      02-17-2014, 11:15 AM   #1
close_to_the_edge
close_to_the_edge's Avatar
Turkey
Drives: 2007 Bmw Z4 3.0 Si Coupe
engine oil
Hi all, I need to add oil on the engine of my z4 3.0 si coupe(at 82000km)?
I was recommended Castrol.
Which brand is the better?
Regards
Kadir
      02-17-2014, 01:57 PM   #2
newbizie
newbizie's Avatar
Drives: 05 Z4 3.0i
I just use the original BMW oil some say it's just re branded castrol but it's only a few bucks more and u know for sure I paid $6.50 per quart from the dealer and change it myself
      02-17-2014, 01:58 PM   #3
psygnosis
psygnosis's Avatar
23
Drives: '04 Z4 3.0i Sport
The oils listed below meet BMW’s Long-life rating and are acceptable for use in BMW Passenger vehicles and SAVs in the US market with gasoline engines.
BMW Long-life rating LL-01 Approved Synthetic Oils for the US Market
Castrol Syntec European Formula SAE 0W-30
Mobil 1 SAE 0W-40
Pennzoil Platinum European Formula Ultra SAE 5W-30
Valvoline SynPower SAE 5W-30
Use only oils with an API rating of SM or higher.
The choice of the right SAE grade is based on the climatic conditions in the region in which you normally drive your BMW.
This is the former recommended oil list before they switched to the new one
      02-17-2014, 01:59 PM   #4
close_to_the_edge
Turkey
what is the specification of it?
      02-17-2014, 02:00 PM   #5
close_to_the_edge
Turkey
Mobil 1 SAE 0W-40
thanks.
      02-18-2014, 03:25 PM   #6
newbizie
newbizie's Avatar
Drives: 05 Z4 3.0i
5W-30 Fully synthetic
      02-20-2014, 01:18 PM   #7
close_to_the_edge
Turkey
this what I could find in the seller. I add only 1 litre on the engine and and the yellow warning stopped.
It matches the spesificatioın you gave to me. But I have a question now that should I use 5W-30 or 0W-30, which one is better?
On the other hand I consider to renew oil in the engine completely? Is
it make eany difference in the performance? Is better oil better performance?
thanks for all post from you.
regards
      02-20-2014, 08:34 PM   #8
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
193
Drives: '01 911 Turbo
Mobil 1 full synthetic 0W-40 should be just fine. Relatively cheap if you purchase 5-quart jugs from Walmart. Then buy some OEM filter kits from like Tischer BMW ( http://www.getbmwparts.com/partlocat...egoryID=103121) or something. I believe the non-M engines use the same filters as E46? I could be wrong, but you can still navigate that site as needed and purchase what you want.
      02-21-2014, 12:06 PM   #9
close_to_the_edge
Turkey
I'm driving 3.0 si coupe, not M coupe. Is OW-40 suitable for me?
As for filter I ask for my service to change it when I completely change oil.
regards
      02-21-2014, 12:28 PM   #10
close_to_the_edge
Turkey
regards
      02-21-2014, 02:49 PM   #11
mfanatic325
///M-fanatic
Taiwan
193
regards
Yes sir...Mobil 1's 0W-40 is perfect for non-M engines. I use it in my E46 325Ci, which uses the same grade of oil as the 3.0L variants.
M engines require 10W60.
      02-21-2014, 04:50 PM   #12
close_to_the_edge
Turkey
thanks!
      02-21-2014, 05:54 PM   #13
pungo
pungo's Avatar
I'm not sure if they have Walmarts in Istanbul?
      02-21-2014, 06:46 PM   #14
close_to_the_edge
Turkey
sure there is no walmart in istanbul
I will check with my seller -its a castrol branch.
      02-23-2014, 07:14 PM   #15
mfanatic325
///M-fanatic
Taiwan
193
sorry, I didn't pay particular close attention to your location
      06-29-2014, 04:56 PM   #16
close_to_the_edge
Turkey
Hi all, today after stop my car I had a warning on the screen displaying engine oil pressure sign. I checked the manual and then checked engine oil level. It needs to be added 1 lt new oil. Actually I'm suprised because I fully changed engine oil in BMW service about three months ago with Castrol Full syntetic 0W-40. Now I need your ideas. Is it normal engine oil requirement in a short time about three months? It's 2007 3.0 si coupe.
      06-29-2014, 07:26 PM   #17
mfanatic325
///M-fanatic
Taiwan
193
It is definitely not uncommon for an engine to "eat" or burn oil, but it's unhealthy if it's burning a full quart worth in such a short amount of time. Maybe take it in to have looked at? You may have valve cover leakage or some other kind of problem.
      06-29-2014, 07:34 PM   #18
close_to_the_edge
Turkey
Valve cover leakage? I'm getting be scared already now
      06-29-2014, 08:21 PM   #19
mfanatic325
///M-fanatic
Taiwan
193
It sounds scary, but isn't too bad. Usually if it is the valve cover, then all you'll need are new gaskets (which are just rubber seals around the edges of the valve cover).
      07-06-2014, 07:58 PM   #20
Clearancediver
Drives: 2004 Z4
And how many miles did you drive in the 3 months? Milage, not time is going to tell us if you have a problem or not. Using 1 litre every 1-1.5 thousand miles isn't uncommon.
Sent from my smart phone...
      07-10-2014, 06:24 AM   #21
close_to_the_edge
Turkey
I did 4000 km in this period.
By the way I went to BMW service. Service guy says burning oil is normal in BMW models. He changed oil with 10W-60. Now I will monitor how long will it take.
      07-10-2014, 09:45 AM   #22
mfanatic325
///M-fanatic
Taiwan
193
Why would they put 10W60 in a non-M engine? I think that is too thick an oil for your engine...
If they're trying to prevent oil from burning by introducing thicker oils, then I think you should stay away from servicing with them in the future
