12-01-2016, 12:57 AM | #441 | |
Rep 820
Drives: 2007 Z4MR silver grey
01-11-2017, 11:24 AM | #442 |
Rep 453
Drives: 2007 Z4M Coupe
Does anyone see any issues with running the below 19 inch setup with larger profiles and slightly larger than stock OD?
My Wheels are HRE FF01: Front: 19 x 8.5 ET 30 Rear: 19 x 10 ET 40 (w/12 mm spacer) Tires I'd like to run are MPSS's Front: 225/40/R19 Rear: 265/35/R19 I'm lowered on H&R springs (25 mm) and will probably go slightly lower with coil overs in the future. I went with the slightly narrower tire due to the aggressive offsets and MPSS tread width being wider than other brands. The proposed larger profiles (40 & 35) will get me closer to the stock overall diameter albeit just a tad larger. Per my calculations using Michelin data the overall tire diameters will be 5.1 mm (front) and 7.6 mm (rear) larger than stock. I'm not a track guy and mainly do occasional spirited street driving. |
01-23-2017, 11:50 AM | #443 |
Rep 142
Hello All.
I have been reading and reading and yes... even used the search feature here. I want to be sure I cover all my bases before pulling the trigger on my wheels. The challenge for me is that I want a set of wheels not normally selected by BMW folks. Any input will either continue to make me go cross eyed and run away, or buy with confidence. Thanks in advance. So... will they work with what I hope will be 245/275 45ish tires? I'm looking for Enkei Kojin's in an 18" Here's the details and some picks for reference. Old setup BMW ZCP's Front 8x19 ET47 on the wheel and an additional 10mm Spacer Rear 9.5x19 ET27 New setup Enkei Kojin Front 8.5x18 ET35 Rear 9.5x18 ET35 For reference, these are the wheels on my old 135i (sold them after the car was totaled a year ago). Same sizes.
Light a man a fire, you keep him warm for a night. Light a man ON fire,you keep him warm the rest of his life.
01-23-2017, 04:21 PM | #444 | |
Rep 2,877
Drives: Anything
01-24-2017, 10:50 AM | #445 |
Rep 142
Thanks for the reply. I was re-reading all 20+ pages here to find commonalities and be positive. I have read that if I use camber bolts and go to -2 degrees I may require a 5mm spacer up front for clearance on the suspension, but I'll cross that bridge when I get there.
Thanks again.
01-24-2017, 11:49 AM | #446 | |
Rep 2,877
Drives: Anything
02-13-2017, 08:51 AM | #447 |
Rep 17
My Z4 MC came with a spare set of VMR Wheels (VB3/V703) with a square set up of 18 x 8.5 (ET 40) and tire size 255/35 R18. Would it be helpful run a spacer in the rear, if so what size? I happen to have a pair of 15 mm spacers with longer lug bolts, would that be appropriate?
The prior owner ran the rears without a spacer, but someone said they didn't look flush. Thanks for your input! Marc Last edited by mcaden; 02-13-2017 at 08:52 AM.. Reason: Fix |
02-13-2017, 09:24 AM | #448 | |
Rep 453
When I was running stock setup I had a 10 mm spacer (ride height lowered 25 mm) with no issues so I think you could do a 25 mm spacer and be fine and get an even more flush look. Of course you would have to make adjustments to the front to get a consistent look front to rear. |
02-22-2017, 02:10 PM | #449 | |
Rep 17
04-06-2017, 02:35 PM | #451 | |
Rep 2,720
This setup will be v aggressive, 21.4mm closer to suspension strut and outer rim poke out 29.4mm. This may rub the sidewall. |
04-06-2017, 03:02 PM | #452 | |
Rep 1,101
I know the same wheels were previously on an e46 m3 which was dropped on kws and had no fender work done. This is the fitment on the e46 m3. Last edited by CJW2OO4; 04-06-2017 at 03:37 PM.. |
04-06-2017, 05:57 PM | #453 | ||
Rep 2,720
I'm moving to 275/30/19 tires on wheel 9.5 wide, offset 25 and it only goes 11.4mm out...so within range. Someone with aggressive setup can chime in here. |
04-06-2017, 07:50 PM | #454 |
Rep 2,877
Drives: Anything
Those tires appeared to be stretched beyond what I would considered safe. But, to each his/her own
04-07-2017, 08:02 AM | #455 |
Rep 1,101
I have continentals which run a little wider and if there is enough clearance i will go wider with the tire. Different strokes for different folks. 275 is the minimum recommended size for the 11" width. I didn't think it was such a stretch.
