06-01-2008, 03:23 AM | #1 |
Rep 49
Handling like Boxster S?
I had to chance couple days ago to test drive a Porsche Boxter S. What a car and amazing handling it had. It blew my away. It felt like a go-cart and my z4 like a comfort car
Now, my wondering is if a want to improve the handling on my Z4, is it enough to just change the springs like H&R or do I have make major changes to the suspension? |
06-01-2008, 10:16 AM | #3 |
My favorite sign.
167
Rep 4,333
The Z4 will never handle like the boxster S. The mid engine design is what makes it handle so well.
06-01-2008, 09:36 PM | #4 |
Rep 97
Drives: 2007 Z4 M Coupe
I agree. I did back and forth test drives between Cayman S and Z4M Coupe.
The Cayman was much easier to drive fast in the corners. I just couldnt rationalize the price bump to get the Cayman. Maybe a real good driver can squeeze the same numbers out of both cars, but to a amateur like me, the Cayman made me feel like a great driver. I too think the weight and engine placement of the car make a big impact on the way it drives. So it would be hard to make a front engine Z4 drive like a mid engine car. |
06-02-2008, 02:50 AM | #5 | |
BMW Fan
11
Rep 553
Porsche did a better job of suspension tuning on the Boxster/Cayman than BMW did on the Z4, and Porsche put better tires on the Cayman S, way better than the Continentals on the Z4M. It is possible to get the Z4 to handle as well as a Boxster or Cayman, but you have to spend some money and change some parts, particularly the springs, shocks, and tires. |
06-02-2008, 06:38 AM | #6 |
Rep 14
I came from a Boxster S...
My car previous to the Z4M Coupe was a Boxster S, which I tracked extensively - it was not modified. Although I have yet to track my Z4MC, I feel it will be quite a bit faster - especially on higher speed/longer tracks. The main differences are in the factory setup, namely:
- The Conti Sport Contacts and/or RFT on non-M's are inferior to anything on a Boxster or Cayman, this makes a huge difference - The Z4MC is set to understeer, whereas the Box and Cayman are pretty neutral from factory - (related to braking) the Z4MC brakes are great, but the pads are spec'd for comfort/cold stops, whereas Porsche OE pads/fluid can take more heat On my car, I swapped the Conti's for Toyo T1R's and 19" CSL wheels; added a strut brace and more negative camber in the front (-1.3 degrees); replaced the OE pads with Axxis Ultimates and ATE Super Blue. The car was very good originally, but now it feels transformed with just these small changes. I was expecting the tires to make a big difference, but was the most surprised by the strut brace -- the Coupe is very rigid but for some reason the brace immediately improved turn-in and dialed out understeer. As far as weight distribution, the cars are actually very similar - although the Z4 is ~200 lbs. heavier. Porsche puts the driver in front and engine behind, BMW the opposite with almost the same effect. The Box/Cayman have a slight rear bias which does help with braking stability and corner exit/traction. I"ll report back on June 29th after a day at Sebring, but I expect the Z4MC to be quite a bit faster than my Box S. Cheers |
06-02-2008, 08:00 AM | #7 |
My favorite sign.
167
Rep 4,333
06-02-2008, 12:11 PM | #8 |
Rep 49
thanks angrodri for the very intresting reading!
though i think i will begin to change to springs first. About the springs most people recommend me to buy the Eibach Pro kit wich will lower 15mm on the m-chassi. and then there is the H&R springs wich lowers more but som people tells me to avoid it. First of all that it gets to low and handling can become worse. True? All though my Z4 has 19inch wheels and it feels like to high, i could really need a bigger drop. |
06-02-2008, 12:18 PM | #9 | |
Rep 1,689
If you are going to do suspension, I suggest getting shocks with the new springs you're planning on getting. Factory shocks are valved to the springs they come with and just changing springs may cause premature wear of the shocks and make them more prone to blowing out. You may also want to look into beefier sway bars like those from Hotchkis or H&R.
2006 VW Jetta 2.5 Once upon a time... '03 VW GTI, '99 Audi A4 1.8TQ, '00 VW Jetta 1.85T, '09 BMW 335i xDrive, '04 BMW Z4 3.0i, '01 Audi TT 1.8T, '04 Volvo S80 2.5T |
06-02-2008, 12:26 PM | #10 | |
Rep 821
06-02-2008, 02:09 PM | #11 | |
Rep 14
The Eibach springs should help. As an option you can consider the Bilstein PSS9 or K&W coil-over kit for the Z4 Another option might be the Z4M struts/springs/sway bars from factory -- could be cheaper?
I agree on the strut bar, it is a good first step. Cheers Quote:
06-04-2008, 07:32 PM | #13 | |
48
Rep 397
no kidding. WTF?
I think "Car62" will be making his way to my ignore list. |
06-04-2008, 07:42 PM | #14 |
My favorite sign.
167
Rep 4,333
I want him to show me a car with the engine in front of the front axle.
06-05-2008, 08:31 AM | #15 |
Car Guy
31
Rep 796
Actually, most of the Audis made have the majority of the engine mass in front of the front axle
06-05-2008, 08:43 AM | #16 |
My favorite sign.
167
Rep 4,333
BOOOO!!!!
06-05-2008, 11:08 AM | #17 |
Rep 51
06-05-2008, 12:52 PM | #18 | |
Rep 598
where'd you order it. thanks! |
06-05-2008, 12:56 PM | #19 |
Rep 598
Bill, you are my favorite member on this site. You rarely post, but when you do it is either very informative or very funny. I also view your website about once a week, more updates please! Keep up the good work!
06-06-2008, 03:49 PM | #21 | |
Rep 238
Most on the board may not be aware of the fact that BMW generally designs their front engine cars with the center of gravity of the engine BEHIND the centerline of of the front axle. This has classically been a requirement of a proper sports car and is also what enables BMW to get the 50/50 weight distribution. The engine not being located in the fashion in most front wheel drive cars is what makes them pigs to drive - the engine placement is a major source of understeer. |
06-07-2008, 03:57 AM | #22 |
BMW Fan
11
Rep 553
A lot of the posters on these boards know next to nothing. They just like to type in comments and statements based on their small bit of information. Mazda marketed the original RX-7 in 1979 as a "mid engine" car because the engine, although in front of the driver, was behind the centerline of the front axle. In 1979 most of the members of this forum either weren't born yet or were having their diapers changed.
