06-09-2008, 01:54 AM | #23 |
BMW Novice
69
Rep 237
Drives: M Coupe
Now I don't know what to do???
06-09-2008, 06:21 AM | #24 |
Civilian
79
Rep 970
Change the CDV. You will get better with the smoothness of changes - specially 1-2. However, it will never be perfect. I changed my CDV after 1 year and I was used to it. However, even after a year there was a great change.
Dammittt is talking about 2 different issues. Firstly - The gear box is not very smooth. Mine became smooth after 15,000km. Secondly - Mine also refused to go into 1st one fine day. I have to put it in second for a second then go back to first and takeoff. I would change the CDV even though you will get used to it. The CDV is 'supposed' to protect the transmission. However what it really does is shorten clutch life. |
06-09-2008, 07:31 AM | #25 |
Rep 821
The gear change part of it seems fine in my lesser car, but, sometimes when doing the 1st to 2nd, it gets the 'bunny hop'. I know it is this stupid valve causing this, but it doesn't do it all the time. Sometimes it takes a good hard shift then again the 'hop'. Anyone know why it do and why it don't?
06-09-2008, 09:33 AM | #26 |
Rep 1,379
Drives: E89 Z4 sDrive28i M Performance
I suggest you run out the gears longer. Shifting too soon is a sure fire way to get a jerky shift, especially in the low gears.
06-09-2008, 12:46 PM | #27 | |
BMW Novice
69
Rep 237
Drives: M Coupe
06-09-2008, 01:36 PM | #28 |
BMW Novice
69
Rep 237
Drives: M Coupe
So for my M Coupe I should order this CDV? And also, is that the best website for those parts?
http://store.zeckhausen.com/catalog/...9cb3fc629f3426
06-09-2008, 01:53 PM | #29 | |
Rep 11,667
The only other option is a complete removal. |
06-09-2008, 02:36 PM | #30 | |
Rep 4,365
but I think I will change it anyway because it is so much different than my other car so switching between them feels weird.
06-09-2008, 03:07 PM | #31 |
My favorite sign.
169
Rep 4,333
True...I have gotten used to it, but that being said, I'll probably do the CDV mod at some point.
The CDV shouldn't stop you from shifting into a gear tho. If you're used to the way the car shifts and the amount of time it takes for the clutch to engage/disengage, than changing the CDV will force you to relearn the car, although it probably wouldn't take too long. So, if the issue is clutch feel and shift time, than get the zeck CDV. If the issue is random gear change refusals, either give it time, or try to get the gearbox changed under warranty. I think the bottomline here is that the zeck CDV isn't going to hurt anything. But, will it fix your non-shift issues? Probably not.
06-15-2008, 12:40 AM | #32 |
Rep 421
Its funny, after a couple of test drives I really had no idea where you guys were coming from with this issue. Now that I've put 700 miles on my car I see the problem. I'm still not sure if the CDV is the source of the problem or if its just a combination of a really sensitive throttle and clutch engagement. I'm thinking I'll give it a couple thousand miles to see if I can adjust but yeah, its definitely different than any manual I've ever had.
Tom, are you getting more used to it, or is it still the same thing? |
06-15-2008, 10:30 AM | #33 | |
BMW Novice
69
Rep 237
Drives: M Coupe
06-15-2008, 01:30 PM | #34 |
Loud and Fast
Rep 30
I just changed out the CDV with the zeckhausen part, and it definitely "feels" different... nice IMO feeling the clutch grab in a much more positive way related to releasing the pedal. Probably no way to tell if it's better or worse over the long term, just different for now in a way that I like... I do have less "jerky" starts, but I'm not ready to say that's the CDV change, I'm only 3000 miles into the car and moving between 3 very different cars driving so it's taking me a while to adjust.
07 Z4MC ~ imola red/black nappa/carbon leather ~ OEM strut tower brace ~ Zeckhausen CDV ~ stubby antenna
01 Trans Am WS6 ~ BMR subframe and shock tower brace ~ SLP air box ~ Lou's short stick ~ SLP TCS reverse module 04 Civic Si ~ daily driver ~ Alpine w/ big-ass sub |
06-17-2008, 12:42 PM | #36 |
Rep 689
Another Illinois M coupe- Congrats.
I vote for leave the CDV alone. It is much easier to get used to than learning to shift and AWD sports car smooth. Also, driveline work is not cheap...btw, clutches are cheaper than replacing other parts of the tranny. IMHO. Cheers.
06-17-2008, 03:20 PM | #37 |
Rep 128
Drives: Z4 M Coupe
The problem lies with the combo of the CDV and the electronic throttle that loves to change depending on your driving style. I still have my CDV, I will get rid of it at some point, but it can be really annoying.
I thought I was beginning to get terrible at shifting until I got back in my ancient beater and can shift and rev match it perfectly. If I could just get the throttle to stop trying to adapt, that would probably fix most of the problem. Right now, in ether sport or normal mode, the throttle barely does anything for the first 3mm or so of movement, and then it has a non linear engagement (faster in sport) that would be fine if it were an automatic, but on a manual, can be a bear to live with some times.
Watch my short film "The Milkman" http://milkmanthefilm.com
06-17-2008, 03:58 PM | #38 | |
Rep 1,289
'16 ///M4 GTS
'11.75 ///E90 M3 ZCP | DCT '06 ///M5 | SMG - Gone '98 ///M3 | 5MT - Gone '07 ///M Coupe | 6MT - Gone |
06-23-2008, 12:22 AM | #39 |
BMW Novice
69
Rep 237
Drives: M Coupe
Yeah, I think I'll take my odds and replace the CDV on mine, too.
06-23-2008, 08:49 AM | #40 | |
Z4M CSL
31
Rep 173
The throttle is perfectly linear, if someone over sensitive (too light a pedal?). I'm happy to say that, in my opinion, the problem is purely down to the CDV. I never use the Sport mode btw. It's simply makes the pedal too responsive at light throttle openings...
06-23-2008, 09:34 AM | #41 | ||
Rep 1,543
06-24-2008, 09:39 PM | #42 |
Rep 97
Drives: 2007 Z4 M Coupe
This weekend at the LA AutoX I drove a M Z4 Roadster with the CDV modified..I now am a beleiver.
It was so much easier to shift. I have about 6K miles on my car and am used to it. But just driving in the parking lot with the modiefied car was better. |
06-25-2008, 02:48 PM | #43 | |
Rep 4,144
If it is still hard to shift then try the CDV replacement. And if it still sucks you can always get a short-shift kit. A weighted shift knob also helps.
2017 F80 YMB.