04-25-2017, 05:15 PM | #456 |
Rep 30
Need tire size advice for Michelin Pilot Supersport
Wow this is a long tread with TONS of information and while I can appreciate it I have been overwhelmed. So please help dumb this down for me.
I have my original rims on my Z4MC and sadly the original tires from 2006. I am now up to 11k miles so plenty of tread for my old man driving style but time for new rubber. Car is summer only and I have decided on the MPSS (please no opinions on that, this is confusing enough). Now I just have two issue: 1) Size = Tire rack says 255/40ZR18 (95Y) XL on the rear and 225/45ZR18 95Y XL on the front. I see a lot of posts with lots of other sizes. I assume that to maintain the stock look that is the size I should go with but what tire size would you recommend? (not racing, just thinking of resale-looks-and driving feel) 2) Price = Once I know the sizes I can shop the internet with the best of you so let's skip the "try a google search". If you have some specific direction on where you feel the best deals can be had please offer it. Last edited by zoomzoomvaroom; 04-25-2017 at 05:21 PM.. |
04-25-2017, 06:03 PM | #457 |
Rep 11,668
zoomzoomvaroom
With your stock suspension setup I highly recommend staying with the original spec sizes. They are aprox 26.0 inches in diameter and will fill the wheel well gap better. If you go to a larger size (265/35 & 235/40) the side wall aspect ratio reduces the overall diameter to ~ 25.3" This will make the gap over the tire look even larger than it is now. Your car looks great the way it is! I would stay the course.
scrammer422.50 |
04-25-2017, 09:10 PM | #458 | |
Rep 453
05-08-2017, 10:59 AM | #459 |
Rep 264
Curious to see what the members think of these combinations on a z4m. I have the turner shim kit with alignment pins pulled and have -2.7 degrees camber on the front, with stock suspension. I am currently running this setup:
Front 18x8.5 et 35 – 225/40/18 with 12 mm spacer Rear 18x9.5 et 35 – 255/35/18 with 18 mm spacer Thoughts on the following combos? Tires are Continental ExtremeContact DW, and I am primarily concerned with the fit on the front Front 18x8.5 et 35 – 255/40/18 Rear 18x9.5 et 35 – 275/35/18 Or Front 18x9 et 42 – 255/40/18 Rear 18x10 et 25 – 275/35/18
2017 M2 - Camber Hubs, MPE, and some other goodies 2006 Z4M - Epic Tune / Eventuri CAI / Euro Headers / Stromung / FA 500 / AS SSK / Arc 8s 2004 Z4 3.0i - Gone, but not forgotten! Last edited by jns_e85; 05-08-2017 at 11:56 AM.. Reason: Added more details |
05-30-2017, 10:36 AM | #460 |
Rep 142
Loving the new shoes for Bianca.
Enkei Kojin 18x9.5 35et Bridgestone RE-71R's 265/35/18 5mm plate up front and a 10mm plate out back.
06-04-2017, 10:20 PM | #461 |
Rep 735
Mixing things up a bit - moved from a square set of 235/40 P-Zeros on BBS CH 8.5 et35 w/ 15mm spacer in the back to the stockers in Graphite Metallic with Matte Clear and 15mm front and 12mm rear H&R spacers and stock Conti tires …. thoughts?
PS: my car met its brother from a different … today!
Current ///M: 2017 M3 Ultimate Past ///M Cars: E92 M3 ZCP 'CDN LRP' … E85 Z4M-R ... E92 M3 ZCP Frozen ... E90 M3 ... E46 M3 Cab ... E46 M3 ZCP ... E46 M3 Last edited by scrammer; 03-22-2018 at 12:14 AM.. |
06-05-2017, 08:24 AM | #462 | |
Rep 453
