinnamon GONE
E85 Z4M Roadster Imola Red/Black GONE
E90 M3 Sedan 6MT Jerez Black/Fox Red GONE
E86 Z4M Coupe Interlagos Blue/Black
E92 M3 Coupe 6MT Interlagos Blue/Fox Red - Build Thread
      06-23-2017, 10:52 AM   #7
yousefnjr
salty cowboys fan
yousefnjr's Avatar
6158
Just put this in mine about a month ago, so far so good
Would NOT recommend Royal's MaxGear oil in the diff though. It says on the bottle it has FM added, but it was groaning like a mother. Switched back to redline 75w140 and she's quiet again
      06-23-2017, 12:10 PM   #8
rockstar93
rockstar93's Avatar
I've heard the same thing about this on the E46 M3 side, quite a bit of complaints about the RP Diff Oil making noises. Redline seems to be quite popular on the E46 side as well.
      06-23-2017, 12:57 PM   #9
elerner61
elerner61's Avatar
157
Drives: '07 Z4M Roadster
+1 for Royal Purple Synchromax in the tranny. I've got over 30K miles experience with it (just changed at 60K last fall) and it has been great. Smooth shifts even in sub-freezing temps.
      06-23-2017, 03:05 PM   #10
dc_wright
dc_wright's Avatar
249
Drives: 2006 Z43.0si Roadster
Sometimes with an LSD when you switch formulas the friction modifiers in the new fluid have to displace the friction modifiers from the old formula that have saturated the LSD clutch discs. The LSD can be quite noisy until this happens and it may take some time (multiple hundred miles) to get a complete change of FM in the LSD clutches. You have to really have faith the new lube is worth it to have the patience to wait it out....
Top Down 365
      06-28-2017, 10:26 AM   #11
tominizer
tominizer's Avatar
Stole this from the "other" thread link noted above.......
2006-08 Z4 M Roadster / Coupe
Engine Oil
Volume : 5.5 litres
Suggest Interval :
Recommended :
Castrol TWS Motorsport SAE 10w-60 Synthetic
Castrol Formula RS 10w-50 Synthetic
Liquimoly SAE 10W60 Synthetic Race Tech GT1
Parts :
Engine Oil Filter BMW PN # 11 42 7 833 769
Engine Oil Filter O-ring PN # 11 42 1 741 000
Oil Pan Plug PN # 07 11 9 904 550
Oil Pan Plug Washer PN # 07 11 9 963 151
Transmission Oil
Volume : 1.5 litres
Suggested Interval :
Recommended :
Catrol MTF-LT-2 PN # 83 22 0 309 031
Options :
Amsoil 5w30 Manual Syncromesh
Amsoil 75w90 MTF
1/2 Redline D4ATF & 1/2 Redline 75w140NS Gear Lube.
Royal Purple
Pentosin MTF2
Parts :
Screw Plug with Gasket Ring PN # 23 11 7 531 356
Differential Oil
Volume : 1.1litres
Recommended :
Castrol SAF-XJ PN # 83 22 1 467 993
Castrol SAF-XJ + FM PN # 83 22 2 282 583
Options :
Amsoil Severe Gear 75W140
Redline 75W140 GL-5 Gear Oil
Parts :
Notes :
Find a parking lot and do several tight circles in both directions to aid lubing.
Brake Fluid
Volume : 1 litre
Power Steering Fluid
Volume :
Coolant
Volume : 10.7 litres
Suggest Interval :
Instructions for Oil/Inspection Reset
Insert Key
Hold Trip Reset Button and turn ignition to first position
Hold Trip Reset Button until display shows "Inspection Reset/Oil Change Reset"
Release and Hold Trip Reset Button until Reset flashes
Release and Press Trip Reset Button once
Release and Press Trip Reset Button again
Next oil service interval will be shown and disappear
Oil service lamp is now reset
