      06-21-2008, 12:36 PM   #1
Jeffrimerman
Drives: BMW R50
Just bought my 03 Z4 and I need to do some maintenance.....
I need to change the brake pads on the rear. The brake pad light is on and the seller said it was the rears. Does autozone carry good ones? I felt the rotors and they didn't feel too bad. Car has 75k miles on it, but it is super clean. I need to do an oil change also. I assume 5w30 mobil one is ok. I need to see if I can get the oil filter locally or is it dealer item?
      06-21-2008, 12:47 PM   #2
Jeffrimerman
Drives: BMW R50
I am searching for a how to with some pics on doing an oil change and rear brake pad change. Is there one posted here somewhere? I am driving 400 miles tomorrow and it would be kewl to do the oil change asap=)
      06-21-2008, 05:55 PM   #3
fins
fins's Avatar
Drives: 2007 Z4MC
try these for pads: http://store.zeckhausen.com/catalog/...h=3_79_150_238 . i just switched and brake dust is MINIMAL now. equal to or slightly better performance than stock. my mechanic said it was a pretty straight forward install.
      06-21-2008, 06:03 PM   #4
Jeffrimerman
Drives: BMW R50
The bmw parts department told me I can re-use the brake wear sensor if it isnt damaged. I will find out. I should be fine to do it. I just want some kinds of pics to refer to.
      06-21-2008, 11:12 PM   #5
BlackSapphireZ
Drives: 22 GLE 53 Coupe
if its lit, then the sensor is no longer good
oil change, u might want to get 36mm socket and 7 quarts of 0w-40 and a oil filter from your local auto parts store
2022 GLE 53 Coupe
      06-21-2008, 11:35 PM   #6
Jeffrimerman
Drives: BMW R50
I have the 36mm and the oil filter already, but I was going to get 5w30. So I should get 0w40 instead.
      06-23-2008, 11:24 PM   #7
Jeffrimerman
Drives: BMW R50
I changed my rear brake pads which were really low, but I noticed the rear brake wear sensor wasn't even scratched. Is it possible that the close proximity to the rotor cause it to set the warning light off? So I just reconnected it to the new pad. Will the light go out after a while?
