08-20-2016, 04:15 PM | #1 |
Rep 139
searched ALL OVER - inspection 1 or 2?
Hey guys, I'll keep it short, but I have to say I have searched far and wide, using Google, on this site, you name it. One of the problems finding an answer to this is the search terms you have to use.
Anyway, question is fairly simple. I own an '07 Z4 M Coupe and bought it just six months ago with about 100,000 miles on it. When I start the car, it says "Inspection" 5700 miles or so. How the heck am I supposed to know if it's inspection 1 or 2? TIA |
08-21-2016, 08:52 AM | #2 |
Rep 165
the local BMW dealer should be able to tell you fairly quickly - some will do it with a phone call - others will require you to stop by with your key fob. That's assuming that the inspections were all done at dealerships and not done by the owner him/herself or an independent garage.
The basic rule of thumb is that inspections are done around 30k miles. I tend to get a few miles less. The computer calculates gas used to determine when inspections are required. So in your case, inspection 1 at 30k - perhaps 28k?, inspection 2 at 60k - perhaps 56k?, inspection 1 at 90k - perhaps 84k?, inspection 2 at 120 - perhaps 112k?. I would believe you are due for an inspection 2. |
08-21-2016, 10:03 AM | #3 |
Rep 18,736
Inspection 1 is the most comprehensive of the two, so I'd recommend just starting with a baseline of Inspection 1 service and go from there.
08-21-2016, 11:12 AM | #4 | |
Rep 2,866
No - Inspection 2 is the most comprehensive of the two. |
08-21-2016, 01:43 PM | #5 | ||
Rep 139
So, it sounds I can just "decide" that it represents Inspection II (I was going to do everything anyway, valve adjustment, already flushed brake fluid, plugs, etc.). In about 30k miles it will again say nothing else but "INSPECTION" and I'll consider it to be 1. Quote:
Thanks all! |
08-21-2016, 02:48 PM | #6 | |
Rep 165
08-21-2016, 02:59 PM | #7 |
Rep 18,736
Your right. My bad, I'm a bit rusty on the old school inceptions . But the point is do the max so everything is covered.
08-21-2016, 05:13 PM | #8 |
Rep 987
Also if you are at all handy with tools then doing the valve adjustment as a diy to save money really isn't all that bad.
CSL headers*Euro cats*Arqray exhaust*DKF hangers*Evolve Tune*Genuine CSL rims*10mm Macht Schnell front spacers*modified Hamann bumper*Tekarbon 2X2 CF spoiler*Turner CF grills*AS SSK*KWV3*OEM Strut bar*Rogue RSM*Polyurethane anti-roll bar bushings*Deka ETX30L battery*Nav Video module*front & rear cameras*Ipod module*stubby antenna*R-Dash LED license lights*LED Ziza interior lights |
08-22-2016, 07:22 PM | #9 |
Rep 139
Oh yeah, I plan to keep this car a long time and I'll save thousands over the long run by doing it myself. I'm sure the first time I do it will take me forever but I'll learn
