12-14-2015, 02:15 AM | #1 |
Rep 291
Replacing Z4 coupe battery - standard (white) or AGM (black)
My battery (Z4 coupe 3.0si) is in need of replacement ... and on checking with BMW, there are two main options to go with:
1. Standard white 70A (this is what the car shipped with) [ Also available as an 80A ] 2. Black AGM (Absorbent Glass Mat) The AGM is apparently better for people who do lots of short trips (which is me). It is more expensive. * Black requires 'registering' and re-programming. * White one might also need registering (but not programming). For some reason, my dealer is quoting me less for fitting the Black than the white (excluding parts), so I am thinking of going for black AGM. Am interested to hear if anyone else has changed from standard white to AGM, and others thoughts. Last edited by krusty; 12-14-2015 at 02:28 AM.. |
12-14-2015, 05:32 AM | #2 |
Rep 86
Hi,
How much is BMW charging you for the battery change (including "registering") in Australia? I was informed by BMW over here that it would cost me $1647USD in total. |
12-14-2015, 06:28 AM | #3 |
Rep 291
Prices quoted to me:
Parts only: ====== Standard white battery: AUD$302 (70A) or AUD$350 (80A) Black AGM battery: AUD$547 Parts with fitting: ========== Standard white battery: AUD$550 Black AGM battery: AUD$700 Doesn't make too much sense, but that's what I was quoted. |
12-14-2015, 09:14 AM | #4 |
Rep 1,991
We are talking about an E86 coupe right? There is no "registering" if this is the case. Scam. Buy the battery at your local parts store and install it yourself. You will thank me later. I had an AGM from the factory which lasted 5yrs. I now have a regular lead acid battery(cheaper) and it has lasted over 4yrs so far. I don't see the advantage to the AGM.
12-14-2015, 11:36 AM | #5 |
your average JAMF
3101
Rep 4,094
Australia? I assume it gets brutally hot there? I'd go AGM, they are more heat resistant than regular flooded batteries.
The doc is right, there is no registration required on any E86/E86 Z4(M). Simple DIY task to replace the battery.
'21 M2 Comp
'19 Golf R |
12-29-2015, 12:41 AM | #7 |
Rep 291
I have been remiss in following up ... which is not such a nice tale.
After the new AGM battery was installed, on starting up again the car (for the first time after I got home), the car started making a loud GLITCH BLIP noise. The noise comes from the front (L+R) speakers in the footwell of the Z4. The engine does not need to be on ... just the ignition key turned to activate the electrics. Then, every 25 seconds, there is this really loud POP / BLIP noise from the speakers. Then it goes silent again for 25 seconds ... then BLIP. It sounds like something is shorting out. This has never happened before on the car; there has never been any electrical problems with the car, and the fact that it has now started would appear to be related to the change of the battery, or the way the battery was changed, or them jump starting the car after it was dropped off. Took it back to to the dealer today (after they re-opened after the Boxing day long weekend), and they are going to look into it ... |
12-30-2015, 04:57 AM | #8 |
Rep 97
I also had a 25 sec pop sound from the speaker in the footwell. It only appeared when the key was turned to position 2 or the car was started and in combination with my iphone (4s) had bluetooth activated. Deactivate BT and it was gone. Strange and annoying. The issue was solved when I got a new iphone (5s) so maybe it was software related and/or bad BT-sync in my case.
